Like Tree2Likes
RB Concept Engine Thread..
Old 04-13-2009 | 11:12 AM
  #271
johnny t's Avatar
Originally Posted by jameslow
Got a few questions about RB ws7ll
- do i need to remove the standard plug shim? bec i find that if i use the plug with the shim, the bottom of the plug cannot sit nicely into the button.
- is there people using 16% for off-road engine? how many shim do i need to shim for this engine if im running 16% and 25%?
Thanks! As this is my first time dealing with off-road engine.
are you sure you have the right kind of plug? RBs take a "long" body plug. There are also "short" body plugs commen to O.S. engines. sounds like you have one of those.
for head shims, In your case start with .3 mm thats what rb recommends the is the minimum for that nitro content. start with a #6 plug, and go colder (#7 or #8) if your idle will let you get away with it.
johnny t is offline
Old 04-14-2009 | 08:11 AM
  #272
NitroWD's Avatar
Default Bearing size
hi guys,
what're the front and rear bearing sizes for the WS7II? the manual didn't state the sizes...
i assume that all WS7 share the same bearing sizes? or all RB .21 offroad engines have the same sizes?
NitroWD is offline
Old 04-14-2009 | 08:26 AM
  #273
aznitronut's Avatar
Originally Posted by NitroWD
hi guys,
Here is a link to amainhobbies.com, for the rear bearing for the WS7 III, and most of the RB engines. The front bearings are all the same size. The C5 and C6 main bearings are a different size. RB Concept 13x25mm Rear Bearing for Square Stroke (E/S5/S7II/WS7II) Engines
[RBC01150-13S]
aznitronut is offline
Old 04-17-2009 | 01:25 AM
  #274
NitroWD's Avatar
[RBC01150-13S]
great! thanks... new bearings for my ws7ii.
by the way, if i'm using 16%nitro, do i need to remove the 0.1mm shim?
doesn't anyone use 16% for their .21 engines?
NitroWD is offline
Old 04-18-2009 | 01:41 PM
  #275
Eccentric's Avatar
Default What's Up with the RB Concepts Engine Forum?
The link I have for the forum now seems to be dead. Couldn't find a working link for it in a Google search either (just more dead links). First the stopped taking new registrants, then...
Sorry if this has been adressed recently here. I'm having problems with my internet connection, so searching is sketchy at best...
Eccentric is offline
Old 04-18-2009 | 02:23 PM
  #276
Update on my WS9
basically bought a rb2045 192 manifold combo for it, first start was instant loved it no locking on me first tank ran smooth bit on rich side leaned half turn to keep running.
Put 4 tanks through , will finish breaking it in nxt week and get it setup on track nxt sunday
adz06 is offline
Old 04-18-2009 | 07:58 PM
  #277
Midnight's Avatar
Does anybody know the diff between the s3 l2g and the s3 II l2g? Can I use the jp3 pipe?
Midnight is offline
Old 04-19-2009 | 08:04 PM
  #278
keavze's Avatar
Default ws7 vs c6
hi guys,
just wana find out how much difference (in terms of power) is the c6 compared with ws7?
or it's a no contest at all?
keavze is offline
Old 04-19-2009 | 08:35 PM
  #279
NitroWD's Avatar
Originally Posted by Mr. Twister
B9=C6 part for part
how about C9?
http://www.rbproducts.com/explose/RB...T/01009-C9.pdf
getting confused here...
NitroWD is offline
Old 04-19-2009 | 09:07 PM
  #280
how about C9?
I think that is an onroad engine.....
Chris__RC is offline
Old 04-20-2009 | 04:53 AM
  #281
JPMSRacing's Avatar
R/C Tech Elite Member
From: Lost in the Dead Space between my Ears Somewhere around Wamego, KS (OZ Land)
Originally Posted by keavze
hi guys,
WS7 lots more top end, big open track engine, C6 will pull wheelies in truggies, so much bottom end, great engine for typical smaller technical tracks, like in my area, and great fuel mileage, 8-10 mins on a tank, because it has so much power you never ever use much throttle.
JPMSRacing is offline
Old 04-20-2009 | 05:23 AM
  #282
triplesix's Avatar
I highly doubt, the C6 has less top end than a WS7! Both have great top.
While the WS7 has very well but still well controllable bottom, the C6 is just an animal! A C6 is by far a better truggy engine than the WS7 is.
triplesix is offline
Old 04-20-2009 | 05:42 AM
  #283
Default best plug
I have the WSTL2g and was wondering which would be the best plug to run in it? I was thinking of this one: http://www.amainhobbies.com/product_...oducts_id/2226, would you recomend this one or another? Let me know what you think.
nick_m is offline
Old 04-20-2009 | 06:48 AM
  #284
NitroWD's Avatar
does that mean c6 is not suitable for buggy?
NitroWD is offline
Old 04-20-2009 | 07:00 AM
  #285
keavze's Avatar
oops my bad.
by the way, i've a used c6 but how to tell which version is it? the prints on the heatsink are totally 'un-readable'.
it uses a turbo plug and with red 7mm venturi. BBT, BBTII or BBII?
on the rod there's a '05' engraved.
keavze is offline
