RB Concept Engine Thread..
#242
From: Lost in the Dead Space between my Ears Somewhere around Wamego, KS (OZ Land)
I am still looking for a pipe for my C6, the 2045 RB pipe in the buggy class doesnt pass the RC Pro Series stinger size, the stinger is to big, their little gauge thing that is suppose to not fit into the exhaust hole just slides in.
#243
Savoya is running the 2045 with the 192 header, I just saw him in Vegas this last weekend at the Silverstate race, and I looked at his buggy.
#244
Got it here ONLY 1 LEFT NOW
http://www.topoptions.com/index.php?...&productId=431
Not bad price seeing as the ws73 is 239.99.
#248
BMI Hobbies in Plano, Tx just signed up to be a distributor for RB.
They only have one US source that importing from France and it just happens to be located in Texas now.
BMI was told that the WS9 and B9 should be avaliable to them in about 2 weeks. They are waiting on the product catalog then they will be placing orders for the new Line of RB.
So in about 2 weeks we should have real prices on these engines and they will be in the US so shipping will go down..
Look them up online and get there number to call and check status or check there online store they have.
I won't post the link, so I am not advertising, but you can google BMI Hobbies and find them, or PM me for more info about them.
#249
#251
Hey guys i have aS7 and a WS7-III and would like to know how maney shims to run 20%? I took the heads off and they have 1 shim on each is this right for 20% the guy i got them from said he ran 30% but i was thinking you need 2 shims for 30%.
#252
#254
Just make sure you know, shims aren't all 0.1mm.
Stock the engine should have two shims;
1) 0.2mm
1) 0.1mm
that gets you a total of 0.3, you need one more 0.1 for 30 percent(0.4mm). You could also use two 0.2mm shims if you wanted, to only have to bother with a total of 2 shims.
EDIT: if you want to run 20 percent, use 0.3mm in shims total (probably the two the engine came with....although i'd still check)
if you want to run 30 percent, use 0.4mm in shims total
2Likes
