Like Tree2Likes
RB Concept Engine Thread..
Old 05-10-2010 | 05:08 AM
  #1246
Chris Peralta's Avatar
Originally Posted by diamondracing
I think those cranks might still be able to purchase but they are expensive really expensive.
They are available if you are able to find a shop that has one, RBUSA had one left a few months back, but I bought it. They aren't made at all anymore but there has to be a few out there somewhere. Like Don said tho they are a very expensive part, if you do find one tho it might be at a clearance price.
Chris Peralta is offline
Old 05-10-2010 | 05:34 PM
  #1247
get some new
and very nice price for this.
Attached Thumbnails RB Concept Engine Thread..-1005100209b740f37d7db45397_jpg_thumb.jpg   RB Concept Engine Thread..-1005100209cb28e42ab5431589_jpg_thumb.jpg   RB Concept Engine Thread..-10051002093b7e396232f2f0b4_jpg_thumb.jpg
cow9527 is offline
Old 05-10-2010 | 05:47 PM
  #1248
tc5 man's Avatar
Originally Posted by cow9527
get some new
dam thats just to nice looking man, im wating for my hobby 9 5 port to come in im using for my truggy.
tc5 man is offline
Old 05-10-2010 | 06:09 PM
  #1249
yes,very nice. just can't get time to break-in on hudy.
when I'm in track, only want to drive the car. I got it on 2 april, and still in the box.....
cow9527 is offline
Old 05-11-2010 | 09:58 AM
  #1250
Default Wrist pin
I'm changing the rod on my S5 and I can't get the wrist pin out. I have the c-clip out and the pin is tight in the piston. Do you need to heat the piston to get it out and reheat to reinstall it.
aj slidways is offline
Old 05-15-2010 | 06:41 AM
  #1251
does any know the stock settings on a c6 bb thanks
dan200487 is offline
Old 05-15-2010 | 06:31 PM
  #1252
tc5 man's Avatar
i have a question i just got the rb hobby, 9 5 port and im breaking it in and i heated it with a heat gun at 180 , degress and the glow plug is bright red and good im using a meduim hot, #5 plug and the idle is open enough. well i bliped the throttle a couple of, times to clear it out than i let it go back to idle but with the glow inighter, on and when its off it will shut off.
should i lean the main and lsn, needle out a little bit or something ? it dint come with a restricter so i added, a # 8 one is that the reason why i wont keep running so i have, to lean the neddles a bit ?
anybody ?
tc5 man is offline
Old 05-15-2010 | 08:57 PM
  #1253
Big KAT's Avatar
High 3.5 turns from closed
Low 5 turns from closed
Big KAT is offline
Old 05-15-2010 | 09:02 PM
  #1254
Big KAT's Avatar
I would suggest you open up the idle a little. The mechanical pinch of the motor can snuff them out until they break in some. Once it is broken in some you can turn it back down.
Big KAT is offline
Old 05-15-2010 | 09:05 PM
  #1255
tc5 man's Avatar
ok the idle is a bit more than 1mm , i did have a hard time starting it though
may be i should preheat the engine intill it gets 200 degress.
oh yea i know there tight the piston got stuck quite a few times.
tc5 man is offline
Old 05-16-2010 | 05:59 AM
  #1256
RoosterXp's Avatar
Originally Posted by Chris Peralta
The best fuel economy I have had was running the 192 header and 2045 pipe. I tried a few of the JP pipes and never had very good luck with them, I think all I ever tried was a JP1 and a JP2 tho.
I threw a JP3 pipe on my C6 in my truggy and it held a tune so nice!! excellent power and decent run time!!! i felt like i was chasing a tune with the 2045 pipe.
RoosterXp is offline
Old 05-16-2010 | 12:10 PM
  #1257
Paperman 90's Avatar
Hey guys i just pick a used ws7 and i want to know what type of glow plug should i run in it.
Thanks for the help
Paperman 90 is offline
Old 05-16-2010 | 01:15 PM
  #1258
TIX's Avatar
TIX
i run the odonnell 97T or 99T plugs in my ws7
TIX is offline
Old 05-16-2010 | 02:47 PM
  #1259
Twitchy Kanai's Avatar
Thanks for the help
O'donnell 97T with Werks 2013. I get over 14min run time on my truggy.
Twitchy Kanai is offline
Old 05-16-2010 | 03:54 PM
  #1260
tc5 man's Avatar
anybody else have advice on getting, my hobby 9 to keep running during break in its my first tank, the glow plug is fine and idle is set right.
tc5 man is offline
