RB Concept Engine Thread..
#3076
I have a rb fire 12 in my mugen buggy. It's way way way too much power pretty much skate the car the whole way round the track. Very on/off delivery. Would this be any good in the rc8tce or same thing-too much. Thinking with the extra grip and weight it should tone the fire down a bit.
It's only just nearly broken in still creeping up on race tune. If it's gonna be too much I'd prefer to not install it at all and sell it off whilst it's still fresh. Is the a way to tone it down a bit without running it blubbering rich at all?
Truggy is in the mail will be here tomorrow, currently has a works b7 pro installed. How do these 2 engines compare? Trying to work on the slow is fast principle and the fire doesn't condone this style at least not in a buggy.
#3078
Are they the same engine?
Why is it more expensive without the pipe?
http://www.absolutehobbyz.com/produc...ducts_id=10587
http://www.absolutehobbyz.com/produc...ducts_id=10584
#3080
#3081
Sounds good... I've tried to sell my V9 a few times, with no luck.., so I guess I'll be stuck with it. See how it goes.. Just have to find the time - and for one of my other engines to die.. I have more engines than I have time to run them these days unfortunately.. And the weather has been awful too(even by German standards..)
#3082
We are happy to release the Murnan Modified RBM5 .21 Offroad Engine.
The RBM5 was designed for today's most demanding drivers who want exceptional power, and fuel mileage together. The RBM5 delivers both. The RBM5 is a great engine to use for Buggy racing. The engine parts are all made in Italy, and are of the finest quality. The engine is hand tuned by Murnan
The engine design allows for smooth controllable bottom end with a high top speed. The engine has a very linear powerband, which is easy to drive. Fuel mileage is exceptional.
-5 port sleeve with 2 by bypass ports and 3 Port Exhaust System
-CNC machined piston for super long life
-14mm Lightened, Bi-turbo crankshaft
-Competition conrod
-Turbo combustion chamber
-14mm main steel bearing
-Front dust protection double rubber sealed steel bearing
-Low Center of Gravity & lightweight cooling head
-Lightweight but strong crankcase
-Composite slide carburettor 7mm insert
-Hand Tuned
Specifications: 3.49cc
Bore: 16.22mm Stroke: 16.80mm
Porting Intake: 5 intake + 2 bypass Porting
Exhaust: 3 port Exhaust System
Crankshaft: 14mm Lightened, Biturbo
Carburetor: Nylon 9mm
Weight: 348g
Plug: Turbo
R.P.M. (max power): 36,000
RPM Practical range: 6,000-40,000 R.P.M. Fuel 25%-30%
Smooth Setup: Novarossi 9901 Exhaust, with Novarossi 41021 manifold / 7mm restrictor, Novarossi C6TGC/C7TGC Glowplug
Aggressive bottom end Setup: Novarossi 9853 Exhaust, with Novarossi 41021 manifold / 8mm restrictor, Novarossi C6TGC Glowplug
More Compatible Exhaust System: Werks 2058 / Novarossi 2096 / Novarossi 9886 / RB2097 There are more Exhaust systems that work great, these are just a few.
-Competition conrod
-Hand Tuned
Weight: 348g
Plug: Turbo
#3083
sprattz
the rb fire is powerful but not too much for buggy
you just need to work on your setup try carbon clutch shoes
and ligter centre diff oil my setup is 3carbon rmv shoes 1st shoe drill 1x2.5mm
hole 2nd shoe 2 holes and 3rd shoe 3 holes useing mugen 1.1mm springs
hope this helps.
hope this helps.
#3084
Hey guys.. I have a RB B10 I bought a couple of years ago. The engine gave me 13 gallons and still had compression. I sent it to get resized and the PSC got lost in the mail. Well... after a Nova 21-4, Odonnell POS, Dynamite V2, and a Gotech GT5, I decided to get a new psc for the B10. Nothing compares to good reliability for me. I lost the 2045 pipe and manifold though and I'm wondering if a dynamite 053 tuned pipe will work well with an RB B10? I don't really want to buy another 2045...
#3086
Looking for some help please. Ordered a few of the RB limited edition 5 ports (Blast V12) for stock and would like to know best pipe choices and headers for buggy and Truggy please as well as best glow plug choice? Thank you.
#3087
#3089
-Competition conrod
-Hand Tuned
Weight: 348g
Plug: Turbo
-Competition conrod
-Hand Tuned
Weight: 348g
Plug: Turbo
2Likes
