Like Tree2Likes
RB Concept Engine Thread..
Old 04-20-2009 | 07:05 AM
  #286
triplesix's Avatar
Originally Posted by NitroWD
does that mean c6 is not suitable for buggy?
It's very suitable, lots of people run this smill in their buggies! It pulls very hard from the bottom and is therefore not the easiest to handle, specially on low traction surfaces.
triplesix is offline
Old 04-20-2009 | 07:08 AM
  #287
With the right restrictor, it's(c6) really good in a buggy. I would never use it myself, because it could pull a 400lb person on a computer chair, but it's good if you can handle it.
Semple is offline
  #288
JPMSRacing's Avatar
R/C Tech Elite Member
From: Lost in the Dead Space between my Ears Somewhere around Wamego, KS (OZ Land)
O heck no, I dropped 4secs a lap where I club race by pulling out the V-Spec and putting in a C6 in my CR-X1X Buggy last year and I just ordered another C6 for my X2 Buggy this year. My sons CR-X1 has a WS7 in it and its way faster down a long straight.
JPMSRacing is offline
Old 04-20-2009 | 07:37 AM
  #289
Midnight's Avatar
Originally Posted by Midnight
Does anybody know the diff between the s3 l2g and the s3 II l2g? Can I use the jp3 pipe?
Any one?
Midnight is offline
Old 04-20-2009 | 08:35 AM
  #290
Eccentric's Avatar
Another quality, quotable post from Semple!
I agree 100% about the C6.
Eccentric is offline
Old 04-20-2009 | 09:46 AM
  #291
rallyebmx's Avatar
Thats good! I've got the USA waiting to go in-I'm scared
rallyebmx is offline
Old 04-20-2009 | 09:58 AM
  #292
slaytanic's Avatar
Whats the best plug for an S5? I'm using a 2035 pipe with it.
slaytanic is offline
Old 04-20-2009 | 10:57 AM
  #293
JPMSRacing's Avatar
Thats funny right there
It does have alot of power, it helped me in buggy because of fuel mileage and where other cars have to hold enough momentum wide in a turn to make a jump, I can hug the pipe and blip the throttle and make the jump, also in a timed section, if you get out of time you can recover quickly. And at one track they still use a gate drop, that C6 will put 10ft on any other car on the straight out of the gate.
Old 04-20-2009 | 11:33 AM
  #294
triplesix's Avatar
it comes with a novarossi/rb 6 standard plug from the factory. works like a charm.
Old 04-21-2009 | 12:59 AM
  #295
keavze's Avatar
Default 16% nitro
hi,
on the ws7 and c6 there's total of 0.3mm shims (usable to 25%nitro according to manual); if i wana run 16%nitro, do i have to remove 0.1mm shim or leave it alone?
keavze is offline
Old 04-21-2009 | 01:57 AM
  #296
putterx's Avatar
Has anyone ever tried the turbo head on the S5. If so what are your results?
putterx is offline
Old 04-21-2009 | 08:55 AM
  #297
NitroWD's Avatar
about RB 192 header, it's considered as short?
NitroWD is offline
Old 04-21-2009 | 12:54 PM
  #298
Midnight's Avatar
Any word on when the new motors will be in the US.
Midnight is offline
Old 04-24-2009 | 09:45 AM
  #299
slaytanic's Avatar
Anyone know the factory settings for the S5?
Old 04-24-2009 | 11:01 AM
  #300
Idle air gap 0.8mm
High jet. 3.5 turns out from closed
Low jet 5 turns out from closed (make sure you set this by holding the slide full open otherwise you will damage the spray bar)
losi8lunie is offline
