Like Tree2Likes
RB Concept Engine Thread..
Old 04-11-2009 | 12:25 PM
  #256
JUD's Avatar
JUD
Originally Posted by aaron joy
I was told also about two weeks on the 9 series. I will be trying out the five port (RB "Hobby" 9) when they become available. Prices are not bad, you pay for quality!
Hey Aaron are they going to have a 3 port available also?
JUD is offline
Old 04-11-2009 | 12:33 PM
  #257
aaron joy's Avatar
Yes they do, it is called RB "Junior" 9.
Here is the link:
http://www.rb-usa.com/main.php?part=...t&ref=01009-J9
Let me know if you are interested I work at Chick's in Gibbstown, NJ and can get you one since you are local.
aaron joy is offline
Old 04-11-2009 | 12:59 PM
  #258
JUD's Avatar
JUD
Here is the link:
THANKS DUDE!!! I LOVE MY LITTLE RB 3PORT!!!! ITS "THE LITTLE ENGINE THAT COULD".
JUD is offline
Old 04-11-2009 | 04:14 PM
  #259
Ok got my ws9 havent started it as wasnt sure what pipe would fit in the mugen and people wernt being to helpful
But just ordered a RB 2045 192 INLINE and i will make it fit, ang the guy i got engine of and he give me the pipe at 50% of lol.
adz06 is offline
Old 04-11-2009 | 05:22 PM
  #260
Originally Posted by JPMSRacing
I am still looking for a pipe for my C6, the 2045 RB pipe in the buggy class doesnt pass the RC Pro Series stinger size, the stinger is to big, their little gauge thing that is suppose to not fit into the exhaust hole just slides in.
Thats sucks, thats what my setup is. Did they let you run?? What pipe did you run, or what pipe is everyone running besides the 2045.
SPEEDSKI is offline
Old 04-11-2009 | 08:40 PM
  #261
JPMSRacing's Avatar
R/C Tech Elite Member
From: Lost in the Dead Space between my Ears Somewhere around Wamego, KS (OZ Land)
I put on a JP3, but it was legal in the truggy class, I just posted that because we had problems in the past with the stinger size on our buggies. It would suck to drive a several hours to race and then not have a legal pipe. We are looking into a bushing or someway to crimp the end of the stinger this year. As long as their gauge doesnt fit in the end its legal, thats what we where told.
JPMSRacing is offline
Old 04-12-2009 | 01:29 PM
  #262
zonda's Avatar
Questions?? pipe for my RB WS7 iii
Hi, I picked up a WS7 III and dont have much cash for a pipe set.
would this pipe and header run ok with the motor???
Fastrax Off Road Pipe Set Bottom End 053
modelsport.co.uk/?CallFunction=ShowSpecification&ItemID=19808
I dont really want to spend more than that.
p.s its only going to be for club racing
zonda is offline
Old 04-12-2009 | 05:00 PM
  #263
cameronspruill's Avatar
Smile RB ENGINE
I just got an S3 and I really love it.I am new too the nitro scene.How many gallons before it's junk?
cameronspruill is offline
Old 04-12-2009 | 07:03 PM
  #264
castirontom's Avatar
I have a S3 and gots to say it is a great engine its on a o53 pipe and i keep her around 230 on 30 percent o'donnels and man she screems. I wanted to do a os v spec (blue head) but this motor runs with them all day long and it gets better fuel economy. "Very Happy" to own it.
castirontom is offline
Old 04-12-2009 | 09:09 PM
  #265
Does anyone know if i can put the crank , rod piston & sleeve from a s5 in my c6 ? The reason i ask is my c6 needs crank & rod but a guy at the track will make me a deal on the s5 parts so it would be much cheaper to fix. i know it won't have as much power but it would just be a back up engine. thanks
romax is offline
Old 04-13-2009 | 06:34 AM
  #266
aznitronut's Avatar
You can't use the S5 crank in the C6, the S5 crank is 13mm, the C6 is 14mm, this is based on main bearing inside diameter. The rods are all the same, on all the RB .21 engines.
aznitronut is offline
Old 04-13-2009 | 06:36 AM
  #267
aznitronut's Avatar
Depending on your track size, the 053 will give you lots of bottom end, and will top out real fast, might be okay for a small track, the 086 pipe would be a better choice all the way around, IMO.
Old 04-13-2009 | 08:20 AM
  #268
zonda's Avatar
thanks for reply....yeh the track is medium size I would say. I might give that 086 pipe a try, havn't had chance to run my WS7 yet
zonda is offline
Old 04-13-2009 | 09:45 AM
  #269
jameslow's Avatar
Got a few questions about RB ws7ll
- do i need to remove the standard plug shim? bec i find that if i use the plug with the shim, the bottom of the plug cannot sit nicely into the button.
- is there people using 16% for off-road engine? how many shim do i need to shim for this engine if im running 16% and 25%?
Thanks! As this is my first time dealing with off-road engine.
jameslow is offline
Old 04-13-2009 | 10:17 AM
  #270
what_stanger?'s Avatar
If you're talking about the glowplug shim then you leave that in. If it isn't sitting right check that you don't accidentally have two shims there, then check your threads out.
As far as nitro if you're running 25 percent and lower you can run the head/button shims stock at 0.3mm. If your engine has 0.4mm (from the last owner) it would be set up for 30 percent and you could remove 0.1mm of shims to run the lesser nitro fuels that you want to use.
what_stanger? is offline
