RB Concept Engine Thread..
#1906
Hello chris I hope you don't mind me asking you a real quick question. I have a C6 that was givin to me awhile back, and love it, sooo much power, my buddy saw it run and had to get one. my question is on top of his engine it has T7 on top of the C6 on the head, now mine has the same looking C6 but it has something diff on top of the C6 I really couldn't make it out but it not the T7 I see on most of the C6 that run at my track. thanks for your help....
If the cooling heads look the same and it's just different engraving on the top... my guess is yours actually says MSC with a big S over the M and C. The MSC stands for Massive Stiff Case... This is when they moved to the 14x25.8 main bearing from the 25.4 main.
The T7 is the follow-up to the C6 MSC. The T stands for Turbo and it is the first offroad C6 to come with a Turbo plug from the factory. If yours uses standard plugs thats a dead giveaway, but it's possible yours was upgraded to a turbo plug after someone purchased it as well.
They are essentially the same engine, the standard plug will be a bit easier to tune, but will have slightly less power.
#1909
#1915
Absolute hobbyz is the bomb. Ordered at 2045 pipe and header last night around 1. I guess that would be this morning but at 10 this morning I got an email that said it has already shipped. Now that's fast.
#1917
I just bought a WS7 III off a guy on here.so when i out a flywheel on it and turned it i noticed slack in it,so i pulled the backing plate and noticed the rod was loose,this motor still has a metal pinch,so i ordered a new rod,but it didn't fix it.so i guess it needs a crank.do these motors have crank problems.this motor is a CEO MOD
#1918
I will have my new Killer 10 and 2045 pipe in tomorrow to run at the Georgia Championship Series this weekend. It will be my first race with an RB. Ill let everyone know how it goes and what mileage it gets. For the money its hard to beat!
#1919
I bet what you are feeling is some slop at the very top of the stroke when the piston gets stuck. This is normal that it will feel like there is slop. The WS7 has a coating on the crank pin, while it's not a DLC coating I have never worn out a WS7 crank, and I have several with close to 20 gallons of fuel on them. If you don't have calipers to measure the crank pin just pull it out and check the play it has on the rod when out of the engine. If you have calipers the crankpin should measure 5.02mm new, what you are looking for is some egg shaping to the crank so if part of it is 4.98 and part is 5.02 your crankpin is shot.
2Likes
