Like Tree2Likes
RB Concept Engine Thread..
Old 04-12-2012 | 07:46 AM
  #2656
That's what I was hoping for ! Thanks chris !
travertini is offline
Old 04-12-2012 | 01:05 PM
  #2657
aznitronut's Avatar
Originally Posted by jbright33
ok just picked up a k9 for a spare engine came with a 063 pipe. been looking for info but cant seem to find much. is the 063 pipe good match? is this motor a good truggy motor bottom end wise?
They are fast engines, I have one that I have used in truggy, plenty of power, used a 2045/192 RB pipe and header, a friend has the K-10 engine, and used s Losi pipe, the R 12, said it was much better than the RB, and better fuel mileage, I havnt tried that combo yet, but I will soon.
aznitronut is offline
Old 04-12-2012 | 02:35 PM
  #2658
Who sells the RB line of motor C6?
wichitafc98 is offline
Old 04-12-2012 | 03:04 PM
  #2659
aznitronut's Avatar
Amain hobbies sells RB Products, but they no longer make the C6, the RB B11 is the closest engine to the C6.
Old 04-12-2012 | 07:56 PM
  #2660
What is the correct number and thickness of shims for a c6 ?
Old 04-12-2012 | 09:14 PM
  #2661
Original head shims, usable until 25% nitro
Head shim Joint de culasse 0.2mm (1)
Head shim Joint de culasse 0.1mm (2)
0.3mm
Taken from this link
http://www.rbproducts.com/explose/RB...-C6BBIIUSA.pdf
Chris Reilly is offline
Old 04-13-2012 | 08:16 AM
  #2662
Chris Peralta's Avatar
I always thought that was odd the way thats listed. To me that looks like it says (1) .2mm shim and (2) .1mm shims which would actually be .4mm total. I have never had an engine come with 3 total shims tho, they always come with one thick shim and one thin shim to be a total of .3mm. Just make sure you have one thin and one thick.
Chris Peralta is offline
Old 04-13-2012 | 03:21 PM
  #2663
That's exactly what it looks like and is why I was confused ! Thanks again chris !
Old 04-23-2012 | 08:44 PM
  #2664
Amrcr's Avatar
Why is Rb still so hard to get in the states? looking for a good f11 and also a piston and sleeve for a ws9. not much luck finding any. suggestions?
Amrcr is offline
Old 04-23-2012 | 08:50 PM
  #2665
What would the difference in power delivery be on a F11 with a 198mm header and running a 2087 or 2045 pipe?
bartnz is offline
Old 04-24-2012 | 09:49 AM
  #2666
I think I saw Absolute had F11's in stock. As for the WS9 P/S/R you will have to do some searching. Those engines were discontinued so the only parts your gona find are parts that are still out there somewhere.
Old 04-24-2012 | 09:53 AM
  #2667
The power will be very similar. I personally prefer the 2045 between those two pipes.
Old 04-24-2012 | 03:07 PM
  #2668
Lucid's Avatar
whats up with RB lately, everything is out of stock everywhere and they dont even list all the engines on the website?
I have a k9 that im looking to replace, I would like to stay with RB but I dunno whats going on with them lately.
Lucid is offline
Old 04-25-2012 | 01:25 PM
  #2669
Akhor's Avatar
Hey Chris,
I was just checking out AMain looking to purchase a new Fire 11. However the photo of the engine is with the old header pipe connection style. Is this just a photo error? As I assume that all new engines are using the new pipe header twist connection method...
http://www.amainhobbies.com/product_...ipe-Turbo-Plug
Akhor is offline
Old 04-25-2012 | 09:20 PM
  #2670
The old Fire 11 came with the 2087 pipe, as in the link. The new twist style pipe is only available in combo-form with the new BX and BXR afaik..
The Fire 11 is being replaced by the "Fire" sometime this year - again, afaik..
The 2045 and 2087 are still current - the new pipes are just additions to their range, not replacements for it..
Herrsavage is offline
