REEDY .21 Nitro Engine
Old 08-03-2009 | 10:24 PM
  #301
Colt4g63's Avatar
Originally Posted by SkarTisu
Adam, did your mods change the drivability of the engine? My V-Specs always hit like a light switch off the bottom when I tuned them nice and crisp. The Reedy engine has been SO much easier to drive since I've switched over.
Although the engine now has more power down low then stock it still has a very "linear/smooth" feel. It no longer comes on hard and falls off on power so quickly in the higher RPM range.... Which makes it have less of an on and off switch feel.
Colt4g63 is offline
Old 08-03-2009 | 10:27 PM
  #302
Colt4g63's Avatar
double post
Colt4g63 is offline
Old 08-03-2009 | 11:38 PM
  #303
GRANPA 67's Avatar
Cool REEDY21 AIRLEAK?
Just curious, anyone out there who is running the reedy, and has had probs
with airleaks from carby,where it bolts to crankcase? some guy`s here in south oz, have had an issue with this, after purchasing from factory..they
say that the carb insulator does not expand very well, within carb housing, and apparently causes it to leak from this area? Any feedback appreciated.....
GRANPA 67 is offline
Old 08-04-2009 | 01:57 AM
  #304
Bigedmond's Avatar
I just ordered my Reedy, and i am going from GRP's so i should notice a huge bottom change. I am just worried that 2 years of GRP tuning has messed with my head to much.
Bigedmond is offline
Old 08-04-2009 | 06:18 AM
  #305
megasaxon's Avatar
yea you have to seal the carb gasket to the block and the carb to the gasket. I use the Racers edge carb sealant which is just RTV
megasaxon is offline
Old 08-04-2009 | 07:34 AM
  #306
lucky2's Avatar
Default reedy 121
ok guys im sorry to say i have followed everyones posts about this motor, thanks brandon, sealed carb sealed backplate tried to tune her and she just wont keep a tune 97t plug odonnells 30% and its not bad gas speed ran fine with it, two good laps temps hold two more they skyrocket up richen it up temps keep on climbing, richen more temps keep going up. called associated they said send her back, so lets see what happens????
lucky2 is offline
Old 08-04-2009 | 08:44 AM
  #307
megasaxon's Avatar
yea kinda sounds like you got a dud, first one i've heard of. Send it in and i'm sure they'll get you hooked up with a fresh one
Old 08-04-2009 | 08:56 AM
  #308
SkarTisu's Avatar
I wonder if it was super lean on the bottom and fat on the top? Seems like when I've heard of people having trouble like that, the balance of the two needles was way off.
SkarTisu is offline
Old 08-04-2009 | 10:15 AM
  #309
lucky2's Avatar
used brandons needle settings ls and high side but richened them just a bit prob two-three hours on both just too be safe, then started leaning out a little at a time temps only held two three laps then sky rocketed, if i fattened lsn it just kept rising and it still had plenty of smoke, maybe just got a bad one, im not mad shit happens ill call it friday monday motor
lucky2 is offline
Old 08-04-2009 | 10:26 AM
  #310
Bigedmond's Avatar
AE has great customer service, so they should be able to resolve it quickly for you.
Old 08-04-2009 | 12:21 PM
  #311
Brandon Melton's Avatar
lucky2, sorry it didn't work out, they'll get you fixed up. If the carb sealed ok and the backplate,the only other thing it could be is possibly a bearing failure, if the bearing fails, it can suck air, meaning that you can keep fattening it but it leans out through the bearing.
Brandon Melton is offline
Old 08-04-2009 | 05:41 PM
  #312
Brandon, any word word on the Team Edition with the gold head??
SPEEDSKI is offline
Old 08-04-2009 | 05:55 PM
  #313
jamminx2kid's Avatar
+1 i also want to know if there will be a gold head edition mabye it will be a screamer like the os
jamminx2kid is offline
Old 08-04-2009 | 05:58 PM
  #314
I have not heard any word on a release date for that motor.
Old 08-04-2009 | 06:44 PM
  #315
skidooracer's Avatar
jus curious did anyone have any problems with the idle screw backing out on this motor ?
skidooracer is offline
