Trinity EXTECH .21
Old 03-28-2010 | 10:00 AM
  #2026
ScottyM's Avatar
Originally Posted by Ramirez24
This advice comes directly from Team Epic (Trinity): Sirio/ ExTech .21 Nitro Engine
I found this advice really holds true, I have been running Extech Motors for the last 3 years. All there saying is don't always think HSN first, making a small adjustment on Low end will usually bring it back in to tune.
Thanks for clearing that up... I agree a properly tuned top and improperly tuned bottom can cause some run problems.. The engine has to be ballanced..
Thanks for the info on run time.. I guess 9 minutes will have to be good enough.. I'm running sportsman and we only run 15 minute mains at my track so 10 isn't much help, but state series runs 20 minute mains, and that's what i was hoping for..
ScottyM is offline
Old 03-28-2010 | 10:18 AM
  #2027
dishsoap's Avatar
Yep this happened to me yesterday. I needed more power and went with the high. Didnt work. Went back to the original setting I had on the high turned the low and then the high and viola. All the power I could handle.
Oh I forgot to say. Snapped yet another cooling head. I am done searching or using an extech head. I just put a nova head on it and called it a day.
dishsoap is offline
Old 03-28-2010 | 11:00 PM
  #2028
ScottyM's Avatar
Damn I hope I don't have the trouble you have with cooling heads..
ScottyM is offline
Old 03-28-2010 | 11:21 PM
  #2029
Marcus Falconie's Avatar
It looks like you run a bulldog body so you will be good. My motor doesn't even have a scratch on it because the body protects it. And I am loving the Extech .21
Marcus Falconie is offline
Old 03-29-2010 | 04:10 PM
  #2030
my ex tech cooling head broke off yesterday at the end of our 3rd qual...no wrecks either...it just plain snapped off....I put a nova P5xl head on it, so we will see how it cools, but the ex tech heads are most certainly a pos
gtsum is offline
Old 04-01-2010 | 02:51 PM
  #2031
bluer322's Avatar
bluer322 is offline
Old 04-01-2010 | 03:14 PM
  #2032
jmaxey51's Avatar
O'donnell makes some nice cheap cooling heads for them, and you can get them in 5 colors i think.
jmaxey51 is offline
Old 04-01-2010 | 04:19 PM
  #2033
ScottyM's Avatar
I've read this problem on this thread a few times, and honestly it scares me considering I picked up one of the last ones.. It also surproses me, because Trinity heads have always been known for how well they cool.. I hope this is related to a certain batch of engines..
ScottyM is offline
Old 04-01-2010 | 04:31 PM
  #2034
Bruce53's Avatar
Ditto on the cooling head going down front straight made left turn , cooling head kept going straight . Got another from a friend , Time will tell !!!!!!
Bruce53 is offline
Old 04-01-2010 | 04:40 PM
  #2035
mikesd1980's Avatar
@ going down front straight made left turn , cooling head kept going straight Its funny cause I never had this problem and I never heard of it till I read this forum.
mikesd1980 is offline
Old 04-02-2010 | 01:55 AM
  #2036
dishsoap's Avatar
The 2 heads that I have broke so far did not come from jumping or rolling. Both times they were on a straight away.
dishsoap is offline
Old 04-02-2010 | 02:02 AM
  #2037
TIX's Avatar
TIX
if i am running the extec 21 in a truggy am i better off using the 2057 pipe or the baseball bat
also what size restrictor would you recommend
TIX is offline
Old 04-02-2010 | 02:19 AM
  #2038
Teufel Racing's Avatar
Tix,
I usually run the bat pipe just about everywhere and it has become my go to pipe. Some guys have had good luck with others. Not sure on the '57, might work out better.
I usually run the 8mm in the carb and have ran the 7mm, not sure which one is better as I seem to get just about the same ammount of run time with both. Don't think there any smaller ones that fit unless you go to a different carb setup. I could be off on that though as I thought the GRP ones looked like they might fit, but never got around to trying them.
Teufel Racing is offline
Old 04-02-2010 | 07:07 AM
  #2039
Bruce53's Avatar
Happened at Hobby Hut 2 weeks ago .............
Bruce53 is offline
Old 04-02-2010 | 07:46 AM
  #2040
mikesd1980's Avatar
Oh man. I was there that day too but didnt see that.
