Trinity EXTECH .21
#1877
Congrats on the great finish. What size carb restrictor are you using in yours? And what pipe are you running?
#1880
Registered User
Hi, im looking for a new engine for my buggy and since i love sirio i found this one interesting. I already have a sirio 2057 pipe so i'll use that one but should i go with or without the "spacer" between the pipe and the manifold? What difference does it actually make?
And yeah, how does this engine like 25% o'donnel? Would it work just as good as with 30% or should i get some 30% fuel?
/Martin
/Martin
#1881
As I understand it, the extension should give a tad more bottom end repsonse. I choose to not run it only because being in a MBX6, things are tight enough already. It would be tough to get it in, I think. As far as fuel, I've only ever run 30%. I would imagine if you're comfortable with your tuning skills, it would be fine to use 25%, only you might experience very slight temp increases. Ideally, the E.T mills are shimmed for 30% though, so you should also take that into consideration.
#1882
Registered User
Btw, won't i get a bit longer runtime with 25%?
Seems like a great engine but i read earlier in the thread that you should stay away from after run oil be course the silicone could come if you did, is that really true?
#1883
True or not I won't argue, lol. But I can say that I don't use any. Instead, I simply empty my tank at the end of the day, then bump it on the box a few times to burn out the remainder of fuel. Gary from GMK has mentioned that his Afterlife ARO is silicone safe, however, so you would have at least that option. I would stay away from MMM, WD40, and the like. While they may be fine for non ramped crank engines, they will ( in my personal experience ) eat the silicone.
#1884
Okay heres a dumb question. Just dropped the extech into my 8T and need to hook up the throttle servo. the ball isnt lined up. Do I just loosend the screw at the end of the slide pull and rotate to where i need it? sorry for the newb question. this is the first non rtr nitro that i have built.
#1885
That's it man loosen uo the set screw rotate it around and retighten, with a losi you may also need to loosen the carb pinch bolt and turn the carb just a little so that it clears the center diff-just don't overtighten the pinch bolt and you will be golden
#1888
as far as the extech goes you don't need any restrictors for that motor. They have tested that motor and found the 8.0mm restrictor to be the best. I think if you try something thing different you will hurt the performance of the motor. But in case you want to try anyways I have heard the the werks restrictors will work. Me personally, I would leave it alone. I rune the race prep extech .24 and average 9 1/2 min to 10 1/2 min depending on the conditions.
#1890
Werks or Orion Alpha venturies will work in the Extech engines, if you can find them anywhere. A-Main Hobbies had the 7mm Orion Alpha venturies for a little while; not sure whether they still have any in stock.
. Three stops in the 30 min main, I could easily run 8+ mins/tank
