Trinity EXTECH .21
Old 02-08-2010 | 09:43 PM
  #2011
dishsoap's Avatar
Originally Posted by bcrazy
Has anyone had to replace their carb dust boot on their ExTech? If so what did you use. I can't find a Trinity or Sirio one and the Werks one is on back order. Has anyone tried anything else I searched carb boot on this thread and didn't come up with anything.
Thank you
Yes run an OFNA carb boot. Its a tighter fit but it works. I had to put one on mine before a fellow racer sent me a trinity one. The OFNA worked perfect though.
I will get you a link in just a second.
dishsoap is offline
Old 02-08-2010 | 09:46 PM
  #2012
dishsoap's Avatar
Thank you
Here you go. I used this one. The smaller hole is smaller than the trinity one but it works. I used this on mine.
http://www.amainhobbies.com/product_...rotection-Boot
dishsoap is offline
  #2013
bcrazy's Avatar
Thank you. I was looking at the ofna one and thought it might work.
thanks again for your help
bcrazy is offline
Old 02-08-2010 | 10:04 PM
  #2014
bigjayjay1's Avatar
I've been able to find all kinds of parts without getting Trinity involved. I look outside the box
Thanks for your help bigjayjay
just playing around no offence
bigjayjay1 is offline
Old 02-26-2010 | 02:33 PM
  #2015
chevydc44's Avatar
I am looking to get a conrod for this motor but I can't find the trinity one so I was wondering if I can use one from a Sirio or Werks motor and one morwe question what is the size of the front and rear bearings are they standard size thanks
chevydc44 is offline
Old 02-26-2010 | 03:19 PM
  #2016
ScottyM's Avatar
I was told when looking for a rod for a Sirio EVO 4 that the Trinity rod will work fine.. SO I would assume the opposite to be true. The CL7B and Evo4 use the same rod.. WERKS Rod will NOT work.. Crank pin is smaller..
ScottyM is offline
Old 02-26-2010 | 03:21 PM
  #2017
chevydc44's Avatar
OK thanks I will check it out
Old 03-18-2010 | 08:54 AM
  #2018
BoMag's Avatar
any confirmation on the rod?
BoMag is offline
Old 03-18-2010 | 03:09 PM
  #2019
ScottyM's Avatar
Anyone taking advantage of A-Mains discounts on the Trinity Engines?? Think I'm gonna pick one up for my D8 buggy.. I luv the .24 in my D8T...
ScottyM is offline
Old 03-19-2010 | 08:34 PM
  #2020
Teufel Racing's Avatar
They're not too bad of a deal at A-Main.
I was in contact with Trinity and they did get some parts in
They are waiting for the rest. Seems that Sirio had some sort of delay getting parts out and they are slowly comming in.
Teufel Racing is offline
Old 03-27-2010 | 09:03 AM
  #2021
chevydc44's Avatar
Does anybody know what are the stock settings are on the carb for the trinity .21
Old 03-27-2010 | 05:23 PM
  #2022
Trinity Extech .21
Rich setting HSN (Flush with housing 3/4 turn out) LSN (Flush with housing).
Tuned setting HSN (Flush with housing) LSN (Flush then 1/2 turn in).
Tuned idle screw setting (With slide closed, turn idle screw 1 turn in.)
Note: Always tune from the Low speed needle first
Ramirez24 is offline
Old 03-27-2010 | 06:42 PM
  #2023
ScottyM's Avatar
Originally Posted by Ramirez24
Trinity Extech .21
I disagree with the tuning order, because the Low speed is effected by the High needle.. Leanin Low needle then leaning high can caus ea lean condition on the Low side.. But, to each his own..
I have a .21 full mod coming Monday, what kind of run time are you all getting in a buggy? I'm hopin for 10 with a 2057 pipe.. Is it possible? I run the .24 ful mod in Truggy and luv it.. using a JP6 pipe with ti and it works nicely, and I get 12 minutes with it pretty easily..
ScottyM is offline
Old 03-28-2010 | 05:17 AM
  #2024
I've avg'd 9+ with both FM and RP .21/2057 on a mid to large size track.
Couldn't make 10.
NitroOB4You is offline
Old 03-28-2010 | 07:05 AM
  #2025
(MRC) Scotty
This advice comes directly from Team Epic (Trinity): Sirio/ ExTech .21 Nitro Engine
Always tune from the low speed needle first, If your engine does not have enough power,do not continue to lean the HSD.
I found this advice really holds true, I have been running Extech Motors for the last 3 years. All there saying is don't always think HSN first, making a small adjustment on Low end will usually bring it back in to tune.
