Like Tree2Likes
GRP... Engine... Thread...
Old 04-17-2009 | 07:07 AM
  #1351
Originally Posted by jpz_67
It still has a lot of pinch but every time I start the motor up it is pig rich and not making any power. I let the motor warm up, retune the carb until the motor runs good but by the time I run the tank low and come in for a refuel it richens right back up!
I had exactly the same problems with my GRP .21 Tuned. After reading some other forums someone suggested to try a different carburetor which helped him to stop the tuning problems. I used one from my RB S7 and the problems are gone. The engine is running great now en holds it's tune.
ebisschop is offline
Old 04-17-2009 | 09:29 AM
  #1352
jpz_67's Avatar
Thanks for the replies. I will take the motor back to the original settings and retune.
jpz_67 is offline
Old 04-17-2009 | 03:08 PM
  #1353
Make sure you don't let the lid slap shut. That will cause the car to go rich after a fuel stop.
indaway is offline
Old 04-17-2009 | 05:55 PM
  #1354
Toiffel's Avatar
why is that?
Toiffel is offline
Old 04-17-2009 | 06:04 PM
  #1355
rc-mike's Avatar
Yeah, I can see a very quick pressure increase when the lid closes but it should equalize very quickly.
rc-mike is offline
Old 04-17-2009 | 06:28 PM
  #1356
Check the needles on your carb very closely. On my GRP, the o-rings for the low and high speed needles were shot, and the needles were backing out due to engine vibration when the engine was running (causing the motor to run richer and richer). Drove me nuts, till I replaced the o-rings.
glolar is offline
Old 04-17-2009 | 07:38 PM
  #1357
rc-mike's Avatar
I just got to thinking about the mixture changing when refueling problem. Could the fuel temperature have something to do with it? When you are running the exhaust going into the tank could heat up the fuel. When you refill it with cool fuel could it make it run richer? Just thinking out of the box here.
rc-mike is offline
Old 04-18-2009 | 05:49 AM
  #1358
rcracenut's Avatar
Try lengthening the pressure hose. When the fuel gets lower in the tank I looses pressure. Then when you refill, the pressure comes back up making it force more fuel in. Just a thought.
rcracenut is offline
Old 04-18-2009 | 07:06 PM
  #1359
rc-mike's Avatar
That is an idea. I had a helicopter that had that problem. You would have to start out rich to keep it from leaning out too much.
rc-mike is offline
Old 04-18-2009 | 08:16 PM
  #1360
question i have the 086 pipe and 6 mm restrictor in and my track is on the medium to small side there are some guys running tourque pipes on the buggy and get better run up to some of the jumps i keep up just fine but feel the bottom is a little soft for these conditions. if i switch to the 053 will it have more bottom end like the tourque pipe or should i just go with the 007
teamreidy is offline
Old 04-19-2009 | 05:40 AM
  #1361
jyfz2's Avatar
the 053 is the one you will want to run
jyfz2 is offline
Old 04-19-2009 | 06:31 AM
  #1362
rcracenut's Avatar
What is the manufacture of these pipes?
Old 04-19-2009 | 07:09 AM
  #1363
Integra's Avatar
Dynamite.
Integra is offline
Old 04-19-2009 | 09:46 AM
  #1364
Frank L's Avatar
I was having a torque issue with a tuned .21 in my truggy with a dyn 053 pipe. mid was great and top end was not bad, but the low end suffered a little bit. I installed a long RB header and what a difference. I used a long header when I used to run the stock GRP 2053 pipe and that seemed to help it too. The long header and a 053 pipe work great for me in a truggy.
Frank L is offline
Old 04-19-2009 | 10:20 AM
  #1365
rcracenut's Avatar
Who makes the long header? What part number? What about the Ofna pipes?
