Like Tree2Likes
GRP... Engine... Thread...
Old 09-04-2011 | 01:27 PM
  #2101
camocowboy's Avatar
Sounds like a lot of work as cheap as engines are these days. I am running the Ascendancy G5 and it's been great. Price point is pretty nice too.
camocowboy is offline
Old 09-04-2011 | 01:41 PM
  #2102
Ambros303's Avatar
Originally Posted by JC Gascot
I used an ascendancy g5 crank and head and ad the internal components from an old grp tuned that I had witch it broke by where the engine mounts goes ,it works great it is virtually the same crank,now I need a rod and bearing since the compression is still very good but I see there are many option and i like to get the best rod for a grp tunned .21? Can anybody help me with this and tell me wich rod is the best for me? Thanks
That would be a G5 rod as it has a slight update compared to the GRP tuned rod. The lower bushing is made of harder material according to Rody.
Ambros303 is offline
Old 09-04-2011 | 02:53 PM
  #2103
JC Gascot's Avatar
Thumbs up
JC Gascot is offline
Old 09-05-2011 | 04:36 AM
  #2104
shanwright's Avatar
Thumbs up parts for Grp .12 touring Engine
Hey guys where's a good place to get parts for GRP .12 engines?
Thanks.
shanwright is offline
Old 09-05-2011 | 07:46 AM
  #2105
JC Gascot's Avatar
Default G5 conrod
Where can I buy a rod for a g5?
Old 09-05-2011 | 10:10 AM
  #2106
Ambros303's Avatar
If you can't find a G5 rod then you can use a Tecnopower B01 or TQ speedlab .21 rod aswell (same rod as the G5).
Old 09-06-2011 | 12:40 AM
  #2107
JC Gascot's Avatar
Talking Grp rod
Hey ambros I was looking up some of the rods for sale on ebay and omnimodels has a duratax rod that look very close to the grp I know the materials may not be as good but for the price I think is worth triying it, the lenght of it is 37.5mm from top to bottom and 30mm from center of the holes the only problem with it is that does not say the size of the holes I will soon take my engine apart to measure the lenght of my rod an if it is the same I will ask omnimodels for the size of the holes,this may be a cheaper way to go even if it will have to be replace sooner. This rod is only 13.0 dollars shipped
Old 09-06-2011 | 10:21 AM
  #2108
Ambros303's Avatar
The rods have to be the excact same size tho, else you will get timing differences in your engine. The bushings have to be the exact size aswell. For the trouble i'd try and find a GRP tuned, G5, TQ or an TecnoPower B01 rod
A Main has TecnoPower rods if i'm not mistaken
Old 09-06-2011 | 05:17 PM
  #2109
JC Gascot's Avatar
Lightbulb
I know a-main have them but they want 80 for the tecnopower rod thats why I am looking for other options thanks ill let u know I talk to the people at duratrax and they said they will get back with the hole dimensions cause they did not have them at the moment hopefully they come true and they are the same for the money I think is worth trying
Old 09-06-2011 | 07:07 PM
  #2110
Default MR21-BO1A
Evening guys. Anyone know where to get carb needle o-rings for a Ninja MR21-BO1A? I'm also curious if any of the engines, in the Technopower line up, parts are interchangable (bearings and other internals). Any response appreciated. Thanks!
nitroburnt is offline
Old 09-11-2011 | 03:20 PM
  #2111
Default glow plug
witch glow plug would be good for a gpr.28
tripple is offline
Old 11-19-2011 | 09:07 AM
  #2112
Suspended
Anyone have an extra carb or just the carb idle screw they will sell me?
MattP is offline
Old 11-19-2011 | 09:23 AM
  #2113
stallen50's Avatar
you can order the g5 rod from ascendancyrc.com. i dont know how much but jason and nate will take care of ya. both are great guys to deal with
stallen50 is offline
Old 11-19-2011 | 09:41 AM
  #2114
Suspended
I have a guy sending me a carb so no need for one now.
MattP is offline
Old 11-19-2011 | 09:46 AM
  #2115
Tecnopower lsn will fit. You ordered the air screw. That's why they are different. Check the part under b01 u will see they look the same(the one u broke) Hope this helps.
tracktearer is offline
