Like Tree2Likes
GRP... Engine... Thread...
Old 09-01-2008 | 09:26 PM
  #406
Default grp info
this motor is a monster two must do's to get motor full performace. trash the plug it comes with get grp 4-5 plugs and trash the 2053 pipe i use jp3 and it was night and day difference when i switched. everone wants to know how long these motors last well i will tell u this i got mine dasy one when they came out. i am just about to crack open the seal and be on my 7th gallon. with absoltely no problems and on the same grp#4 plug. this motor has not missed a beat yet still as fast as it was after break in. whats even more amazing is i was new to nitro when i got this beast i did the reseach and trail and error when u fist start and still going on gallon seven to me that says somthing. of course i know this motor like the back of my hand now. tip to all new to this motor think oppiste when u tune do bottom first when u go to top just lean it so it clears on the longest stairght on your trak and u will be perfect. my hsn is like is close to being flush with probally a half turn in. my lsn is probally two turns out of the lsn housing
mixedguy is offline
Old 09-01-2008 | 10:07 PM
  #407
Good to hear, im not new to nitro but im definitely no expert on tuning the things ether, My promokit just showed up yesterday so i hope it does as good as yours and better than the leaky deaky V-spec i bought recently.
Hmm i was hoping the 2053 pipe that came with it would be a good match for the engine, since well, it came with the engine, anyhow i have a JP-3 if need be.
Jonro is offline
Old 09-01-2008 | 10:21 PM
  #408
thecman26's Avatar
R/C Tech Elite Member
I know a guy who has an Ofna 053 pipe on his engine and its off the wall!
thecman26 is offline
Old 09-01-2008 | 10:38 PM
  #409
louie_b's Avatar
Default 053 / 9853
I read somewhere the OFNA 053 is the equivalent to the Nova 9853, has anyone used both.. any feedback. thanks.
louie_b is offline
Old 09-02-2008 | 03:04 AM
  #410
I was just looking over my new tuned .21 5 port, it hasn't been installed or run yet, i noticed there is a little less than half a millimetre play in the crankshaft backwards and forwards(into and out-of the engine)? Is this normal?
My V spec with 2 gallons on it has this play but its about 1 whole millimetre, i never checked if it had it when it was new.
Is this normal?
Jonro is offline
Old 09-02-2008 | 03:53 AM
  #411
my engine was the same way, once i put flywheel on it and tightened down the sliding back and fourth goes away
cjm1126 is offline
Old 09-02-2008 | 05:21 AM
  #412
Ah yea that makes perfect sence, thanks.
Jonro is offline
Old 09-04-2008 | 11:38 PM
  #413
Damn rain, got this shiny new GRP engine and pipe sitting in my 8ight that im dieing to break in and rain is on the cards for the next 5 days!
Jonro is offline
Old 09-05-2008 | 03:48 AM
  #414
yea the weather hasnt been good here either, dodging hurricanes at the moment
cjm1126 is offline
Old 09-05-2008 | 03:07 PM
  #415
is it tuesday yet? my GRP tuned .21 engine comes in tuesday.
phixd is offline
Old 09-05-2008 | 06:40 PM
  #416
Gliptal's Avatar
how long are the bearings lasting? I'm going on 5 gallons and all good so far but I'd rather replace them before they fail.
Gliptal is offline
Old 09-05-2008 | 10:27 PM
  #417
my main bearing failed at about 3 1/2-4 gallons and took the whole engine..I would be changing the bearing out if I were you...
I also agree with above...GRP 4 plug, 9853 pipe, and you are good to go with this mill...too bad my bearing ate mine
gtsum is offline
Old 09-06-2008 | 12:24 AM
  #418
Geo Y-Rock's Avatar
+1 with the GRP 4 plugs. Better idle reliability. Best engine I've ever run. I'm curious about the .28 for truggy. I'm thinking the .21 is plenty of power and will get better economy. Has anyone run both in their truggy? I've run both the JP 3 and the GRP pipe with my .21. I was lean bogging on top with the JP3. I think the stock pipe is easier to tune.
Geo Y-Rock is offline
Old 09-06-2008 | 01:08 AM
  #419
Green Machine's Avatar
Just ordering mine now , with the plugs im assumimg they are turbo (conical) ??
Green Machine is offline
Old 09-06-2008 | 08:09 AM
  #420
desertbird's Avatar
yes, turbo head.
desertbird is offline
