Like Tree2Likes
GRP... Engine... Thread...
Old 10-07-2008 | 12:32 PM
  #556
associated is the same as 2035 thunder tiger, 053 is a copy of 9853,they both work well, i prefer the 2035
cjm1126 is offline
Old 10-07-2008 | 12:50 PM
  #557
El Tigre's Avatar
Why do you prefer the 2035?
El Tigre is offline
Old 10-07-2008 | 01:00 PM
  #558
just seemed to have more bottom end power with the pipe, wasnt a huge difference they both work better then the 2053 that comes with the promo kit, if you have a 053 or 9853 allready, go ahead and use it, you will be happy with it, if you are gonna be buying a new pipe you can get the thunder tiger with manifold from amain for 46.99
cjm1126 is offline
Old 10-08-2008 | 04:10 AM
  #559
agressive1's Avatar
I heard that a Hong Nor 2062 go mean on a GRP 21 tuned
Anynews guys?
Are people still running os P3 plugs?
agressive1 is offline
Old 10-08-2008 | 04:49 AM
  #560
El Tigre's Avatar
Got it.
Does anyone know the stock needle settings for a GRP 21 tuned?
El Tigre is offline
Old 10-08-2008 | 08:35 AM
  #561
desertbird's Avatar
HSN 4
LSN 6.5
desertbird is offline
Old 10-09-2008 | 04:38 AM
  #562
El Tigre's Avatar
Originally Posted by desertbird
HSN 4
LSN 6.5
Thanks for trying to help me, but you're way off, especially on the LSN. You numbers didn't sound right so I emailed GRP support in Italy and their reply is below:
"Please return both needles to their original position (all in). Then, turn the low speed needle fully 3,5 times out and the high speed needle 3 times out for .21 engines."
El Tigre is offline
Old 10-09-2008 | 07:17 AM
  #563
That's funny I called Horizon Hobby support and they told me 6 out on HSN and 2.5 out on the LSN. I ignored their advice since that too seemed way off.
slow is offline
Old 10-09-2008 | 07:26 AM
  #564
El Tigre's Avatar
Yeah, I would think that 6 turns on the LSN would bog any engine out there. Normally the stock settings place an engine at a overly rich setting at around 3 1/2 - 4 turns so I know that 6 turns is drowning an engine with fuel.
El Tigre is offline
Old 10-09-2008 | 08:00 AM
  #565
i was told by horizon 4hsn 2.5lsn, it seems like everyone gets a different answer
cjm1126 is offline
Old 10-09-2008 | 10:38 AM
  #566
desertbird's Avatar
I'm running around 5.5 LSN and 3.5 HSN consistently with P3 plug temping around 185 - 190 good smoke excellent power; engine runs great. Sorry my numbers were way off for ya.
Check this out before you start running your LSN too lean. Also, it's always a good thing to use the search feature of this forum you will typically find answers to your questions before you have to ask them...
http://www.rctech.net/forum/nitro-of...ml#post4450579 Start at top of thread
http://www.rctech.net/forum/nitro-of...ml#post4711243 Start at top of thread
Last edited by desertbird; 10-09-2008 at 11:09 AM. Reason: found more info by searching
Old 10-09-2008 | 12:34 PM
  #567
El Tigre's Avatar
I'd forgotten about the search feature. Thanks. I'll check em out.
El Tigre is offline
Old 10-09-2008 | 01:13 PM
  #568
agressive1's Avatar
Is there any point of getting the GRP 21 promo kit because i heard the pipe in them are preety average and that the Hong Nor 2062 is way better.
Should i just buy the engine itself then instead of the whole kit?
Old 10-12-2008 | 03:21 AM
  #569
agressive1's Avatar
just put in 3 tanks in my GRP 21 PROMO. By far one of the easiest engines to run in.
A++++
Old 10-15-2008 | 05:53 AM
  #570
TonysScrews's Avatar
Cleaning up my pit boxes and I have a used GRP Ninja .21 carburetor and cooling head. Anyone interested please email me at [email protected].
Best regards,
TonysScrews is offline
