Like Tree2Likes
GRP... Engine... Thread...
Old 08-05-2008 | 08:24 PM
  #346
desertbird's Avatar
Originally Posted by Nitro$junkie
yer man whats wrong with that ? I always do it on my new motors to find the stock settings, And yes i had the cerb slide all the way open when i did the LSN (Own a Ninja already) wich had the same carb settings aswell
Nothing wrong at all with it, wish I had done that before I went twisting on them.... I searched GRP with no luck is the only reason I asked.
Thanks for posting those! Much appreciated.
desertbird is offline
Old 08-06-2008 | 01:17 AM
  #347
Nitro$junkie's Avatar
Yea man no probs im like you hate trying to find out things later on if i ever have a tuning prob i always like to go back to stock and start again always works for me
How you finding ya GRP how dose she like to run i know me Ninja loves it at about 5 1/2 on the LSN and about 3 1/2 in the high and screams, always temps after a 10min Q at about 120c (248F) thats running 25%Nitro and 12% oil (10%syn & 2% Cast)running a Ninja C6 plug idels all day long and plug last for a few club meets to so hope me new GRP is just as easy to tune and run im hearing about all this flame out issues just want me new engine to run as good as me last she's been a dream coming from Novarossi's which gave me nothing but headaces
Nitro$junkie is offline
Old 08-06-2008 | 06:26 AM
  #348
desertbird's Avatar
My GRP is set exactly what your Ninja liked 5 1/2 LSN 3 1/2 HSN +/- and hour or two. I find I only need small adjustments no more than 3 hrs. I have never had a flame out. My problem is I start temping low as the night goes on, 190ish, running a OS P3 plug in hot ass Arizona. I then start leaning it out to get the temp up and put her into a lean bog. I'm running that ultra hot plug to open up the tuning window, not sure my logic is the best on that, but it's been working; except for how quick I can lean bog when leaning it out.
Old 08-06-2008 | 11:36 AM
  #349
HarleyMf2's Avatar
190 is not bad the last race i was at the pros motors were coming off of a 15 min run at 160
HarleyMf2 is offline
Old 08-06-2008 | 12:16 PM
  #350
desertbird's Avatar
Yeah, next race I'm not going to twist the screws if smoke is good and performance rocks, but temps seem low. My lowest temp was 186, and am concerned that the cooler temp is not good for conrod life. But I also hear this is a cool running motor, so I should probably not try to fix what ain't broke, but I am learning.
Old 08-07-2008 | 03:30 AM
  #351
Shane Racer's Avatar
Those poor motors are going to freeze to death. Lean it out.
Shane Racer is offline
Old 08-07-2008 | 03:28 PM
  #352
FrankBlack's Avatar
One thing i noticed with the grp is when you temp it you have to temp it immediately after the run, the engine will cool significantly cause of the huge head, the temp will drop greatly even in a short time like the walk from the drivers stand to the pits.
FrankBlack is offline
Old 08-07-2008 | 07:45 PM
  #353
my grp likes to run around 230, thats when it gets around 11-12 min run times, i have been running the associated pipe with 6.5 restrictor and p3 plug, really seemed to wake the engine up
cjm1126 is offline
Old 08-09-2008 | 10:37 AM
  #354
Looks like GRP engine users are happy using the OS P3 plugs.
joydude630 is offline
Old 08-10-2008 | 07:59 PM
  #355
1/2 gallon and the bearings are making noise.....? What are the bearing sizes? I want to get some TKOs for it.
Dave.H is offline
Old 08-10-2008 | 08:21 PM
  #356
FrankBlack's Avatar
Front: 7 x 19 x 6mm
Rear: 14 x 25.4 x 6mm
Old 08-14-2008 | 08:12 AM
  #357
Tony899's Avatar
Yea its from Hong Kong but it is the promo kit with pipe here is the link http://shopping.rcmodel.hk/product_i...ducts_id=13053
PS why would i give a US company the bussiness when i can get it else ware way cheaper and by the way im from Australian not America
Are these the same engine as we can get in the US? The picture on the 21 looks correct, but if you look at the GRP 28 on that site, it has a smaller cooling head and the wrong header pictured. So either there are different versions internationally, or they have knock off 28's.
Tony899 is offline
Old 08-14-2008 | 10:08 AM
  #358
LVBaja's Avatar
I would second that about the OS P3 plugs. After reading an earlier page on this thread, I was reluctant to try anything other than the GRP plug, but I gave the OS P3 a try and it works great. I don't have any sealing problems, and it seems to run better all around, from idle all the way up to WOT. I have also run about half a gallon through it and haven't had to change the plug. Tuning was never really a problem, but hasn't become one either with the use of this plug.
LVBaja is offline
Old 08-14-2008 | 04:04 PM
  #359
Has anyone tried the non-tuned GRP? How are they?
Breakin2 is offline
Old 08-15-2008 | 01:52 PM
  #360
Desertbird - Run the motor anywhere between 175-195. As someone already pointed out they have a massive cooling head. Anything too much hotter than that and its too much IMO...
I also run the GRP at the Pit and I always try and run it around 180.
You may want to try the GRP 5 again or try a ODonnell 97T.
ultragraffics is offline
