Like Tree2Likes
GRP... Engine... Thread...
Old 09-22-2008 | 07:08 AM
  #496
schreff's Avatar
Originally Posted by millerdui
about to order a .21 buggy promo kit, What carb inserts come in the promo kit? And which other brand inserts fit the GRP? I will be running a Losi engine in an Associated buggy.....quit laughing
Thanks Guys
The promo kit comes with the 6, 7, and 8mm restrictors. Not sure what other brand ones fit. I use the 7mm restrictor and haven't had a need to try anything else.
schreff is offline
Old 09-22-2008 | 08:29 AM
  #497
Matt M.'s Avatar
Administrator
ninja are identical to grp....
Matt M. is offline
Old 09-22-2008 | 08:30 AM
  #498
Toiffel's Avatar
I replaced my p/s and rod on my ninja .28 with the grp, and perfect fit!!!
Toiffel is offline
Old 09-22-2008 | 01:09 PM
  #499
El Tigre's Avatar
Has anyone ran the buku pipe with the GRP .21.
I need more cowbell!!
El Tigre is offline
Old 09-22-2008 | 08:43 PM
  #500
millerdui's Avatar
thanks for the quick answer....i have a heavy throttle finger and need milage...the 6mm should help me some, I just need more throttle/self control
millerdui is offline
Old 09-22-2008 | 09:28 PM
  #501
Gliptal's Avatar
Mine only came with an 8mm but it was when they first came out. It also came with the #6 plug and I hear the new ones are coming with a #5.
Novarossi restrictors will fit the GRP
Gliptal is offline
Old 09-23-2008 | 01:05 AM
  #502
Well i dont know what the hell to do about this thing, NO MATTER WHAT I DD the carb binds, i almost threw the thing in the bin today after hours of fiddling with it.
Engine is in an 8ight
Ive Tried:
Taking the carb apart checking for burs and rubbing the slide down with scotch brite and greasing it to hell - any heat and the slide binds.
Adjusting this thing every way possible, different length servo arms, different carb rotation positions and different ball linkage positions. No matter how good i get it when its cold - any heat and the slide binds.
Do i buy a new carb and risk the same shit all over again?
Or should i just buy a new kit with a conventional servo tray set-up, i know it wouldn't bind with a normal, straight set-up.
Jonro is offline
Old 09-23-2008 | 01:55 AM
  #503
Ive Tried:
I don't if this is of any help but you could go on the Trinity forum and ask Adam Drake, he might have some tricks which might help. Could be worth a try.
Jesussaves is offline
Old 09-24-2008 | 04:24 PM
  #504
AE
It could be the fuel causing the carb to stick. If the carb is fine when cold, then binds when the motor is warm, chances are it is the fuel. Grab one of your buddies fuel bottle and empty your tank and replace the fuel. start the engine and the problem should go away. I've seen alot of sticky carbs due to bad fuel.
Dyno Dan is offline
Old 09-25-2008 | 08:48 AM
  #505
Does anyone have experience with a JP1 and 2053 pipe on the tuned GRP 21? I'm looking for a strong bottom end. I tried the JP3 and JP1 and I like the JP1 so far. I would like to know if the 2053 pipe would have a stronger bottom end than the JP1.
slow is offline
Old 09-27-2008 | 04:24 PM
  #506
Bad Mika's Avatar
Default GRP tuned .21 buggy engines...
hi, anyone tried out the GRP .21 tuned off-road buggy engines ? ...
it's price is very attractive , includes tuned pipe, engine and free gifts at quite an amazing price compared to other top engines... at the moment.
think Truhe, Battle are using GRP engines as well and have a very strong showing at the Worlds.
thanks
Bad Mika is offline
Old 09-27-2008 | 05:43 PM
  #507
thanks
No none of us have! Where did you find out about these engines?!!1 J/K
Look back through this thread and you will find all that you want to know.
Jonro is offline
Old 09-28-2008 | 08:05 AM
  #508
You would think after all this time, all the kits sold, all they money they have made, all the servos killed and all the complaints received they would have improved the radio tray........
I think ill be switching to ether the 808 or the MBX6, i think ive spent just as much time, if not more messing with the linkage and servos on this 8ight than i have driving it.
I have had 2 Losi 8ights and was very satisfied with the buggy. The Kingheads Radio tray stiffner solved most all of the problems with the Throttle servo's.
Previously I had the XB8, XB8EC, Jammin, MBX5, Turmoil, RC8, and the previously mentioned Losi's. The Losi's Were great until I tried the 808, Hands down the best buggy I have ever drove!! You can drive it hard or soft if you like and the parts dont wear like the Losi.
GRP, for what its worth, If you use a Go or Novarossi standard head button on them, most of the tuning issues go away. You just need to reset/reshim your deck height.
Spdjunky is offline
Old 09-28-2008 | 08:09 AM
  #509
tuning issues go away if you just switch over to a os p3 plug, the grp plugs are tempermental, once they get working good they last a long time, but i found the os plug just works better, makes it much easier to tune and to get the engine to idle
cjm1126 is offline
Old 09-28-2008 | 08:48 AM
  #510
itsshemp's Avatar
Personally, I have not had many tuning issues with my GRP .21 . It has an awsome engine. Mine is going on its 3-4th gallon? and still runs great. I did, however, switch from the GRP #6 (TOO COLD) to the GRP #4, which smoothed out the idle, got rid of the occasional flame out (after refueling). I am now running the OS p-4 plug, and seems to work great. It runs all day @ 180-190 degrees, with tons of power. As far as holding a tune, I find that it normally only needs a tiny tweak of the LSN (within 1-2 hrs) depending on track, but normally is fine.
I have read of some having tuning issues, but I have not experienced any of that, with the exception of the ones I mention. Maybe I have been lucky.
I come from running the Novarossi's (which I still like), but have been SUPER happy with the GRP, so I see another in my future.
Oh yeah, and I run the Jammin JP-3 on it, which it seems to love. On race day, I have gone 8 1/5 minutes with fuel to spare.
Just my experience, anyways.
itsshemp is offline
