Like Tree2Likes
Go-Tech Engines Thread
Old 07-10-2014 | 09:27 PM
  #14641
Originally Posted by Hoese37
Illl be getting one soon here.
Please let us know how it performs.
Bellgate is offline
Old 07-10-2014 | 09:44 PM
  #14642
cczjordan's Avatar
Thumbs up
Originally Posted by Bellgate
Pato Concha is running the Cera in South America. He says it is an "amazing little engine" and he is running it both buggy in truggy and is going to start testing it in 1/8 on road. He mentioned that the Cera was in the car that won the Argentinian national truggy championship last year.
I just received a report about the GXII Plus from a driver that just finished breaking one in. He raced it for the first time last weekend and he said the bottom end was "finicky" with a fine line between rich and lean. He eventually got the tune down and in his words started "hauling the mail." He was pulling the pack down the straights and he wound up qualifying 4th for the Amain. In the Amain he was running in 2nd place when a hole opened up in the carb boot and he started sucking air and that ended his run. In terms of fuel economy he reports he is getting 12 minute run times.
I hope this helps.
thank you for ur info
cczjordan is offline
Old 07-13-2014 | 07:32 AM
  #14643
cczjordan's Avatar
Anyone having issue when swithing fuel, when o swtched from byron to rapicorn, my go engine losses power n flame out for no reason even at rich side. Any advice?
Old 07-13-2014 | 04:07 PM
  #14644
nitroexpress's Avatar
Byron's is a traditional synthetic/caster oil formula. Rapicon uses a completely synthetic oil. You need to retune your engine.
nitroexpress is offline
Old 07-13-2014 | 05:09 PM
  #14645
cczjordan's Avatar
Did retune but it dont have the power of byron
Old 07-13-2014 | 05:16 PM
  #14646
They make a 9% and a 16% oil fuel. Which one you using?
Old 07-13-2014 | 08:34 PM
  #14647
cczjordan's Avatar
Rapicorn 25/9, i'd been using it since last year, maybe 10 gallons already
Old 07-13-2014 | 11:04 PM
  #14648
So why are you asking if its a fuel problem,or have you been dealing with this problem(flameouts)for 10 gallons?
kyosho28 is offline
Old 07-14-2014 | 12:31 AM
  #14649
cczjordan's Avatar
No. Maybe is clutch setup n 7mm venturi. Will try again this weekend
Old 07-14-2014 | 10:45 AM
  #14650
zonda's Avatar
anyone know where I can get a GO 2072 Pipe for my 5 port?
Don't care where in the world it is aslong as they can send it to the uk
zonda is offline
Old 07-14-2014 | 03:46 PM
  #14651
grizz1's Avatar
I have a near new 2072 you can have for NZ$45 plus postage whatever that will be (NZ$45 is around 22 British pounds).
Hopefully you will find one closer to home (as we are about as far apart as you can get on the globe ) - but if you can't, email me at
[email protected] and we will organise something.
grizz1 is offline
Old 07-14-2014 | 07:52 PM
  #14652
cczjordan's Avatar
That pipe is a must have for go engine
Old 07-15-2014 | 09:16 AM
  #14653
cczjordan's Avatar
I looking to buy 7port p/s/c set, is the bottom end comparable to 5 port?
Old 07-15-2014 | 01:23 PM
  #14654
grizz1's Avatar
The 7 Ports still have nice bottom end, but not as strong as the 5 Ports.
The power band is smoother on the 7 Port.
Basically less bottom end torque, but extended top end over the 5 Port. The 7's are a great buggy motor - but can still power a truggy on an open flowing track.
grizz1 is offline
Old 07-15-2014 | 04:17 PM
  #14655
Hoese37's Avatar
Look what showed up today!
Hoese37 is offline
