Like Tree2Likes
Go-Tech Engines Thread
Old 06-28-2014 | 04:00 AM
  #14611
cczjordan's Avatar
Default Byron 25%/9% fuel
Originally Posted by grizz1
Get rid of the .2mm shim. It's a break-in shim, and is only meant to be used for break-in to ease up on the compression (first 12 - 15 tanks).
Running it will be decreasing the compression ratio of the motor.
These motors have a reasonably low compression ratio compared to some others to start with, so you will be losing a lot of power and punch - especially running like this in conjunction with using 25% fuel.
If you want peak performance with reliability and a reasonable tuning window - run the stock factory .5mm shim stack, and run 30% fuel.
These motors love the higher nitro percentage, as it effectively raises the compression ratio, and they really perform.
The .5mm factory shimming is suitable for up to 30% fuel - you don't need to change anything (just get rid of that extra break-in shim).
I took off the .2 shim n run 25%/9% byron. My udp 4port n 5port go become beast. The idle n tuning become better. Drastic temperature drop n crazy power. Will the fuel give enuff protection for engine, is it suitable to use for break in?
cczjordan is offline
Old 06-28-2014 | 02:01 PM
  #14612
grizz1's Avatar
Glad it's working for you
Byrons 25/9 is a good fuel. Fine for run-in, as your running a little rich anyway.
If your not happy, get some Byrons 25/11 and use that for run-in only.
If you want even more performance, just move up to Byrons 30/9. The Taiwanese engines do like the 30%.
grizz1 is offline
Old 06-29-2014 | 03:06 PM
  #14613
22Racer's Avatar
I got some of the Cera engines in, I believe these never made production but very nice. I have them listed on my site.
22Racer is offline
Old 06-30-2014 | 10:22 AM
  #14614
invrtd's Avatar
Just picked up a GXII plus. Took pics of the internals compared to my original GXII. The biggest thing I noticed was intake port is much larger on sleeve on newer motor. I will post picks later.
invrtd is offline
Old 07-02-2014 | 07:58 AM
  #14615
cczjordan's Avatar
Is ARGUS T3 PLUG compatible with GO motor, I'm out of go and os plug
Old 07-02-2014 | 08:05 AM
  #14616
stadiumangt's Avatar
have you done any testing? I would, seeing as how these hit the market, and a few made it overseas, then they were pulled...
stadiumangt is offline
Old 07-02-2014 | 05:36 PM
  #14617
cczjordan's Avatar
Anyone try to put Novarossi carb 24069 into go enjine, my go carb hsn was loose n will lose tune when running
Old 07-02-2014 | 06:32 PM
  #14618
22Racer's Avatar
Yes
22Racer is offline
Old 07-02-2014 | 06:35 PM
  #14619
22Racer's Avatar
They were pulled for marketing reasons not because they didn't work out. Maybe Arrow distributors complained, I have no idea why they pulled it. They have been making the Arrow for quite a while so I know it will run well.
Rex
22Racer is offline
Old 07-05-2014 | 05:07 AM
  #14620
cczjordan's Avatar
Is this enjine totally same as ARROW GTR PLUS? If so the arrow 2103 pipe will be good. Just purchase a unit, guess will get it in a month
Old 07-05-2014 | 07:04 AM
  #14621
invrtd's Avatar
Have about half gallon thru my gxii plus. Taking it okay the track today to see how she does on the dirt. Engine is still tight, so I am sure it will be another 1/4 gallon until it fully breaks in. Just have to learn the tuning techniques with long low speed needle. I ave an original gxii gho with 3 needle carb. I will try the 2 needle carb first to give it a shot. Did run a few tanks in the street to get a basic tune on the engine. I live at 3500 feet. Will be heading to THUNDER ALLLEY close to sea level so I am sure I will need to richer the needles a hair.
invrtd is offline
Old 07-05-2014 | 07:26 PM
  #14622
cczjordan's Avatar
Any info for cera engine? Is the venturi compatible to GO CARB? What is the expected performance?
Old 07-05-2014 | 07:29 PM
  #14623
cczjordan's Avatar
It works n recommended. Easier to tune. But need to factory settings the carb before start your engine. Might need to richen the hsn
Old 07-05-2014 | 08:10 PM
  #14624
22Racer's Avatar
I am not a fan of how the new Nova carbs tune. I do like the 3 needle Go/Arrow/Cera carb, with the needle settings like posted above they run very well.
Rex
22Racer is offline
Old 07-05-2014 | 08:41 PM
  #14625
cczjordan's Avatar
Rex
Had u ran the cera engine? Is it good. I saw in ebay like usd140
