Go-Tech Engines Thread
Are the MG66's still advailable?
I had one a few years back, 045, if I remember right. Loved that engine. But I got sick of replacing the crankshaft every couple of months due to excessive wear, where the clutch bearings ran.
Has that been fix yet?
If it has I would love to get my hands on another.
Yes, MG 66X.21 are still available.
I assume your in Aus ?
Try MassiveMods web site, or MassiveMods Face book page if your on FB
And the wear prob is a self fix, I don't wear shafts any more since been doing this........ put the first clutch bearing on shaft, then a little bit of "Eureka Lube" (comes in a tube) from most repritable hobby shops, then the clutch bell and 2nd bearing.
So the lube is between the 2 bearings.
I'll try and find you a link for the Eureka Lube when I get on my own computer at home. (I'm at work ATM)
Find more info and how to get one (GODZILLA) on FB or contact MAGPIE, as I'm sure he can hook you up, but if you go the Face Book route, there is a deal going ATM for a limited time
Eureka Lube
http://www.ocrpitshop.com.au/index.p...&productId=359
I actualy should get another tube soon, I think I'm low, lucky one of my LHS sells it too
Yep, got it, replied
Any one else been reading this thread ?
http://www.rctech.net/forum/nitro-of...-pitman-8.html
SO FUNNY I had to go to the start and read it all
2Likes
