Like Tree2Likes
Go-Tech Engines Thread
Old 02-01-2011 | 03:42 AM
  #13396
Flanno's Avatar
Flanno is offline
Old 02-01-2011 | 04:55 AM
  #13397
nitrozilla's Avatar
do the piston pins and slide valve have a clear coat o them?
nitrozilla is offline
Old 02-01-2011 | 11:12 AM
  #13398
grizz1's Avatar
Not 100% sure, but I suspect so. Whatever was TiNi coated on the GX would most likely be clear coated on the GXII. Massive or Trey may be able to give you a definite answer though.
grizz1 is offline
Old 02-01-2011 | 11:26 AM
  #13399
Ruune's Avatar
I'm going to assume yes, but I will have to verify. I've had some reports of non-smooth throttle slides on the GX, but they were on the older models. Machining on the throttle slide movement was something that I asked them to pay special attention to- I'm just obsessive about mechanical stuff like that.
Ruune is offline
Old 02-01-2011 | 08:54 PM
  #13400
MassiveMods's Avatar
Hey All Official list of changes put forward that got through
9 Fin 2 Piece head with new styling ( retrofittable ) MM without top hat thank the lord ...
Sleve re design and timing change ( Retrofittable ) MM/S/Go
New HSN Metering angle MM ( Retrofittable )
New Anodised alloy Pinch Bolts MM/S/Go ( Retrofittable )
Poly Filled crank as standard S ( Retrofittable )
New Crank Case and Material S / Go
There is no coating on the crank. Its bare metal.
Things that did not make it
New G Clip Design
New Inlet timing change
New Rod Material
Cheers MM
MassiveMods is offline
Old 02-01-2011 | 09:19 PM
  #13401
deadmancourt's Avatar
New G Clip Design
New Rod Material
Cheers MM
no coating on the crank at all...i thought it was going to be a clear coating?
deadmancourt is offline
Old 02-01-2011 | 09:38 PM
  #13402
Thanks for the real info on the new engines.
I was hoping for a totally new designed carb.
But I never thought that they would go back-
wards with the crank refinements too.
rageworks is offline
Old 02-01-2011 | 09:46 PM
  #13403
its not backwards....its a WHOLE new crank...i bet the material is different and thats why it needs NO coating....
Old 02-01-2011 | 10:02 PM
  #13404
Until I know for sure, I wont be bettin on it.
Don't get me wrong, I like the GO engines
that I own. GO had the time to come out
with a newly designed engine that would
be a cut above the rest of the other engines
in it's price market, but now I just don't
see where they have.
Like I said on the other GO thread, only
time will tell.
Old 02-01-2011 | 10:17 PM
  #13405
AlanHall's Avatar
Thought you guys were killing the "go tech" post
AlanHall is offline
Old 02-01-2011 | 10:26 PM
  #13406
no not KILL it...was just hoping to get rid of the TECH part...but this thread IS and ALWAYS WILL be the OFFICIAL GO ENGINES thread for ALL Go Engine users
Old 02-01-2011 | 10:36 PM
  #13407
grizz1's Avatar
Post deleted. There is no point in trying to talk sense to some people.
grizz1 is offline
Old 02-01-2011 | 10:46 PM
  #13408
rider313's Avatar
you could say that again.
rider313 is offline
Old 02-01-2011 | 11:17 PM
  #13409
MAGPIE-121's Avatar
some people just don't get it, don't know why they bother coming on here
MAGPIE-121 is offline
Old 02-02-2011 | 03:06 AM
  #13410
Flanno's Avatar
9 Fin 2 Piece head with new styling ( retrofittable ) MM without top hat* thank the lord ...
New G Clip Design
New Rod Material
Cheers MM
Does that mean the finned button can be used with the MG head ?
or
the new finned button and new head fits the MG ?
or
the new head fits the old button ?
Flanno is offline
