Like Tree2Likes
Go-Tech Engines Thread
Old 01-04-2011 | 04:20 PM
  #13306
motomatt's Avatar
I guess that disproves some of those "$200 engines only last 2 gallons" posts.
motomatt is offline
Old 01-04-2011 | 05:21 PM
  #13307
bigmatt's Avatar
Originally Posted by newuserlosi8t
yes only a main has touched it shows no wear at all great fuel
Hi,mike sent me a gallon out of the very first mix[25%] engine ran like crap. We figured that maybe to much oil got in it. What % are you running?
bigmatt is offline
Old 01-04-2011 | 05:47 PM
  #13308
newuserlosi8t's Avatar
30% stuff runs great
newuserlosi8t is offline
Old 01-05-2011 | 12:13 PM
  #13309
MassiveMods's Avatar
FYI the GX 2 HO will be coming out with the original carb. Go Have followed suit with me. We will however be going with my Needle taper design to make the GX/MG carb easier to tune. The Metering of the HSN in particular will be changed to give a less sensitive HSN needle.
We may introduce the new carb at a later date.
Thanks for listening
MM
MassiveMods is offline
Old 01-05-2011 | 12:29 PM
  #13310
GoEngineUSA's Avatar
MM
Correct- They are still working on the 3-needle. The initial GXII carb will feature a longer LSN and a smoother throttle slide.
Mark- Is the new HSN the same taper as the double sealed HSN on the GX series? Here in the US, I believe we changed midyear to the less sensitive version.
GoEngineUSA is offline
Old 01-05-2011 | 01:10 PM
  #13311
All Carbs will be changed to the new HSN design remaining with double sealed HSN . All carbs are identicle world wide. The HSN Change that i suggested last year never took place. Its about to with the new carb for 2011
I have recommended against changing the LSN needle and only changing the HSN for the new HO.
the MG66X will only have a HSN needle change. If Go Follows suit for the HO im not sure at this stage.
Cheers MM
Old 01-05-2011 | 03:50 PM
  #13312
MAGPIE-121's Avatar
can't wait to have a look at the GX 2 HO in the flesh
MAGPIE-121 is offline
Old 01-05-2011 | 04:56 PM
  #13313
bigmatt's Avatar
Trey, do you have any of those double sealed hsn's? along with the seals. I need 3
bigmatt is offline
Old 01-05-2011 | 06:06 PM
  #13314
grizz1's Avatar
MM
Thanks for that Mark. I am actually quite releived to hear that. I wasn't really looking forward to introducing a new 3 needle type carb onto my customers, especially since we are having so much success with the current GX long needle version on both the GX and MG motors.
These carbs are so easy to tune now we have the "long needle education programe" in place and working well around the globe .
Having said that the re-tapered needles will be a nice improvement on an already good carb.
I run the MM re-tapered needles in my MG66 and it certainly improves the tuning window, especially with the HSN not being quite so sensitive.
Looking forward to the release of the new mill with great enthusiasim
grizz1 is offline
Old 01-05-2011 | 07:50 PM
  #13315
deadmancourt's Avatar
yes sir...i personally think the present carb is great....i will run the 2 needle carb through the life of my GXII 5RHO.....so far the pics of it that max posted look like a great change for Go Engines....cant wait
deadmancourt is offline
Old 01-05-2011 | 08:34 PM
  #13316
grizz1's Avatar
Should be some detailed pictures to post up on here soon. They are in the process of taking some promotional pics with the motor as it will be released (new motor with GX carb), so there is no confusion in the customers mind as to what they will be getting.
Great result for the new motor in China. The meeting that Max Chen posted the photos from was I believe the first public debut of the new motor.
They ran the motor with the GX carb and new needles (same package that will be released onto the market). Got TQ and 1 - 2 - 3 on the podium. Not a bad first outing
Makes the wait even harder
grizz1 is offline
Old 01-05-2011 | 08:35 PM
  #13317
Flanno's Avatar
+1
Flanno is offline
Old 01-05-2011 | 08:39 PM
  #13318
thats what im talking about....cant wait..its killing me
Old 01-05-2011 | 09:17 PM
  #13319
motomatt's Avatar
Everything takes time young grasshopper.
Patience is a Virtue. (it's the only one I have )
motomatt is offline
Old 01-14-2011 | 05:40 AM
  #13320
Tigergutt is offline
