Like Tree2Likes
Go-Tech Engines Thread
Old 10-13-2010 | 10:07 AM
  #12346
Gizmatron's Avatar
Originally Posted by grizz1
Hi Alex, the run time thing has a lot of variables. Track surface (amount of dust and wheelspin), fuel type, ambient conditions, tuning, and a quite throttle finger are the main culprits
If your on a dusty track with a 7mm restrictor your times are probably not too far off. Your needle settings sound about right for the long needle carb (which you will have seeing the motor was purchased in China)
In the summertime when our track is pretty dusty and slippery anything over 9 mins with the 2072 pipe and 7mm restrictor is pretty good for me (I don't run my motors on the limit as a rule, so I am probably a little down on some others run times).
The only way I get 10 min on our local tracks with normal ambient conditions is with a 6.5 restrictor and 086 pipe. The bottom end punch is a little less than the 2072, but run time is much improved.
I have tried the 086 on the 3R, 5R and MG66, but not on the 7 Port. With the top end on the 7 Port and the high end 086 pipe it might be a sweet combo.
I know some guys are getting over 10 min in buggy and around 12 - 13 min in truggy, so hopefully they will pop up on here and reveal their secrets
Grizz1 is right...8.5 minutes is around average.I run MG66 7mm restrictor with .4mm shim stack and 2072 pipe and I get 9m10 if I go insane but I can easily stretch that to 11m30 if I use a smoother throttle finger.Full race tune and ceramic bearings and my best ever runs were in the 12m10 to 12m20 range.These kind of run times though really really depend on smooth driving and no wheelspin.On very dusty or slippery tracks you are never going to see those kind of times.blipping the throttle and just yanking it to max at the beginning of every straight will soon burn up fuel.The easiest place to gain runtime is accelerating down the long straights.Just don't pull throttle straight to max but increase gradually it as you speed up. You'll find you don't go any slower but you burn way less fuel.
ps I also run a cnc head which loses me an extra 15ºC -20ºC of temp so I can afford to get my motor a hair on the lean side at race tune.
Gizmatron is offline
Old 10-13-2010 | 03:38 PM
  #12347
MassiveMods's Avatar
MG66 First National title !
Very Happy chappy !
thanks Gerry Davis for showing the true colours of the MG and Shane " Grizz " Adams for running an awesome race team in NZ !
Take a bow
http://www.buggy-sport.info/index.ph...fo+%2F+News%29
Cheers MM
www.massivemods.com.au
MassiveMods is offline
Old 10-13-2010 | 03:44 PM
  #12348
deadmancourt's Avatar
Very Happy chappy !
Take a bow
Cheers MM
NICEGO get em....is there gonna be any GO engines in the WORLDS race in THAILAND?
deadmancourt is offline
Old 10-13-2010 | 04:20 PM
  #12349
YEP ! plenty of Go engine at the worlds ! and the MG is going to run the Worlds too ! I believe the Malaysian National Champion and the New Zeland National Champion .
VERY EXCITED !
Old 10-13-2010 | 05:38 PM
  #12350
grizz1's Avatar
Nice race report
Jerry played down the tyre issue somewhat. The fact of the matter was he managed to stay ahead of the entire field for nearly 30 mins with the left rear tyre hanging off the rim (which put a few more gray hairs on my head I can tell you). A quick pit stop and Forumula One style tyre change saw him pull away once he had 4 good wheels on the track again
It certainly topped of a great year for the Massive Mods MG66 and GO engines in NZ, with wins in every major event except one, where we took a 3rd place podium. A big thanks must go to Massive and his team on the other side of the Tasman for their support and technical back up. Cheers Mark and Co
grizz1 is offline
Old 10-13-2010 | 07:07 PM
  #12351
max_chen's Avatar
VERY EXCITED !
I think you can.
max_chen is offline
Old 10-13-2010 | 11:24 PM
  #12352
can you get there names?....i would like to follow up on them....
Old 10-14-2010 | 12:01 AM
  #12353
grizz1's Avatar
NZ Champ running MG66 is Jerry Davis (X-Ray 808 10 Spec)
To be honest the NZ boys going over (NZ ranked 1-2-3) will be pretty out of their depth at that level. We just don't get the competition here, nor do we have tracks like that to race or practice on. I see the big shots have been practicing at the track for the last few weeks, and will probably continue to do so right up the the event. Our boys will off the plane, jet lagged, straight onto an unfamiliar track. I think all 3 guys have a goal of finishing inside the top 100, which is pretty realistic when consider what they are up against.
Whatever happens it will be a great showing for the Massive Mods MG66 and the GO motors.
grizz1 is offline
Old 10-14-2010 | 12:12 AM
  #12354
hell yeah!...i wish them all the BEST LUCK!...is there any body running the GX motors?....i mean what are their names lol
Old 10-14-2010 | 07:24 AM
  #12355
guntek18's Avatar
guys"
i own a gx-7r and i love it.
i was thinking to go with gx-5r , next time.
i have a chance to buy a used 5.5 , what is it?
is that a sport model .21 or a 5r equivilant??
guntek18 is offline
Old 10-14-2010 | 07:36 AM
  #12356
MAGPIE-121's Avatar
Originally Posted by guntek18
guys"
it's the GX,
MAGPIE-121 is offline
Old 10-14-2010 | 09:39 AM
  #12357
Ruune's Avatar
Originally Posted by MAGPIE-121
it's the model before the GX, stick to the GX IMO (better cooling head, carby & seals)
Yes... the GX series have a number of improvements over the gen 5.5... including different porting, coated crank, coated throttle slide, coated wristpin, and a lighter conrod. This is in addition to the carb, seals, etc.
Ruune is offline
Old 10-14-2010 | 01:40 PM
  #12358
guntek18's Avatar
same engine case or not ??
guntek18 is offline
Old 10-14-2010 | 02:02 PM
  #12359
Ruune's Avatar
casting is the same, yes.
Ruune is offline
Old 10-14-2010 | 03:26 PM
  #12360
Suspended
got the goodies today RUNNE, thanks alot! but......no stickers? JEEEEEEZE!!! lol, just kiddin! thanks again!!!!
inferno13 is offline
