Like Tree2Likes
Go-Tech Engines Thread
Old 10-11-2010 | 06:21 PM
  #12331
Diegoli's Avatar
In my GX-7R (bought in China), I'm running at idle gap 0.7mm, 0.5 turns HSN, LSN 2 turns, 7mm restrictor, 100 degrees(C) and go2072 pipe. I can not more than 8.5 minutes of the tank.
Fuel Byron 25% - 4 shimm - OD97T
XRay 808, 17T clutch bell
Sorry my bad English!
____________________
Alex Diegoli
BRAZIL
Diegoli is offline
Old 10-11-2010 | 07:58 PM
  #12332
grizz1's Avatar
Alex Diegoli
BRAZIL
Hi Alex, the run time thing has a lot of variables. Track surface (amount of dust and wheelspin), fuel type, ambient conditions, tuning, and a quite throttle finger are the main culprits
If your on a dusty track with a 7mm restrictor your times are probably not too far off. Your needle settings sound about right for the long needle carb (which you will have seeing the motor was purchased in China)
In the summertime when our track is pretty dusty and slippery anything over 9 mins with the 2072 pipe and 7mm restrictor is pretty good for me (I don't run my motors on the limit as a rule, so I am probably a little down on some others run times).
The only way I get 10 min on our local tracks with normal ambient conditions is with a 6.5 restrictor and 086 pipe. The bottom end punch is a little less than the 2072, but run time is much improved.
I have tried the 086 on the 3R, 5R and MG66, but not on the 7 Port. With the top end on the 7 Port and the high end 086 pipe it might be a sweet combo.
With the 2072 pipe, try running the 6.5 restrictor and going down to .4mm of head shims (remove 1 x thin copper .1mm shim - leaving 1 x .3mm alloy and 1 x thin .1mm copper). This should give you a little extra run time.
I know some guys are getting over 10 min in buggy and around 12 - 13 min in truggy, so hopefully they will pop up on here and reveal their secrets
grizz1 is offline
Old 10-11-2010 | 08:57 PM
  #12333
deadmancourt's Avatar
Originally Posted by rodcpierce
Its a RUNNE problem, not a USPS problem... I hope this doesnt turn into a pattern, that would be a bad thing.
HE IS A VERY BUSY GUY!...AND GO ENGINES ARE GETTING BIGGER SO HE HAS ALOT OF PEOPLE TO TAKE CARE OF BIENG ONLY 1 GUY....HE WILL TAKE CARE OF YOU FOR SURE!
deadmancourt is offline
Old 10-11-2010 | 09:02 PM
  #12334
Suspended
THEY ARE ON THE WAY, I DONT NEED THEM NOW UNTILL MAY 9TH OF 2011 BUT ATLEAST I WILL HAVE THEM! whats with the caps?!?!?!
inferno13 is offline
Old 10-11-2010 | 11:29 PM
  #12335
MAGPIE-121's Avatar
HE'S DEAF !
MAGPIE-121 is offline
Old 10-11-2010 | 11:50 PM
  #12336
Ruune's Avatar
hey... as I stated in the email, I entered your zip code wrong and UPS neglected to notify me they couldnt deliver. I did send you another setup w/ the long LSN as requested.
Ruune is offline
Old 10-12-2010 | 02:33 AM
  #12337
Flanno's Avatar
For any of you guys in the states that are interested.
FastLane graphix has all the logo's in my avatar on file.
MassiveMods MG66
AmainFuels the power to perform
GoEngines
AnswerRC
AKA
Flanno is offline
Old 10-12-2010 | 07:25 AM
  #12338
Suspended
ok thanks, but did not receive a email
Old 10-12-2010 | 08:21 AM
  #12339
Ruune's Avatar
ok... I just resent the email with the UPS tracking number to the same address you emailed me from.
Ruune is offline
Old 10-12-2010 | 12:59 PM
  #12340
MAGPIE-121's Avatar
Old 10-12-2010 | 01:01 PM
  #12341
MAGPIE-121's Avatar
IMAGIAN THAT! just got a email with ups shipping information. ill have them thursday. thanks to whoever is sending them!! lol
Old 10-12-2010 | 06:41 PM
  #12342
Suspended
thanks RUNNE! i got the email with tracking, i just dint the message you wrote with it. i got it this time!
Old 10-12-2010 | 06:44 PM
  #12343
Ruune's Avatar
no problem bro... let us know how you like that LSN!
Ruune is offline
Old 10-12-2010 | 06:50 PM
  #12344
Ruune's Avatar
MassiveMods MG66
GoEngines
AnswerRC
AKA
yeah I can definitely vouch for FLG. Chad Brosseau does some maad work!!
Ruune is offline
Old 10-12-2010 | 10:56 PM
  #12345
dude those things are sick!!!....i just got on the UPGRADE RC team so im gonna start running there wraps....plus they are local..but FASTLANE GRAPHIX deffinently does GREAT work!....
