Like Tree2Likes
Go-Tech Engines Thread
Old 08-05-2010 | 07:53 PM
  #11356
bigmatt's Avatar
Originally Posted by deadmancourt
what pipe do you guys recomend for the gx-5r?....i have a jp-4,is this a good pipe for these motors?
dynamite 086
bigmatt is offline
Old 08-05-2010 | 07:56 PM
  #11357
deadmancourt's Avatar
oh yeah,and i run TRUGGY!....seems like the dynamite 086 is the all around pipe!
deadmancourt is offline
Old 08-05-2010 | 08:01 PM
  #11358
Suspended
086 is a top end pipe, also if you do run a 086, use a u shaped header, not the ] shaped header.
inferno13 is offline
Old 08-05-2010 | 08:47 PM
  #11359
jwm2's Avatar
Screw came out easily enough. Now i have another issue. I took the carb off and noticed alittle irregularity just inside the bottom of the carb. There was a little chunk of plastic sticking out, or some of the plastic was dug into. Anyhow i took my dremel to make it smooth with a buffing pad but that didn't do any good. Instead of polishing the inside it actually scuffed it up. I was using the softest pad i had to buff it but somehow it just scuffed up the entire inside of the carb, the bottom 1/4" is like this. Anyhow i have no idea how thats going to affect performace. I guess i'll just spend the $35 and get a new carb :/
jwm2 is offline
Old 08-06-2010 | 04:51 AM
  #11360
motomatt's Avatar
motomatt is offline
Old 08-06-2010 | 05:11 AM
  #11361
Well . really I10 with Kappa will be better than any small car .If you have extra bucks look for i 20 .Ritz is a failure model .
Adem Stival is offline
Old 08-06-2010 | 06:33 AM
  #11362
hobdog's Avatar
I have a older 5 port, I believe that I have been told it is a gen 5 with the black case with a silver head without the fancy design on the top of the head. Where can a guy find a new rod to work with this? I noticed when I pulled it apart that the crank pin and rod have a bit of slop between them, and for the price of the go rods I figured I would just change it. Also what would be the recommended plug to use in it? It's a turbo head, but I think I might be having a problem with the button so if you could reccommend a turbo plug and a standard I would appriciate it. Thanks
hobdog is offline
Old 08-06-2010 | 03:32 PM
  #11363
MassiveMods's Avatar
Hey Hodog
to be able to check what part has the slop in it we would have to measure the components. Regardless if you want to revive that Gen 5 you would be best off getting a new crank and rod as they would be a matched pair. The Gen 5.5 GX Crank and Rod will work in that Gen 5 no probs.
Have a look for your local Go Dealer for parts, Part numbers you need are
Crank 21-0907T-03
Rod 21-0600
www.massivemods.com.au
MassiveMods is offline
Old 08-06-2010 | 03:41 PM
  #11364
MAGPIE-121's Avatar
hey mark, is it the MG66 birthday
MAGPIE-121 is offline
Old 08-06-2010 | 03:52 PM
  #11365
MAGPIE-121's Avatar
i haven't run the dynamite 086 pipe but the 7072 ripes on the GO motors
Old 08-06-2010 | 05:51 PM
  #11366
one last question,...are these motors just a little louder than normal?....this thing sounds like a nova with bad bearings! lol....is this normal?...other than that these motors are the shit!...gx-5r pulls like a tractor!
Old 08-07-2010 | 02:59 PM
  #11367
MAGPIE-121's Avatar
LOL nova with a bad attitude
Old 08-07-2010 | 06:30 PM
  #11368
yes it is matey ! Happy B day MG66 ! 21 to day lol
Yes its already been 1 year since the release of the MG66 in August 2009 and since we have sold over 500 units and had incredible user feedback to critical acclaim ! Its a top little motor and we are proud of its achievements and indeed the race drivers that run the engine and bring it over the line to victory so many times !
Happy B Day MG 66 ! and thank you for your support !
Mark De Berard
source
MassiveMods Australia
Old 08-07-2010 | 11:28 PM
  #11369
so is that a yes?...i dont want to keep running it if it needs new bearings!....when the bearings go out,its usually a reaaallly high pitch squeel? or does it start squeeling alittle then gets higher pitch as it gets worse?...or do these just naturally sound like this?....i looked up these motors on youtube and they all sound kind of like this but hard to tell on youtube!
Old 08-08-2010 | 06:25 AM
  #11370
Stalkie's Avatar
Hey Magpie, I will have to get one of them 7072 pipes to try:lol
Dont forget the good old 0801 pipe the wife has one on her GX5 with a GO T6 plug in her Truggy and you have seen the run time she gets.
DEADMANCOURT: IMO I think the GOs have a sound of there own and with mine I would say the 0801 pipe sounds a bit louder than the 2072
Stalkie is offline
