Like Tree2Likes
Go-Tech Engines Thread
Old 07-24-2010 | 12:45 AM
  #11206
Gizmatron's Avatar
well that was fun..trying to post here i crashed first opera then my computer and have now lost 5 years of R/C bookmarks.... all those useful sites I found gone..shit
oh well I had a great weekend anyway and after a few weeks of slightly disappointing performance from my MG66 (nothing major just not as snappy as it should be..I was thinking it was just needing to loosen up the new piston set a bit) spotted the nipples on each end of my exhaust line cooler had unscrewed and so I was getting a tiny intermittent air leak..spot of tightening and a bit of threadlock and bingo..rocket ship back again...
Gizmatron is offline
Old 07-24-2010 | 05:15 AM
  #11207
Originally Posted by MAGPIE-121
http://www.amainhobbies.com/product_...bo-Glow-Plug-1
they have them in stock as i bought 8 yesterday $4.99 each
are u getting any leakage around your carby boot on the slide ? a pin hole will do it !
10 out of 10,
found a pinhole in the carb boot, thanks a million i would of never thought of looking there, tick over now normal again, just the tuning now.
kevinjh is offline
Old 07-24-2010 | 07:50 AM
  #11208
hey guys,i just checked my engine this afternoon and found out that i can easily turn the flywheel on my engine by 1 finger with less resistance COMING on TDC,the engine has approx. 2 and a half gallons on it,is this a sign of having low compression?but the engine still performs well.
jeremiah23 is offline
Old 07-24-2010 | 09:40 AM
  #11209
jwm2's Avatar
You can have it repinched for pretty cheap. 22racer on here does them for $37 return shipping included. I just sent in an engine to him this week. Hes also got a bunch of parts so if anything needs to be replaced he can do it for you.
jwm2 is offline
Old 07-24-2010 | 04:13 PM
  #11210
qcrc's Avatar
I run the 3PT Race motor and it is in dire need a new conrod. Is there anywhere that has them in stock? Thanks.
qcrc is offline
Old 07-24-2010 | 06:03 PM
  #11211
MAGPIE-121's Avatar
Motomatt on here is a GO dealer, he will look after u, just send him a PM
MAGPIE-121 is offline
Old 07-24-2010 | 06:05 PM
  #11212
jeff_ellis_9's Avatar
What plug for a GO 5 port thats been modded by RB mods? I got it in a trade and trying to figure out what plug to use. He said he used Ultra Hot plugs but didnt specify what brand. Would this be the O.S. P3 plug? He did say it used a turbo plug
thanks
jeff_ellis_9 is offline
Old 07-24-2010 | 07:00 PM
  #11213
Redvet79's Avatar
Novarossi Ultra Conical "Turbo" Glow Plug Hot C6TGC
This is what rick has me run in my GX-7R
Redvet79 is offline
Old 07-24-2010 | 09:18 PM
  #11214
would plugs from OD or OS work?
if so, which ones?
Old 07-24-2010 | 09:19 PM
  #11215
BSchorr's Avatar
R/C Tech Elite Member
Odonell 97T bud.
BSchorr is offline
Old 07-24-2010 | 10:19 PM
  #11216
boxhead's Avatar
Just realised I may have that backward re the oil in diff.
boxhead is offline
Old 07-24-2010 | 10:52 PM
  #11217
MAGPIE-121's Avatar
thanks
o'donnell 97T for me long life & great value at the price
Old 07-24-2010 | 11:33 PM
  #11218
grizz1's Avatar
+1 on the 97T. The GO motors seem to really like these plugs, and value for money they can't be beaten.
grizz1 is offline
Old 07-25-2010 | 12:14 AM
  #11219
808gx7r's Avatar
just had a full day out. after 21 continous tanks... flamed once... temp 170F after last tank. had awesome power + a screaming top end motor: gx7r pipe combo.
808gx7r is offline
Old 07-25-2010 | 05:04 PM
  #11220
Suspended
ok, still have the lean issuse with the go 3 portr21, changed, tank, all gas and presure lines, sealed back plate and carb, changed plug, changed pipe to 086, and still have a lean issue, after running for about 5 minutes, give it full throttle and it cuts out untill i let up alittle and eventionaly will take off, it is not a tuning issue. i have tryed everything and is the same as it was before i changed everything, starting to get frustrated a bit. will a nova carb fit on this? if so i will try to see if that makes a differnce, any help would be great!!!
inferno13 is offline
