Like Tree2Likes
Go-Tech Engines Thread
Old 03-26-2010 | 06:16 PM
  #10336
Originally Posted by grizz1
Remember - if you lean the top end needle you are also effectivly leaning the bottom end needle at the same time.
You say you set the bottom end right, then went and leaned the top end some. If you don't go back and richen the bottom end again to compensate, you will end up with a lean bottom end and lean bog.
Also - just very small adjustments at a time. No more than 1/8 of a turn at a time, or you could miss the tuning sweet spot and be chasing your tail all day for a tune.
What your describing also sounds like a rich bottom end disguising a wide idle gap - resulting in a way too lean top end. This will cause the motor to run OK, but it will run cool, then start lean bogging at around half a tank, then run really lean as the tank runs out. It's a classic mistake, made by pretty much every RC gas racer at some time during their learning curve. It's hard to pick because the motor will actually run not too bad, but nowhere near it's full potential.
Check that idle gap by pinching the fuel tubing off about 1" back from the fuel nipple when the motor has just started, before it gets too warm. If the idle comes up quite high, your idle gap is too big. Reduce it and pinch test again until the revs only rise up very slightly. This indicates a correct idle gap for your motor. If the engine won't idle for long at this setting, lean the botton end - DO NOT ADJUST THE IDLE GAP. Now tune bottom end, then top end, then re visit the bottom end if you made big adjustments to the top end needle. You should now have a ballpark tune. Fine tune from here.
Grizz1, when I had the engine behaving the way it should, not lean bogging, bottom set correctly, I had no top end. I was getting humiliated down the straight. To get some top end I leaned the top end then the lean bogging starts.
Ideal gap is 0.5-0.7, to me that sufficient? Isn't it?
I’ll go and try out now. Richer on top and lean out the bottom end.
Does the pinch have anything do with the behaviour of this engine? That's why I asked the question if it would be ok to but heat gun get it really hot to get some pinch out?
Thanks for your help. Get ready for NZ 7’s team to beaten tomorrow in Hong Kong.
Jesussaves is offline
Old 03-26-2010 | 06:59 PM
  #10337
chevydc44's Avatar
I have a go motor that i got from a friend it's like a couple years old can i put the new internals from the new go motors in that case
chevydc44 is offline
Old 03-26-2010 | 07:55 PM
  #10338
MAGPIE-121's Avatar
If you have the red, silver or orange head .21 yes
i have the mg66 internals in my old red head 3 port & it rocks
MAGPIE-121 is offline
Old 03-26-2010 | 09:29 PM
  #10339
chevydc44's Avatar
Ok cool thank you yeah I have the silver head where did you get the mg66 internals
Old 03-26-2010 | 09:58 PM
  #10340
MAGPIE-121's Avatar
from the engine designer, mark, of massivemods : http://www.massivemods.com.au/index....ath=24&&page=2
you have the 5 port
Old 03-26-2010 | 10:15 PM
  #10341
chevydc44's Avatar
you have the 5 port
Yeah I have 5 port silver head im gonna change the carb also
Old 03-26-2010 | 10:28 PM
  #10342
MAGPIE-121's Avatar
lol good one u won't be disapionted with the gx or mg internals or the carbs
Old 03-26-2010 | 10:37 PM
  #10343
grizz1's Avatar
If you have one of the long LSN GO carbs on there, and you lean the top end, you will get serious lean bog. These carbs tune quite differently to the Nova carb you have.
Don't worry about measuring the idle gap, set it usiing the pinch method I described in my previous post. This is the most accurate way, and works on any motor regardless of carb type etc. If the motor is still really new and has lots of mechanical pinch, you won't get the top end out of it until it's broken in. Leaning a new motor like that trying to get more top end will just kill it - real fast.
grizz1 is offline
Old 03-26-2010 | 10:43 PM
  #10344
chevydc44's Avatar
Do you know what are the stock settings are on the old carb
Old 03-26-2010 | 11:21 PM
  #10345
grizz1's Avatar
It will vary depending on the type of low speed needle fitted.
Gen 5.5 and more recent (GX, MG66) with the long needle carb, the factory settings are flush on both needles.
grizz1 is offline
Old 03-27-2010 | 07:45 AM
  #10346
Ruune's Avatar
Bigmatt, thanks for the feedback . I don't think I have a air leak, as this is happening with all 4 carbs I have tried, 2 Go Carbs (Gen 4 and 5), 1 Nova Carb ( 2 needle on road), 1 OS carb.
Engine is shimmed as per factory spec for using 25% nitro. Head bolts are tight, very tight.
If you've got some older go carbs that are giving you trouble with tuning, you should probably replace your carb seals with the new black nitrile seals and o-rings. They're relatively cheap and we have them in stock in the US. Have your dealer contact us and we'll get you set up!
Ruune is offline
Old 03-27-2010 | 08:38 AM
  #10347
chevydc44's Avatar
I have the silver head motor not sure how long the needles are
Old 03-27-2010 | 11:27 AM
  #10348
Hey Trey(Ruune), when are you going to post a list
of all the dealers and get the forum up and running
on the go-engines-usa site? Also is the "Contact"
working on the site? I left a message two weeks
ago and never received a reply. Bussiness is going
to be picking up fast now that GO has some gunners
sponsored. All the "fan boys" will be wanting to jump
on the GO wagon. Good luck with all the noobs wanting
to run the long needles, your going to have fun with them.
rageworks is offline
Old 03-27-2010 | 12:08 PM
  #10349
post here to remember my GO 3PT, I was run it always between 260-280, used 25% nitro and without any shims..................
and after maybe 10L I sold it. haha
cow9527 is offline
Old 03-27-2010 | 06:21 PM
  #10350
Quad Racer 34's Avatar
what kind of runtime does the go port 3 port with the pipe that comes with it get? and how many gallons does it usually last for?
thanks
Quad Racer 34 is offline
