Like Tree2Likes
Go-Tech Engines Thread
Old 07-04-2009 | 05:33 AM
  #7636
mattwoodcraft's Avatar
what are you running buggy or truggy ? the 3 ports are awsome buggy motor im very happy with mine
i got spare motors to i have a 7 port as my back up or if some one wants to have a shot i just lend them them the motor
mattwoodcraft is offline
Old 07-04-2009 | 06:04 AM
  #7637
tonydig11's Avatar
D8 buggy
tonydig11 is offline
Old 07-04-2009 | 06:22 AM
  #7638
if your going to get another motor the 3 and 7 ports are great in the buggy
Old 07-04-2009 | 11:55 AM
  #7639
Originally Posted by gtxracer
He was running the OS p3 plug. I bought some of the O Donnell 77T and 97T plugs to try out. I might just swap one in from the get-go.
I honestly wouldn't know if he had it upside down on the throttle or not. It's not a scrape or gouge but a mark from one of the detonations. However, it may be from having a rich setting (which he said he ran it rich) and the plug element dropped in there. Either way, it wasn't anything more than a surface difference. Should I be worried?
Anyone?
gtxracer is offline
Old 07-04-2009 | 03:48 PM
  #7640
grizz1's Avatar
Originally Posted by tonydig11
I got almost a gallon on my 5 port so the rod and pin replacement is due in a race or two. I got the rod and clips but pin is backordered. hope its here by the time i need it. Also. is the EB mods GO worth the extra cash? i am looking at a second mill. I will eather get the 3 port race and break it in and keep as backup or get the EB mods and make my 5 port a back up. I live 1.5 hrs from the track and it sucks to blow a engine in first heat. Its happened to me once.
Don't sweat it on the rod change Tony. Rod and pin change at around 2 gal is the norm, so you have some laps up your sleeve. Change it earlier once the hard pinch has gone by all means if you want though
grizz1 is offline
Old 07-04-2009 | 03:55 PM
  #7641
grizz1's Avatar
Anyone?
Put it back together and run it. You would need to replace the p/r/s to fix the scrape problem anyway, so just run it and see how it goes. It may be fine for quite a few gallons. If not then just fit a new p/r/s kit, which is not a huge expense with these motors.
grizz1 is offline
Old 07-04-2009 | 04:07 PM
  #7642
the pleasures of these engines the parts for these are always very well priced
Old 07-04-2009 | 07:12 PM
  #7643
megasaxon's Avatar
what size is the front bearing on a go 21?
megasaxon is offline
Old 07-04-2009 | 08:41 PM
  #7644
22Racer's Avatar
7X19 same as pretty much every motor.
Rex
22Racer is offline
Old 07-04-2009 | 09:10 PM
  #7645
Whats the best pipe for go 3 port turbo plug engine? I've been using ttr efra 2039 it seems pretty decent but I think its not bringing the full potential out of this engine.
TopGearRC is offline
Old 07-04-2009 | 10:00 PM
  #7646
grizz1's Avatar
The new GO 2072
GO 0801
Dynamite 086
in that order.
grizz1 is offline
Old 07-04-2009 | 10:13 PM
  #7647
Hey thanx for the quick response... Btw who sells the 2072? I just did a quick search on amain and tower and ebay no one has it.
Old 07-04-2009 | 10:26 PM
  #7648
zJatoRad's Avatar
the only one who seems to have it right now is MassiveMods in Australia.
zJatoRad is offline
Old 07-05-2009 | 12:10 AM
  #7649
the 2072 pipe is awsome on the 3 port i have this in my buggy
Old 07-05-2009 | 09:32 AM
  #7650
Gizmatron's Avatar
Default R.I.P
Well racing went fabulous today.....until in the semi final I first cracked the weld at the front of the stinger on my new 2072 pipe and almost ripped it right off..Bugger..repairable though but 3 laps later the 7 port died and after a few attempts to restart I slammed the 3 port in and finished the race in 8th..BOO!..Post race inspection of the 7 port revealed a crack in the underside of the crankcase..Oh shit..strip down this evening shows it pushed the rear bearing through the case..ruined the case,crankpin,probably the rod etc and definitely the piston and sleeve (but they were on their last legs anyway)SO! big question is do I rebuild it with the new MM5 p/r/s I have which means new crankcase gen5.5 crank and might as well get MM to fit ceramics as well cause I bet the bearings are shot as the crank was presumably spinning at an angle for a while b4 it died!probably at least aus$160 or do I flog the unused p/r/s kit to someone on here and buy a new MG66..
.MM5 7 port p/r/s unused and ready to run in anyone
Gizmatron is offline
