Like Tree2Likes
Go-Tech Engines Thread
Old 06-20-2009 | 12:05 AM
  #7291
grizz1's Avatar
Originally Posted by Jeremys8T
I''ll try heating it up and reshaping it, but the bend goes all the way to the end cap of the pipe. When it happened, the crash pushed the exhaust mount and bent it where the mount attaches. Now my mount is another 1/2" away and the pipe is currently closer to the fuel tank than I like. Thanks for the response.
I had a similar thing happen to my 0801 a few weeks ago, except the whole end where the pipe mounting wire attaches split open and pulled out . Looked like someone had taken a can opener to it. I got monstered by a truggy during an open practice session
Good pipe the 0801 but just a bit too thin walled and fragile.
Order a new 2072 from Massive Mods. With your exchange rate you will get a cool price, and Mark will ship it to you real fast. HP readings with the new 2072 are scary. Will make your EBMods scream
grizz1 is offline
Old 06-20-2009 | 12:50 AM
  #7292
hi there
at first, i hope you understand my terrible english :-)
i have a lot of engines, go 25, go r217pt, Ninja Jx, modded v spec, trinity ex tech 21, rb ws7II, Rb C6, sirio cl7B sti....wiht a lot of differnet pipes
i like to try new engines and to see if there is much trues what people write about there engines :-) in forums
i just believe what i try by myself
i drive the engines in truggies, this time a losi 2.0T is my truggie.
of all these engines the ninja jx and the go 21 7 port are my favourites. the go a littl bite more because you get more then you pay for.
this engines is fantastic, its my second 7 port go engine and this engines has so much bottom and low end, its fantastic, but one thing i didnīt like at the go engines, the carbs are not constant, they hold a tune, that is not the problem but the carb is not good enough for the rest of the engine. the quality of the carbs are not constant
try a ninja jx 21 carb on your go and you will see what happend. this thing fit perfect, much beter then ateh sirio carb
you will see that you will have more snap from low when you accelarate
next days i will sell my other engines and the go 7 port would be my engine next time, i like the engine.
i like it too when people laugh about my engine, but after they will see at the corners and the straights that there ist nothing to laugh :-)
so i hope you can read my terrible english , hahaha
i like this go engines, my favourite ist the 7 port, i drive the 5 port too but the 7 port is the engine that i like
mihaelbencek is offline
Old 06-20-2009 | 02:46 AM
  #7293
grizz1's Avatar
Hi Mihael, nice to have you on the forum
Yes, the GO 7 Port is a wonderful motor in truggy or buggy. Interesting what you say about the JX Ninja carb. There are plenty of Jx Ninjas where I race, so I will have to try and get my hands on a spare carb and try it out. I know the Jx's are very strong down low from watching the run.
Have you tried shortening the low speed needle on your GO carb ? Take it from 1.6" down to 1.42" and try it. You will find the carb totally different to tune, and performance IMO is better.
grizz1 is offline
Old 06-20-2009 | 03:34 AM
  #7294
mattwoodcraft's Avatar
i know people have been putting the os carby in so i have been told but i do like the go carb very fuel efficiant and reliable ..... what is the fuel economy like on this jx ninja carb ? i have 2 carbies from the old engines i used to run they are from the GRP they should be very similar i would have thought
mattwoodcraft is offline
Old 06-20-2009 | 04:08 AM
  #7295
cuttin the needle? hahah
are you crazy? haha
i never herad that but i will try
i let you know if i feel a difference
mihael
Old 06-20-2009 | 04:23 AM
  #7296
i havea spare Go carby which i will trim the needle like Grizz says... i have only heard positive results about
Old 06-20-2009 | 04:42 AM
  #7297
Talaba's Avatar
how did you do that is it compatible to all go engine
Talaba is offline
Old 06-20-2009 | 08:06 AM
  #7298
when grizz was talking about this earlier he was shortening the long lsp needle trimming it and filing a rounded point on the end as remember its a few pages back think
Old 06-20-2009 | 10:14 AM
  #7299
sickpuppy1's Avatar
So if I have a carb with the HSN that measures 1.42 already but is more than 6-9 months old ( got it last year late summer early fall) what version motor you think I have? The gen 5 has the 1.6 right? Oh yeah, its the silver headed 5 port turbo button. And it has been a pain to tune so far.
sickpuppy1 is offline
Old 06-20-2009 | 10:27 AM
  #7300
Gizmatron's Avatar
Well after breaking my bloody conrod last month on my 7 port just as it ran out of fuel (and 5 minutes after thinking "I'll just run this today and then change the rod before racing tomorrow!!!"and since having some slight tuning problems I decided to give the sleeve a pinch..Job done..back on top form and with the 2072 pipe absolute screamer..around 9 minutes runtime so a bit less than the 2047 but well worth it for the improved bottom end punch..gotta back off the front brake though as stopping fast at the end of the straight I managed to lift the rear wheels with ease and flip the buggy over..and that's in dusty low grip conditions.
I'm really liking the 2072 on the 7 port, but after trying both I think the 3 port R is still better with the 2047..Next race is on the 5th july at a really tight track with the worst rocky ripped up surface..not my favorite venue at all..maybe now I have the car and both motors soeted properly I can get some points this time..
Gizmatron is offline
Old 06-20-2009 | 11:13 AM
  #7301
sorry low speed needle ......
i must have had memeory laps
Old 06-20-2009 | 11:36 AM
  #7302
Grizz is right,shorten your LSN as he described.I did my gen4 7port and it tunes real easy and stays consistent all day.
I took your advice Grizz and have ordered a Gen5.5 5port and 2072 pipe combo from MM.Luckily I know what I am in for with breakin after breaking in the 7pt (now where`s that heat gun?
Will let you know how it goes.
ben1970 is offline
Old 06-20-2009 | 01:14 PM
  #7303
grizz1's Avatar
Nice one Ben. You will find the Gen 5.5 a little easier to break in, as they have eased the initial pinch a little on the 5.5 motors. Bet your glad to hear that Just go through the same break in routine though
Yep that shorter LSN makes it easier to tune for most people. I reckon I have got better performance from both my motors since I changed (probably because their tuned properly now !!). Economy doesn't seem to be affected at all either. Enjoy that 5 Port - you will love the bottom end punch
grizz1 is offline
Old 06-20-2009 | 01:51 PM
  #7304
sickpuppy1's Avatar
LOL, its infectious, yeah lsn. its already 1.41+-. Took out the HSN and noted the oring was nasty. Hadnt fallen apart yet for the most part, but was cracked up badly, kinda "chunky" lookin. Did the fuel tube mod. The lsn oring looked fine so I used allittle Dow55 oring lube on it. Havent had a chance today to retry it, as I'm getting ready to go to Father in laws 80th B-Day party! WOOHOO! I'll fire it up in the morning as soon as I think most neighbors are up,LOL Am using a 801 pipe with it and the blips I get around driveway show potential, but wont stay running long enough to get a feel or good breakin. This oring may do the trick I hope
Old 06-20-2009 | 03:00 PM
  #7305
always over looked the o-rings on a carby no matter what carby it is
any way bugger the neighbours fire her up and roll along
when i run my motors in im sure the neighbours are happy i know for sure that successfully kill my lawn and soon i get to do it again when run in my new 7 port in my truggy ready for the nationals and yet again the neighbours will listen to it all DAY
