Like Tree2Likes
Go-Tech Engines Thread
Old 04-27-2009 | 12:14 PM
  #6511
will g's Avatar
Originally Posted by TBIRDOWNER86
Mthird,
When comes to computers and texting I am clueless. I don't know what pm, bump, ping, etc., etc.... means. I'm sorry.
sent you a private message
will g is offline
Old 04-27-2009 | 02:16 PM
  #6512
grizz1's Avatar
Originally Posted by Semple
It runs really well at those settings. Doesn't hesitate. I blasted it wide open throttle, stopped dead for 5 seconds, and pulled the trigger to full throttle, no hesitation.
I'll lean it out some more next time I get a chance to put some more fuel through it. I guess I'll keep leaning the LSN...?
Just keep leaning the LSN a little at a time. The HSN should end up somewhere between flush and .5 of a turn in - no more. If you go any fuether in on the HSN you will get lean bog. The long LSN stays in the spray bar even at full throttle, so you need the rich top end to allow enough fuel past at full throttle.
The LSN will tune 90% of the rev range, then you just tweak the HSN to get the last 10% to full throttle perfect. Important to check your idle gap is .7 - 1mm - no more. Because you tune with the LSN, this gap is very important as the throttle slide location also effects where the LSN needle sits. Change the idle gap and you change your LSN too.
grizz1 is offline
Old 04-27-2009 | 02:21 PM
  #6513
Mthird,
hehe let me give you a cheat sheet.
PM = Private Message
Bump = posting a new message in a thread to raise it to the top of the forum.
Ping= The amount of time it takes for a packet of information to go from your computer to a host computer and back. Measured in Milliseconds.
Jasonguy is offline
Old 04-27-2009 | 02:23 PM
  #6514
That makes a lot of sense and explains why I originally gave up on the engine last year. I will keep this information in mind while tuning. Thanks for the help, guys.
Semple is offline
Old 04-27-2009 | 02:30 PM
  #6515
Will G EB FUEL RULES I love the way it burnes and it doesnt have that super high oil content but the engine seems like it has been running fuel like that, now I just need ED to hook me up with 1 of them FM's to try out.
malik is offline
Old 04-27-2009 | 02:38 PM
  #6516
TBIRDOWNER86's Avatar
Default .
HA.........Thank you jasonguy!.....DEE DEE DEE....
TBIRDOWNER86 is offline
Old 04-27-2009 | 02:57 PM
  #6517
Default Go Tech
Sorry folks. I didn't realize I would have such a huge response. Here are some pictures.
This is a B21 5port. You will need a piston, a sleeve, and a carb. The block has a chipped fin near the rear head screw hole. The engine still will seal. You can see it in the picture below.
To buy $100 + shipping
For those wanting to trade, I'm looking for hitec servos HS-985MG. I think 2 servos would be a good trade.
Attached Thumbnails Go-Tech Engines Thread-084.jpg   Go-Tech Engines Thread-088.jpg
Old 04-27-2009 | 06:30 PM
  #6518
zJatoRad's Avatar
Looks like MassiveMods have some new Go products!, the new Go EFRA 2072, Turbo button for the .25 and .28 as well.
http://www.massivemods.com.au/produc...7bed28e708a5a1
wonder when they'll get here in the U.S.
zJatoRad is offline
Old 04-27-2009 | 09:39 PM
  #6519
grizz1's Avatar
That 2072 pipe looks like the goods. Be just like running the 2047 pipe with the 0801 header, but probably a little better. It will be nasty on the 5 and 7 ports, 3 port too I'm guessing - HOT
grizz1 is offline
Old 04-27-2009 | 09:42 PM
  #6520
Originally Posted by malik
I have seen both them heads on GO's before.
word thanks
NitroLuver is offline
Old 04-28-2009 | 12:16 AM
  #6521
max_chen's Avatar
Do you run it?
How about your feeling?
it's excellent.
max_chen is offline
Old 04-28-2009 | 08:11 AM
  #6522
I am digging the pipe.
malik is offline
Old 04-28-2009 | 08:24 AM
  #6523
I would be all over that pipe if I hadn't nuked my steering servo somehow yesterday .
Jasonguy is offline
Old 04-28-2009 | 08:34 AM
  #6524
Default Pipe temp
Hello guys,
there is a point I would like to share with you about my new GO 5ports Stock engine.
The temperature of the pipe is high, which means my bodies are melting on the area above the pipe.
Has anyone had this issue before ?
The configuration I'm using is:
25% nitro fuel
OS P7 medium plug
GO 2047 Pipe
OS 2060 header (a litle bit shorter than the GO header)
Shimm: 0,1mm less than the stock configuration
engine work temp: 239 - 248 F
Good top end - not so good botom end.
Is this a normal situation for a GO Engines or does anyone has any sugestion ?
Thank you very much.
Cestari
Cestaric is offline
Old 04-28-2009 | 08:48 AM
  #6525
Gizmatron's Avatar
Originally Posted by Cestaric
Hello guys,
25% nitro fuel
OS P7 medium plug
GO 2047 Pipe
Cestari
Is that .1mm less than the stock with the extra run in shim or what? How many shims and what total thickness are you running..Less shims = higher compresssion = higher engine temps but lower exhaust temps..While running in generally add a .3 shim to reduce compression and give both your rod and starter box and easier time but this will increase exhaust temps some and may melt bodies ..How many gallons on the engine..Probably best not to reduce the shims too soon until the metal pinch has relaxed properly because the tightness of the engine gives more friction/compression and increases engine temps too..wait 2 gallons or so..I just removed my run in shim at 10 litres (2/1/2 gallons approx)..i ws melting my body just a touch on the header but thats stopped now..
edit..the lack of bottom end is probably the shorter header..longer headers for bottom end shorter for top end...your temps are fine..lowish in my experience .mine runs at 260º - 280º no problem..
Gizmatron is offline
