Like Tree2Likes
Go-Tech Engines Thread
Old 03-08-2009 | 05:24 PM
  #5851
Tree's Avatar
Originally Posted by tagalong_74
what would u guys rather run in a truggy the go 25 or the go 28???
Personally I would get a Go Tech 5 port turbo. That mill has more than enough power to move a truggy plus it gets excellent run times. If your choice is between the .25 or the .28, I would rather go with the .25.
Tree is offline
Old 03-08-2009 | 05:30 PM
  #5852
you would be better off with a ebm5 race prepped for your truggy, it will have all the power you need plus get good fuel economy, is allready broke in and has a tko ceramic rear bearing
cjm1126 is offline
Old 03-08-2009 | 05:54 PM
  #5853
VenturaDC's Avatar
ok guys, what needle settings would you start with on a modded sport 3 port turbo button with the shortened LSN?
VenturaDC is offline
Old 03-08-2009 | 06:18 PM
  #5854
stu541's Avatar
Agreed, any of the GO .21 5 ports will do the trick. I had great luck with the jammin JP-2. Stock carb restrictor and it ran 9 min. easy. My buddies ran picco .28's and to smooth out the power you are lucky to get 6 min. the GO .25 I'm not sure.
stu541 is offline
Old 03-08-2009 | 06:19 PM
  #5855
22Racer's Avatar
1.5 turns in from flush on the Lsn and a 1/2 turn out from flush on the high speed.
Rex
22Racer is offline
Old 03-08-2009 | 07:10 PM
  #5856
grizz1's Avatar
Originally Posted by t8rtot
i keep hearing about these motors going bad early.. wats the avg. life expectancy?
and whats the milage like on the 5port and if the Grenade is out wat is the milage on it? thanks
Ain't nothing wrong with the GO motors. If you break them in carefully, tune them right, and look after them (like any motor), you will get 10 gal or so.
I think most people have trouble because they are too impatient with the break in. These motors are very tight when new, and just need to be broken in properly. No motor will last if you just run a tank through it and then cane it. I am sure there is the odd ¨lemon¨ out there, but you get that with any brand - even the top dollar ones. On the whole I think you would find them one of the most reliable motors at the track.
5 Ports are very economical for their power output. 10 - 11 min with a 6.5 mm restrictor is quite obtainable, especially with the modded motors.
grizz1 is offline
Old 03-08-2009 | 07:38 PM
  #5857
VenturaDC's Avatar
Rex
with the shortened lsn?
i only ask cause i thought after i ground down the lsn it would tune more like any other motor and that seems quite rich on top. just want to make sure as this motor has been giving me fits for quite some time now and was hoping that grinding teh lsn would help.
Old 03-08-2009 | 07:41 PM
  #5858
rearviewmirror's Avatar
The .21 5-port.
rearviewmirror is offline
Old 03-08-2009 | 08:30 PM
  #5859
grizz1's Avatar
Originally Posted by rearviewmirror
The .21 5-port.
+1 Plenty of power were you need it, and you only got to stop every 10 min or so for fuel.
grizz1 is offline
Old 03-08-2009 | 08:46 PM
  #5860
22Racer's Avatar
Sorry, I thought by starting out meant you hadn't broke it in yet. I think the hsn should be in from flush some.I don't have alot of experience with the Sport carb, I do set the needles for break in on the ones I sell and I've heard they are right on.
Rex
22Racer is offline
Old 03-08-2009 | 09:05 PM
  #5861
drs92's Avatar
what would a modded .21 3 port sport be like?
drs92 is offline
Old 03-08-2009 | 09:13 PM
  #5862
22Racer's Avatar
The one I modded I plan on using this summer. Almost as much bottom end as a 5 port and really close on top end too. I've been getting $145.00 for the new ones I modded.
Rex
22Racer is offline
Old 03-08-2009 | 09:42 PM
  #5863
drs92's Avatar
How do you like it and do you run it in truggy? Is it worth it?
drs92 is offline
Old 03-09-2009 | 12:21 AM
  #5864
MrUnlimited's Avatar
Hi Guys,
I am looking for some turbo plugs for my MM5 7p engine. What is the best plug for it or will any turbo plug will do like these: http://cgi.ebay.nl/TCA-Turbo-Head-Gl...3A1|240%3A1318 or http://cgi.ebay.nl/TCA-Turbo-Head-Gl...3A1|240%3A1318
MrUnlimited is offline
Old 03-09-2009 | 01:29 AM
  #5865
grizz1's Avatar
Originally Posted by MrUnlimited
Hi Guys,
Check out the bottom of page 193. Just been a discussion on suitable plugs.
I favour the OS P3 or P4 personally.
grizz1 is offline
