Like Tree2Likes
Go-Tech Engines Thread
Old 12-17-2008 | 01:31 AM
  #5101
grizz1's Avatar
Hi jnc011994
It should idle for quite some time before dying, certainly more then 10 secs.
When you have the LSN set right you will get a steady smooth idle and a very punchy take off from a standing start with full throttle.
Run the buggy for 30 secs or so and bring it in. If the idle starts high and then drops off quite markedly in a short time, your LSN is too rich. Lean 1/8 th of a turn at a time and repeat. When the buggy comes in and the idle stays the same speed for 15 secs or so, or even longer you are pretty close.
If the idle gets very erratic, speeding up and surging, your LSN is too lean, so richen by 1/8 of a turn at a time until you get the steady idle.
Providing you are running the long LSN all you need to do now is tweak the HSN a little if necessary for a nice top end. Do not lean by more then 1/4 turn though or you might start to get lean bog at half tank or lower. Basically leave the HSN at the .5 mark and tune with the LSN as described above.
Remember - this is only for the long LSN carb. Cheers
grizz1 is offline
Old 12-17-2008 | 01:45 AM
  #5102
slaytanic's Avatar
Originally Posted by Paperman 90
hi i have 3pr and i was racing last week and the glow plug blowed out of the motor so i put a new plug in the motor and it blew that one out to can anyone help me.
Most likely you overtightened the plug and stripped the threads on the button. You need to take the engine apart and clean it well in case any debrisgot inside and replace the head button. At least they are cheap!
slaytanic is offline
Old 12-17-2008 | 04:58 PM
  #5103
jnc011994's Avatar
Originally Posted by grizz1
Hi jnc011994
I do think i have the Long LSN, since its an old engine, i bought this engine 6 or 7 months ago. And yes, when i tested it, under running temp (i don't have a temp gun, but the engine is already hot) the idle starts high and drop off after 5 sec. which mean that i'm still running rich. I would re-test this on saturday so that i could get the desired condition on race time. really appreciate the help. One more thing, is the setting for the .28 Red Head the same with the .21? I also have an old .28.
jnc011994 is offline
Old 12-17-2008 | 07:35 PM
  #5104
does anyone have any oppinions on the best break in process for the 3 port turbo?
JohnnyLeach is offline
Old 12-17-2008 | 07:40 PM
  #5105
Read the bottom of page 78 on this thread.
Follow that and you will be good to go.
herb99 is offline
Old 12-17-2008 | 10:51 PM
  #5106
grizz1's Avatar
Yep, that will be the long LSN.
You don't need a temp gun, just use the good old spit method. Wipe a bit of spit onto the top of the cooling head.
If it just sits there and takes more than 15 secs to evaporate away you are a bit cold. If it sizzles and pops and evaporates straight away, you are too hot. If it steadily evaporates away over 5 - 10 secs you are good to go.
I am pretty sure the .28 has the same carb as the .21. Perhaps someone else could confirm that for you ?
+1 on that. That break in works a treat and is kind to the engine too.
grizz1 is offline
Old 12-18-2008 | 03:12 AM
  #5107
triplesix's Avatar
Default Pipes for R217PT
hey guys,
after years with R&B motors i decided to try the R217PT, just because i'm curious. i've heard so many good things about them.
my question would be which pipes can you recommend on this engine? i know there is a motorbox with a go-pipe included, but are there any other pipes worth to try? (e.g. the ae/tt 2035, which suits to quite a lot of engines...)
thx in advance!
triplesix is offline
Old 12-18-2008 | 06:29 AM
  #5108
will g's Avatar
best pipe for .21 7 port is the dyn 053 or go 0801
will g is offline
Old 12-18-2008 | 07:17 AM
  #5109
TMizzle's Avatar
My G7 Powered 09 ride.
some shots with my practice body on.
Sean Ozz is painting my race lid.
TMizzle is offline
Old 12-18-2008 | 09:17 AM
  #5110
Tabushi's Avatar
Congrats TMizz !!! ... VP + GO excellent combination !!!
My season 2009 starts by January 11th, i hope to have the new CEN car by that time
cya,
Tabushi is offline
Old 12-18-2008 | 09:36 AM
  #5111
TMizzle's Avatar
why not GO + VP + D8? lol
you left out D8, Cen boy. hahaha
how you been man? did that big race go well that you were trying to get me to come to?
TMizzle is offline
Old 12-18-2008 | 11:59 AM
  #5112
losi_racer's Avatar
if u guys are lookin for a .28 go motor pm me. I have a .28 6port. has no more then a gallon on it. Pm me for details
losi_racer is offline
Old 12-18-2008 | 12:20 PM
  #5113
grizz1's Avatar
Hi TMizzle, nice looking ride
Good to see you have Go and VP Pro onboard. There is a group of six of us down here in NZ that are running an XRay 808, GO, VP PRO combination. Looks like we have the brands covered between us eh??
grizz1 is offline
Old 12-18-2008 | 12:26 PM
  #5114
TMizzle's Avatar
true. true...
Now we got to get you guys over to the world champ buggy. lol. Just kidding. Most of the guys in my area run the 808 since RCamerica is right here in Texas.
TMizzle is offline
Old 12-18-2008 | 02:23 PM
  #5115
quick question. i just got my go 3 port turbo in the mail today which i bought brand new from somebody on here. it has a different head and different block then my brothers and the one they show on a main hobbies. did they recently change it to the black block, and different printing on the head?
