Like Tree2Likes
Go-Tech Engines Thread
Old 12-20-2008 | 10:49 PM
  #5146
22Racer's Avatar
.25 6 port in a truggy, it launches off the corner.
Rex
22Racer is offline
Old 12-20-2008 | 11:47 PM
  #5147
jasonhiggo's Avatar
Rex
i agree spot on hell engine the .25 GO
jasonhiggo is offline
Old 12-21-2008 | 12:18 AM
  #5148
grizz1's Avatar
Originally Posted by Jesussaves
Shane a few options re: plugs
You could try some O’Donnell OS style plugs, they are cheaper and fairly tough from what I have heard. Check out RC Mart.
If you plane on running RB plugs which are NR based then try Extreme racing plugs as they are cheap at Carolinas R/C they are can be used in a NR engine without leaks, I can send you a PM from a good source about the Plug design/fit if you like?
$19 for plugs that's steep mate, $120 minimum just to walk out the door to race, 3 plugs, race fees, food and drinks, ect, expensive, but fun..
Cheers mate. Unfortunately I live in new Zealand so any plugs I bought from the States would have to be shipped down to me here in the South Pacific, some 14,000 miles away. The shipping costs negate any lower prices.
grizz1 is offline
Old 12-21-2008 | 10:01 AM
  #5149
triplesix's Avatar
Originally Posted by will g
thanks grizz i did didnt i hahaha
oh my...!
should have opened my eyes properly...
thank you guys!
triplesix is offline
Old 12-21-2008 | 05:26 PM
  #5150
nazprerunner's Avatar
what kind of run time are you folks getting from the 3port race ?and what carb insert its with
thanks nic
nazprerunner is offline
Old 12-21-2008 | 10:42 PM
  #5151
slaytanic's Avatar
I'm getting an easy 9 min with an 086 pipe and Trinity #5 plug. And I am only at 1/2 to 3/4 gallon with temps right at 190-200. Should get much better once the metal pinch goes.
slaytanic is offline
Old 12-22-2008 | 01:29 PM
  #5152
grizz1's Avatar
thanks nic
Running a modded 5 Port (which should give very similar times to the 3R) with a 7mm restrictor. Refueling at 7.5 min with just on a quarter tank left, so realisticly looking at 10 mins total run time.
grizz1 is offline
Old 12-22-2008 | 04:43 PM
  #5153
losi_racer's Avatar
grp boys i need your opinion....
i have the .28 6 port and i thought it had a air leak or somethin but today i played with it a little more and i got it runnin good. but the only concern is where my needles are. My high speed is like 3/4 turn above flush and my lsn is like 3 1/2 turns in from flush(not exact but aprox) are these settings ok? if i touch the hsn at all it cuts out. My temps are at 210-220
these were takin with a high end temp gun not the cheap ones
losi_racer is offline
Old 12-22-2008 | 04:48 PM
  #5154
Rocket42's Avatar
You need to check your idle gap. but you shouldn't really be worried where the needles are in relation to the housing too much. My guess is that your idlegap is too small causing you to run a very lean LSN and then in order for the engine to get enough fuel you have to run the HSN very rich.
Rocket42 is offline
Old 12-22-2008 | 04:52 PM
  #5155
losi_racer's Avatar
.7-1 mm right??
EDIT: i just went and looked, its small but its not bad. i had a bigger gap then it was now but i was leanin the lsn so i had to adjust the idle. I just put a 6mm just now wanting better fuel mileage(i havent ran it with the restrictor in) it started raining so i had to bring it in
Old 12-22-2008 | 07:44 PM
  #5156
TMizzle's Avatar
First time out with D8 with GO7 port
TMizzle is offline
Old 12-22-2008 | 07:52 PM
  #5157
David Wall's Avatar
Congrats on the ride Mizz!!! See you in Atlanta again this year!! Can't wait!!
David Wall is offline
Old 12-22-2008 | 08:44 PM
  #5158
Is your 7 port stock? And what restricter are you using? I havent ran mine yet due to the weather and my PTM 5 port I ran it in truggy last year so I know I am going to have alot of tning down to do. I am going to start with the 7mm restrictor and .9 springs and if its still too much I will go to the 6.5mm and worse comes to worse go up a tooth on the bell but I dont want to have to do that.
malik is offline
Old 12-22-2008 | 08:52 PM
  #5159
TMizzle's Avatar
yes, its a stock 7 port
OS P3 plug
VP Pro clutch shoes with 1.0s
0801 Pipe
7mm go restrictor
insane fast! and smooth!
TMizzle is offline
Old 12-22-2008 | 08:57 PM
  #5160
How you like the vp shoes? I am just alittle worried about the bottum end being too much.
malik is offline
