Like Tree2Likes
Go-Tech Engines Thread
Old 10-05-2008 | 06:34 AM
  #4471
TripleX-JT's Avatar
What is a good starting point for the needles on a .28 3 port?
TripleX-JT is offline
Old 10-05-2008 | 09:17 AM
  #4472
TMizzle's Avatar
NEW RC8T/GO.25 VIDEO
RC8T
GO .25/GO 2047 pipe
Panther 38 Gators
TMizzle is offline
Old 10-05-2008 | 09:22 AM
  #4473
dhopkins8's Avatar
Default Plugs
Help
I have a gen5 7port that now has about 2 gallons on it and it screams. I started to see some high temps 315+ and took the motor apart. I noticed the carb sleeve had a tick or wiggle. I then replaced the carb with an OS vspec carb that a friend had. This immediately fixed both tuning and temp problems and the motor runs really well. However, recently I have been blowing plugs after approx 3-4 tanks of running. I thought maybe I was too lean but I have a smoke trail and am temping at 180-210max. I had been using P3 plugs then tried P4 plugs and right now I am trying P6 plugs. I am running odonnel 30% and have 1 copper shim and 1 alum shim. I also sealed up the motor with blue rtv and have installed a brand new tank. I am not sure where to go from here.
Help
Dan
dhopkins8 is offline
Old 10-05-2008 | 10:26 PM
  #4474
22Racer's Avatar
When are the plugs blowing? during running, or it wont fire the next time you run it. Shutting down a motor by plugging the exhaust can ruin plugs.
Rex
22Racer is offline
Old 10-05-2008 | 10:28 PM
  #4475
22Racer's Avatar
Originally Posted by zJatoRad
does any Go dealer here have a .21 Rod in stock? for some reason the bushing in the rod went out after just 3/4 of a gallon.
would this be under warranty or it's normal? I know in the first piston/sleeve/rod set I had lasted over 5 gallons and the rod was still good.
Was this a new motor or a rebuild? was the crank new?
Rex
22Racer is offline
Old 10-06-2008 | 07:51 PM
  #4476
hey guys i need to know what size the stock black venturi is.for the go .21 5 port. i got the engine used and i dont have the manual. thanks
meno222 is offline
Old 10-06-2008 | 09:13 PM
  #4477
zJatoRad's Avatar
Rex
it was rebuilt with a new gen 5 piston/sleeve/rod but like I said, after 3/4 of a gallon the bushing on the rod went out, the engine was running very good, temps around 220-240 but out of no where it just stopped and found the bushing in pieces
who can I contact about this issue?
zJatoRad is offline
Old 10-06-2008 | 09:17 PM
  #4478
zJatoRad's Avatar
It's 8 if I'm not mistaken.
zJatoRad is offline
  #4479
MassiveMods's Avatar
Originally Posted by dhopkins8
Help
Help
Dan
Add a shim for 30 % nitro
MassiveMods is offline
Old 10-06-2008 | 09:20 PM
  #4480
dhopkins8's Avatar
Default blown plugs
Rex
I have had it happen both times. I plugged the exhaust to kill the motor then it would not restart. Then the most recent one I was running on the track and noticed a decrease in power, then 3/4 of the way around the track, the car died and the plug was dead.
Old 10-06-2008 | 09:25 PM
  #4481
22Racer's Avatar
If the crank was worn it could have caused the bushing to come apart, especially since you had to break in the new p/s. I am working on an Rb C6 right now that the same thing happened, have no idea why.
Rex
22Racer is offline
Old 10-06-2008 | 09:28 PM
  #4482
dhopkins8's Avatar
Thanks for the reply. I thought that 1 copper and 1 alum shim was 30%. If not, how much performance would I lose by adding another .1 shim? Would it even be noticable? Also if that is the case, is it worth running 30% and adding a shim or leaving it alone and running 20%. I don't know much about this stuff but I am slowly learning.
Dan
Old 10-07-2008 | 12:34 PM
  #4483
Rocket42's Avatar
Hey guys hows everyone doing, sorry i been gone for awhile and I hope everyone has been getting help with their Go engines. I will try and be back to answer some questions more often.
Rocket42 is offline
Old 10-07-2008 | 12:39 PM
  #4484
Tree's Avatar
Hey Rocket42, I am sure you have been extremly busy, it is good to see you back on the forum again.
Tree is offline
Old 10-07-2008 | 12:47 PM
  #4485
grizz1's Avatar
Dan
Use the standard shims and run 25%. The Go´s run sweet on 25%, with as much power as you will need
grizz1 is offline
