Like Tree2Likes
Go-Tech Engines Thread
Old 07-11-2008 | 05:35 PM
  #3736
will g's Avatar
here some more pics of my jammin x2 truggy with the .25 6 port engine and wow its silly fast on bottom
will g is offline
Old 07-11-2008 | 05:36 PM
  #3737
mugenb46's Avatar
Originally Posted by v1r killer
Hey Killer, the pipe you have is the ticket for the 5 ports, 9886, if you didn't have that pipe then the GO 0801, we are hitting 12 min on our test 7 port with a 0801 and Inovative Designs 6mm carb insert, the 5 requires less throttle input, so tune correctly and you will hit 10+ easy.
mugenb46 is offline
Old 07-11-2008 | 05:38 PM
  #3738
mugenb46's Avatar
Will, looks good man, good luck this weekend.
mugenb46 is offline
Old 07-11-2008 | 05:42 PM
  #3739
just got my 0801 pipe for my 3pt cant wait to race mbx5r tommorrow
novenom is offline
Old 07-11-2008 | 05:43 PM
  #3740
mugenb46's Avatar
Have fun and be safe, that pipe rocks on the 3R
mugenb46 is offline
Old 07-11-2008 | 05:52 PM
  #3741
novenom is offline
Old 07-11-2008 | 06:09 PM
  #3742
Default 0801 pipe
I have seen a few people asking about the new 0801 pipe. I have a new 0801 pipe/header if anyone is interested.
brianr34 is offline
Old 07-11-2008 | 07:55 PM
  #3743
grizz1's Avatar
Originally Posted by malik
Pretty dum huh! I put it back together and ran like 5 tanks through it and by the 3rd one it was making power. I melted around the Idle screw but it is still functional. Got a good deal on a RB carb so I should have it her tomorrow. I will try to get to the track early tomorrow and put as much fuel through her as possible in case I decide to run. Brian it started instantaneously, too bad I got too friendly with the heat gun LOL. What were those settings again for the RB carb?
Hey malik, good to hear you are up and running Don´t sweat it man, we can only learn from our mistakes, and I bet you won´t fall into that trap again I know I said to get it real hot, but not that hot !!!!
Hope you get to race
grizz1 is offline
Old 07-11-2008 | 08:10 PM
  #3744
chucked's Avatar
i've got about 1/2 gallon through my 7port turbo. At what point is it recommended that I take out the break in shim and leave in just the two thin copper and one silver shim?
chucked is offline
Old 07-11-2008 | 09:15 PM
  #3745
grizz1's Avatar
Probably about 1 - 1.5 gallons. It sort of depends on what break in method you used.
I use the PTM method from page 78 of this forum, and took the break in shim out at around 6 litres (about 1.25 gal). Pretty much when you can turn the motor over out of the car by hand and not feel that real tight metal pinch anymore.
You also feel it in the performance of the car. It all of a sudden really gets up and goes and starts to rev out a lot more freely - take it out then.
As insurance, (because these motors are so tight from new), I have religiously replaced the con rod at 2 gallons on my 3 Go Techs, just to be on the safe side. It would be a shame to wait all that time for the motor to bed in and then have the rod let go
Hope this helps.
grizz1 is offline
Old 07-11-2008 | 10:55 PM
  #3746
RETRO RC's Avatar
I use the PTM method from page 78 of this forum, and took the break in shim out at around 6 litres (about 1.25 gal). I have religiously replaced the con rod at 2 gallons on my 3 Go Techs,
Hope this helps.
6 ltrs = 1.5 gallons and Grizz I think you mean you change the rod after the first 2 gallons, not every 2 gallons just so some people out there don't get the wrong idea
RETRO RC is offline
Old 07-11-2008 | 11:20 PM
  #3747
grizz1's Avatar
I thought that's how it read ("at" 2 gal, not "every" 2 gal)
"Around" 6 litres - "about" 1.25 gal. Nothing specific, as our friends on here are talking US gallons instead of imperial gallons anyway.
My apologies if I confused anyone. Just putting forward my limited experience to try and help out a little.
grizz1 is offline
Old 07-12-2008 | 03:24 AM
  #3748
Your post made perfect sense grizz.
Your advise is appreciated.
Do I need a temp gauge to break in a Go motor?
I plan on following the break in guide on page 78. But dont own a temp gauge.
herb99 is offline
Old 07-12-2008 | 05:37 AM
  #3749
Whether you're breaking-in a motor, tuning it, bashing, or racing, I think you should have a temp gun.
Every type of motor has min/max/optimum operating temperatures and not knowing the temperature of your motor (nitro or electric) can be very bad.
I, personally, recommend you use a temp gauge.
kilana is offline
Old 07-12-2008 | 06:01 AM
  #3750
vti-chris's Avatar
Just got an RB S5??(how old is this) carb from a friend...does anyone know if it will fit in my 3 port R before i start removing anything?
It's the old one...fully aluminum with venturies.
vti-chris is offline
