Go-Tech Engines Thread
#3693
Here's a little video my wife took from round 4 of our points series here in Bama. I'm running my PTM Go 3R with approx. 4 gallons on it.....and I'm the slow red car.
But I did finish 2nd.................
http://www.youtube.com/watch?v=c97czXcEv1s
gj!
#3694
Make sure you have a real strong starter box and heat that baby up with a hot air gun or powerful hair dryer otherwise you will struggle to turn it over. The 5 and 7 port Go Techs have mega pinch when new. Check out the break in procedure on the bottom of page 78 on this forum. Follow this and you will be sweet. Those needle settings are spot on for break in. After 15 tanks or so you can start leaning the LSN toward 2.5 turns in from flush for normal running.
#3696
#3699
#3701
HERB I HAVE NOT YET RAN THE 2027 YET BUT I MATCHED IT WITH 2047 GO PIPE AND THEY ARE EXACTLY THE SAME PIPE BUT I WILL LET YOU KNOW WHAT COMES OUT OF THE PIPE WHEN I GET CHANCE TO RUN IT THNX WILL G
#3702
There is currently an ebay auction for a set of 4 got tech inserts for $14 (47 available) buy it now. Not sure if its ok to post a link, but the auction isnt hard to find. Has anyone tried these inserts or ordered from this seller?
#3703
I have them in stock too. I use a 7.5 on my 7-port and it is fine. They are very high quality and aluminum and not plastic like alot of others.
#3704
Hey guys, I have a question and sorry if its been asked before. Im also new to nitro stuff so bare with me
I recently installed a 3PT motor in my buggy, broke it in as followed. Installed a JP-2 pipe on it, byrons 30% gen 2, p3 plug. Motor runs around 210-230 with motor settings at a little lean on the bottom and a touch fat on the top. I also have the carb restrictor in that came with motor.
The problem im having is the motor seems to have no bottom end at all. I went from a 1.0 clutch spring to a 1.1 spring with no difference. I just cant seem to get any rip at all out of the bottom end. Mid range and top end are ok, just killing over bad on the bottom.
Do I have the wrong pipe on? Wrong plug? Ect? Any tips and info i can would be helpful!
#3705
2Likes
