Go-Tech Engines Thread
#3661
Hey guys, I have a question and sorry if its been asked before. Im also new to nitro stuff so bare with me
I recently installed a 3PT motor in my buggy, broke it in as followed. Installed a JP-2 pipe on it, byrons 30% gen 2, p3 plug. Motor runs around 210-230 with motor settings at a little lean on the bottom and a touch fat on the top. I also have the carb restrictor in that came with motor.
The problem im having is the motor seems to have no bottom end at all. I went from a 1.0 clutch spring to a 1.1 spring with no difference. I just cant seem to get any rip at all out of the bottom end. Mid range and top end are ok, just killing over bad on the bottom.
Do I have the wrong pipe on? Wrong plug? Ect? Any tips and info i can would be helpful!
#3662
Where are your needles set at?
#3664
guys,eed help on my my 5 port(standard)what should be the main problem if my fully broken in engine is flaming out?i started it yesterday to finished the run in procedure,due to vibration the plug that connects the rx pack and the receiver disconnects and my buggy(hyper 7 )gone wild and crashed on a concrete wall,good thing is there is no any damage on my kit,then i let the engine to cool down,then after some few minutes cooling down, my engine starts to flame out i dont know what reason why my engine is acting like that,since it hit the wall so bad,i tried adjusting the needles to its factory settings and nothing happens,always flaming out.
#3665
With all the nitro rumors, concerns, facts out there...has anybody run the .25 with 20%? If not what would be the disadvantage or problems if I did? I can find 20% locally but can't find 30% and the rumors (yes I know they may be rumors but rumors that should be considered) that 30 may become difficult to find in the future are suggesting running something other than 30, and I haven't begun break in yet so a fuel change would make sense.
#3666
#3667
#3669
So what's the best plug to run in my 3 port race? I have a OS p3 I'm gonna use for break in. I'm gonna use 30% Sidewinder and live in IN. I've seen in other forums that running a hot plug in hot weather with high % of nitro is a no-no.
#3670
#3672
Well, quite a few people shall be getting the upgraded
L.S. needles for there carbs in the mail this week. Is this
going to be The BIG FIX? I wonder what this thread has
in store for us next week? Will the GO motor tuneing be
retaught all over again? I think this thread is going to
get very interesting real soon.
#3673
#3675
I think the only low speed needles being sent out are warranty ones. I am a dealer and as far as I know I am not getting any to hand out, only the ones I ordered.
Not everyone is having problems with the current carb. I experimented and ground my low speed needle shorter on a new .25 6 port and it works great. I have seen some other motors come with 2 lsn's before, just another tuning option for the conditions.
If you change needles I do think the needle settings will be quite a bit different.
Rex
Rex
2Likes
