Like Tree2Likes
Go-Tech Engines Thread
Old 06-29-2008 | 08:55 PM
  #3466
22Racer's Avatar
My son Kendall placed 3rd in expert buggy at the Rc pro series north race in Evansdale Ia. It was the first time we tried the new 0801 pipe on his 7 port and it was awesome! He was pitting at 8-8 1/2 minutes and even speed V-specs didn't even pull him on the straight.
Rex
22Racer is offline
Old 06-29-2008 | 10:23 PM
  #3467
TTR:EB4's Avatar
Grizz is on RCTECH aye!!! Anyway
hi, can any of you compare a Go Tech 21 size engine to a O.S V-spec (standard one) and if the GO TECH is better which one do you recommend? Go techs would be a cheaper option for me so i want to see if anyone can compare it to a v-spec,
Cheers
Michael
TTR:EB4 is offline
Old 06-29-2008 | 10:29 PM
  #3468
Furadi's Avatar
Originally Posted by TTR:EB4
hi, can any of you compare a Go Tech 21 size engine to a O.S V-spec (standard one) Go techs would be a cheaper option for me so i want to see if anyone can compare it to a v-spec,
Cheers
Michael
I keep reading that the 7 port will pull a vspec but doesn't deliver the power as linear. Heck, I keep reading that the 7 port doesn't even wrap out
Furadi is offline
Old 06-30-2008 | 04:17 AM
  #3469
MassiveMods's Avatar
Originally Posted by cheesecake
oh and i finally got it tuned spot on today its a awesome engine but still lacking power for my liking in my truggy
These engines take 1 to 1.5 gallons to bed in and make full power , If you
can wait till then you will notice it pick up and get better the more you run it . ive had people get antsy that the engine wasnt going hard after a litre .. the ones that were patient got a very pleasing surprise once it was run in..
My advise is to be patient and dont lean for max top end till you hit the gallon mark.
Cheers MM
MassiveMods is offline
Old 06-30-2008 | 04:33 AM
  #3470
I think its safe to say that peoples set ups , eg pipe, fuel , car , driving ability , gearing etc etc can make an engine look good when its dialed, some days you may see the same engine in another car not look impressive at all ... I think its safe to say that a good set up and tune has a lot to do with this and its moot to blame the engine for this ..whatever brand it is .. Ive seen Go engines go harder than V Specs and vise versa , ive seen modified Thunder Tiger Pro .21 engines keep up with RB C6BB's ! ( YES I DID RUB MY EYES ) And OS TZ.12 Modified shoot past Rossi 3CT modidfied on the straight .. ( yep rubbed my eyes again )
Getting the most out of your engine is up to you to learn how. It takes time but when you see the guys that got it going on you can appreciate the engine at its full potential .
Old 06-30-2008 | 05:33 AM
  #3471
Hey guys,
I got the new generation 7 port go engine and all I can say the motor is given me a hard time keeping its temp. I have been running the motor with 30% sidewinder and a novarossi 7 plug just to keep the motor cool. But for some strange reason the motor will flame out after a few minutes of run time. I also noticed that the motor likes to run kind of hot from strange reason. I would like to know what will be the best plug to run for this motor to maintain a reasonable temperture. I can tune the motor, but the motor can't hold it's tune. This motor is actually not a bad motor at all! I cannot believe all the power this little rice burner has.
sKiMpYbOy is offline
Old 06-30-2008 | 06:00 AM
  #3472
I think the deal with cheesecake was that he was
used to running a novarossi 528 before going to the
5 port. If he would have bought a GO .25 motor he
would have been very happy. My PTM GO .25 is ONE
MEAN MO-FO. He would never had complained about
a power issue and been amazed with the run times
this motor gets. If you are power hungry, then get
the GO .25. I'll even bet that it gets twice the run
times of the 528.
rageworks is offline
Old 06-30-2008 | 06:28 AM
  #3473
CHogle's Avatar
Well, i just purchaced a GO 5 Port turdo, i was wondering about the break in procedure, i am getting it on thursday, there is a big local race on saturday, i want to know if the engine could be broke-in, in one to two days and not couse harm to the engine, i plan to use the heat cycle method, im ok with running a little rich on the HSN for most of the day.
Also, will the O.S P3 turdo plug work well in this engine?
thanks
CHogle is offline
Old 06-30-2008 | 06:48 AM
  #3474
will g's Avatar
Guys,
I ran my ptm 08 3 port .21 race spec engine sat night at the nitro pit in a series race we had i was very impressed with the way it realed in the v specs and even kept up with some of the novarossi engines out there. Brian i cant say how that thing runs. All i can say is WOW . Im still runing the 8 mm carp insert and next race i will change to the 6 or 6.5 mm carb insert for fuel mileage, other than that im very happy. Thanks GO engines and Brian @ PTM Will G
will g is offline
Old 06-30-2008 | 07:25 AM
  #3475
petevette's Avatar
Originally Posted by sKiMpYbOy
Hey guys,
I have the same engine with the same problem. My engine was delivered to me in Dec of 07 and I am under the impression that I have the updated carb however I am trying to confirm that. I am using the OS P3 plug. I have tried the regular trouble shooting even changing out my fuel tank but nothing helped. This past weeked I replaced the carb with a Nova carb and it seemed to hold a tune much better but I wasn't able to race it. I won't know for sure if the tuning problem is gone until I get a good 5 -7 minutes out of it. Prior to my switching, the engine would run good for about 3 minutes and then start acting up. Going back on to the track on Wednight for some test and tune so I will be able to see if the engine likes the Nova carb better. I have my fingers crossed.
petevette is offline
Old 06-30-2008 | 10:46 AM
  #3476
yaright's Avatar
Thumbs up
I was in the same boat, run great for 3-4 minutes, then start acting up, mainly the temperatures would climb to the 280’s. So, I swapped the carb for an OS unit, and now I have had zero problems. This is my first GO engine, one other person at my local track runs a 07 21 5 port turbo, and it screams, not to mention the run times. Some of the other racers look down at the GO engine, but after the last race, most of them are second-guessing themselves. I TQ’ed and first in the A main. I cannot say that the GO engine does not have its problems, but I think I will stick it out and see what happens. Just hope it runs as well with the new updated GO carb when it gets here.
yaright is offline
Old 06-30-2008 | 11:50 AM
  #3477
Originally Posted by zJatoRad
cheesecake you are saying that you got the tune on the spot and it's lacking power? your tune must be way off then because the 5 ports have stupid power on the low side
i have been spioled by having a 528 in my truggy. everything is now under powered if it was in my buggy it would be balistic. it was temping around 230 and had awesome power but it wasnt 528 power.
cheesecake is offline
Old 06-30-2008 | 12:32 PM
  #3478
I got a 5 port a few months ago I was having the same hesitation problem after 3-4 minutes others are having. I even went so far as to keep pitting in a b main when I was up a couple laps and could only get it a little better. I finally put an old vpsec carb on and it ran flawless after only tuning it on the table. Racefactors will replace the lsn if you want. The people at the track were impressed with the power once I changed the carb.
clebo3 is offline
Old 06-30-2008 | 01:09 PM
  #3479
grizz1's Avatar
Hey guys,
Run an OS P3 plug (the Go's like a hot plug) and tune the HSN Flush and the LSN 2.5 or more in from flush and it should run great.
I'm guessing you have the HSN wound in too much and the LSN way too rich. This is why it is flaming out and then running real hot when the tank level drops down some.
Also these Go motors are super tight and will run a little warm when new due to the extreme metal pinch. Just take it easy with a slightly rich top end until 1.5 gallons and then you will be very pleasantly surprised. As Massive said a few threads ago - just be patient and it will be worth the wait
grizz1 is offline
Old 06-30-2008 | 02:34 PM
  #3480
smracer31's Avatar
I cant get any where near 2.5 turns in on the lsn. I have the hsn flush, i get to about 1.5 turns and its running about 250-260. Doesnt seem to have the bottom end or mid grunt either (this is on a 7-port). I had sealed the carb but went over it again the other night and sealed everything extremely well. Go tech needs to work on their carbs and these engines will be much better!
smracer31 is offline
