Like Tree2Likes
Go-Tech Engines Thread
Old 05-14-2008 | 02:34 PM
  #2716
mugenb46's Avatar
1 left
mugenb46 is offline
Old 05-14-2008 | 02:54 PM
  #2717
rcdaddy's Avatar
Is the new version the one with the black case and coral head? Thats the one I have and Im not sure which it is. I do know its pretty. LOL
rcdaddy is offline
Old 05-14-2008 | 03:06 PM
  #2718
vnmsgt's Avatar
That is what mine were when I got them in. So they must be the new ones.
vnmsgt is offline
Old 05-14-2008 | 03:13 PM
  #2719
rcdaddy's Avatar
Thats what I was thinking, I called Russel at race factor the other day and asked him and thats what he said also. I just didnt want to get on here and sound like a fool saying I had a Spec with the coral head. But I guess I do. I will be getting the 5 and 7 port soon also. They will be Brake modded like the 3 port.
rcdaddy is offline
Old 05-14-2008 | 04:20 PM
  #2720
mugenb46's Avatar
to tell, take the back plate off, if the crank has a long cut on the left side it is the new 3 port, and the carb will be all black, and the end of it will be alum color
mugenb46 is offline
Old 05-14-2008 | 04:47 PM
  #2721
MassiveMods's Avatar
Originally Posted by slaytanic
Tmizzle, could you tell us what is changed in the 08 version besides I assume the new head markings. Is it just the updated crank? Or maybe an improved carb! Thanks Man!!
The New Gen 5 Go engines have
New balanced / designed crank
New Heat Sink / material fins cracking issue has been addressed
New Carb design
5 and 7 port now come with Turbo HB
Crank case ribbing changed in shulnre port
Deeper angle cut in crank case in front of bearing
Knife edge rod
Thats about it ... oh yes the exhaust porting is now matched at the factory !
Thats about it i think unless ive missed something .
Cheers MM
www.massivemods.com
MassiveMods is offline
Old 05-14-2008 | 07:27 PM
  #2722
tonyy's Avatar
Originally Posted by will g
what pipes have you run ? thnx will g
2047
jp-1
jp-2
2013
086
tonyy is offline
Old 05-14-2008 | 07:50 PM
  #2723
Go 2047 or the 086 would be my choice
Old 05-15-2008 | 01:10 AM
  #2724
vti-chris's Avatar
I'm currently using Sh(LRP) glow plugs 7# med-cold.
I want to move back to O.S. plugs but i think i'll go with the P6 or P7.
Has anybody used these two or only P3s are used on the GOs?
vti-chris is offline
Old 05-15-2008 | 03:22 AM
  #2725
grizz1's Avatar
The OS P3 is the plug of choice here. The Go Tech engines really seem to like this plug. I have been using the LRP #6 plugs over our summer and they have been good. Since winter has come though, I have had a little trouble with idle and fine tuning using the colder plugs. I have switched to the OS P3 on the recommondation of other Go Tech users here and find them great. I will most likely use them all year round now. With the standard button I found a #5 plug worked fine pretty much all the time.
Summer we normally race at ambient temps of around 20 - 24 deg C and in winter around 14 - 18 deg C maybe a little cooler at times.
grizz1 is offline
Old 05-15-2008 | 04:21 AM
  #2726
vti-chris's Avatar
Ambient here is:
Summer: 35-45C
Winter:5-15C
I usually use the same plug both seasons.
That's why i'm looking into the P6 or P7 plugs.
Or maybe P7 for summer and P6 for winter.
I'm just looking for info on these plugs besides the P3.
I also want some info on the 9mm venturi if someone has used it.
Old 05-15-2008 | 06:00 AM
  #2727
hey Brian i sent you a pm.
GRudinger is offline
Old 05-15-2008 | 06:40 AM
  #2728
will g's Avatar
i am using a rb #6 in my 25 6port standard and it seams to work nice i have been running odonnel 097t in my 21 5 port turbo i guess these are good plugs they seem to last a while thnx will g
will g is offline
Old 05-15-2008 | 06:54 AM
  #2729
Tabushi's Avatar
P3 and P4 from OS are the ones to use ... i dont think you need other than that
Tabushi is offline
Old 05-15-2008 | 04:43 PM
  #2730
Vigilante212's Avatar
Well i have half a gallon on my 5 port and I am finally able to run it without tinfoil on the head lol, but I still cant start it without heating the head first.
This thing is a monster plain and simple.
Vigilante212 is offline
