Like Tree2Likes
Go-Tech Engines Thread
Old 06-04-2008 | 04:00 AM
  #3031
vnmsgt's Avatar
Originally Posted by MassiveMods
you can never state whats the best .. experimentation will tell you what works for you..
That quote should be used WAY more often in so many things that have to do with R/C. I will remember this one! Well said.
vnmsgt is offline
Old 06-04-2008 | 06:13 AM
  #3032
max_chen's Avatar
Originally Posted by Bubonic-X
Can somebody post a link as to where I can get this 0801 pipe in the US?
I think that you can contact with "mugenb46".he is a professional guy.
max_chen is offline
Old 06-04-2008 | 09:34 AM
  #3033
will g's Avatar
got ? would a os 2060 work with the 3 port race spec .21 engine pretty good or ?? thnx will g
will g is offline
Old 06-04-2008 | 12:07 PM
  #3034
I don't know if this has already been asked but with the .21 non race motor the instructions that come with the motor and what is on the website is different for the break in procedure. Which procedure should be used ? Also if you go by the steps in the manual it does not tell you what temps you should be running at for break in. Just a little confused so just a little insight would help as im fairly new to nitro.
teamreidy is offline
Old 06-04-2008 | 01:38 PM
  #3035
mugenb46's Avatar
[email protected]
mugenb46 is offline
Old 06-04-2008 | 02:14 PM
  #3036
grizz1's Avatar
Hi teamreidy - Use the method as described by Brian from Pro Twister Mods. You will find it at the bottom of page 78 on this forum. I have used this on 3 Go-Tech engines and they are all running long and strong. There are many different methods and theories out there on break in. This method works for these particular motors so I just stick with it.
grizz1 is offline
Old 06-04-2008 | 11:36 PM
  #3037
ok im having this issue with my go 5 port it seems that the bottom end is always too lean it lean bogs all the time ive tried everything and i cant get it to hold a tune i heard there are some faulty carbs and i have a feeling i have one of them.
cheesecake is offline
Old 06-04-2008 | 11:42 PM
  #3038
vti-chris's Avatar
What i found about the GO carbs is that the LSN is toooooo sensitive.
1/8th increment can get you from rich to lean without even knowing!!!!
What i do is try to keep it rich and lean the HSN.Although i don't like this kind of tuning but seems to be the easy way out.
vti-chris is offline
Old 06-05-2008 | 12:03 AM
  #3039
if i get the bottom end set right and i start leaning the top my lean bog gets worse if i richen the top it gets too rich all around
Old 06-05-2008 | 12:35 AM
  #3040
grizz1's Avatar
That can happen because the HSN has a direct effect on the LSN settings. ie - if you lean the HSN you lean the LSN too. That's why it pays to set the HSN first and then the LSN so your not chasing your tail around in circles.
Try setting HSN at flush and LSN at 1.5 turns in. Then tweak the the HSN if needed for good full throttle performance, then lean LSN until you get a nice steady idle and good clean acceleration off the mark after 10 sec of idle.
grizz1 is offline
Old 06-05-2008 | 04:09 AM
  #3041
what i mean is that if i turn it 1-2 hours rich the whole engine gets really rich ive never had a novarossi do that to me
ill give it a try though i keep setting the high end to slush getting the bottom set right then i tweak the top it runs great up top but hesitates like its lean
Old 06-05-2008 | 04:17 AM
  #3042
slaytanic's Avatar
Cheese. I have a new '08 5 port and 3 port coming in this week. I will bring it out so you can compare it with yours. I won't have time to break it in though.
slaytanic is offline
Old 06-05-2008 | 04:28 AM
  #3043
ok cool if i have to replace the carb this will eb the first and last go i will ever buy.
i knew there were issues with earlier carbs and i just hope i dont have one of the earlier ones
Old 06-05-2008 | 04:40 AM
  #3044
vti-chris's Avatar
Make sure you are not having any air leaks.
Check for any fuel("fresh") on the engine after 3-4 tanks and try to spot the leak.
All carbs are different...some need 1/4th increments some need only 1/12th.
My previous OS required 1/12th adjustments at the HSN and 1/8th-1/4th at LSN.
The GO requires 1/8th-1/12th for both LSN and HSN adjustments.
These are for fine tuning.If you are way off then go with 1/8th and 1/4th.
Old 06-05-2008 | 07:50 AM
  #3045
Welll..... there is clear instructions how to check the carbs and determine if you have one with issues or not. Even if you have it's pretty easy to fix it just takes some time and effort. I think it's not reasonable to bash an engine because you don't know how to tune it or "don't have time" to check things before you go. So there really is no free lunch here either.
Poinas2 is offline
