Like Tree2Likes
Go-Tech Engines Thread
Old 04-30-2008 | 06:19 PM
  #2521
Originally Posted by petevette
I don't know much about the 3 ports, but I don't think they will run with the Turbo heads. Someone please correct me if I am wrong. Not sure if the race spec 3 port is turbo or not, but doubt the sport will run with a turbo head on it.
Are you talking about the engine head or burn room button ?
Sport 3 port - You can use a turbo button off of a 5 or 7port.
Race 3 port - I think comes with a turbo.
Brandon Powell is offline
Old 04-30-2008 | 06:22 PM
  #2522
guys thanks shane keller saves the day question answered ...thanks shano
zixxer is offline
Old 04-30-2008 | 07:19 PM
  #2523
mugenb46's Avatar
The sport 3 port will run very good with a turbo head button, the sport engine has more bottom than the spec 3 but it doesnt have near the top, the spec 3 is turbo only, the spec 3 is also easier to control out of the turns, very fast engine., i have 2 available
mugenb46 is offline
Old 04-30-2008 | 07:21 PM
  #2524
Originally Posted by GenReaper
Had the same problem with mine mate.
To fix this pull the retaining screw out, then the two halfs of the locking bolt that clamps the carbi in the crankcase then grab an angle grinder and shave a small amount off the midle of both of the pinch bolts, dont bother trying to do it with a file as it is hardened steel and you will be there for a year, or use a pedestal bench grinder just be carefull, and i promise you this will fix your problem, just dont forget to seal the pinch bolts after and lock tight the retaining bolt when you line the carbi back up.
hey gen how much did you take off in like millimeters? thanks man
zixxer is offline
Old 05-01-2008 | 09:08 AM
  #2525
will g's Avatar
petevette i have ran the 3 port sport with a turbo button head on it and ran nice was really aggressive on bottom but lacked a little on the top thnx will g
will g is offline
Old 05-01-2008 | 09:43 AM
  #2526
tonyy's Avatar
i have the 3 port and my has lots of top and not so much bottom
tonyy is offline
Old 05-01-2008 | 12:58 PM
  #2527
mugenb46's Avatar
you have the race spec right?
mugenb46 is offline
Old 05-01-2008 | 01:12 PM
  #2528
mugenb46's Avatar
mugenb46 is offline
Old 05-01-2008 | 03:58 PM
  #2529
shady3031's Avatar
Brian-did you get any of the 25's in yet?
Jason
shady3031 is offline
Old 05-01-2008 | 07:50 PM
  #2530
petevette's Avatar
Hi guys, I know there has been a lot of talk about what pipes to use with what engines, I didn't pay too much attention at the time because my 7 port turbo was running real good with a .053. As of last week it seemed to start changing on me. Wasn't running very good at all. I checked the usual things like fuel line, glow plugs, clutch etc. Everything checked out. Decided to try just for kicks to change the pipe to a JP-1 and seems to run really well with it. Won't know for sure until I get it on the track, but ran well up and down the street with just a slight difference in tunning from my .053. I still have the head shim installed. The engine is fully broken in now. What effect will keeping the shim in versus taking the shim out have on the engine?
Does anyone else have an opinion on using a JP-1 pipe on the 7 port T? For that matter, what about the other JP pipes?
petevette is offline
Old 05-01-2008 | 08:42 PM
  #2531
22Racer's Avatar
Taking out a shim will give you more bottom end. My son was running a Nova 9901 on his 7 port last time out, haven't played around with many pipes yet though.
Rex
22Racer is offline
Old 05-01-2008 | 10:12 PM
  #2532
double post
cheesecake is offline
  #2533
well i figured out my lean bog issue it was a carb leaking at the base where it seals to the engine so i ripped it down sealed everything and installed my turbo head button with a os p3 plug and so far so good i ran a tank and it temped around 200 with plenty of smoke and power and no lean bog
Old 05-02-2008 | 02:12 AM
  #2534
Vigilante212's Avatar
yea take that shim out if its fully broken in it could be causing low detonation.
Vigilante212 is offline
Old 05-02-2008 | 02:56 AM
  #2535
I have drive my 7 p 2 gallon, and i have not take out any shims, i think is 2 shims ther, shold i tak out 1 shim?
Lars Erik is offline
