Like Tree2Likes
Go-Tech Engines Thread
Old 10-14-2007 | 04:54 PM
  #226
can anyone help with getting in touch with GO tech please, its really important. has anyone recieved replies from the current email listed on the web page?
DirtRacer is offline
Old 10-14-2007 | 05:21 PM
  #227
Rocket42's Avatar
Dirtracer PM
Rocket42 is offline
Old 10-15-2007 | 06:41 AM
  #228
jumpjunkie's Avatar
Has anyone run the 7 port at altitude? Here in CO we run at 5200ft. Is the head shimmed and would it need to be removed?
jumpjunkie is offline
Old 10-15-2007 | 07:39 AM
  #229
salteen's Avatar
I'm currently in the market for a .21 and I'm loving what I'm seeing with Go Tech. I will be buying a 5 port soon. I see on their website it says to use only OS compatible glow plugs but I was wondering which plugs do you guys run in them? are any of the MCs compatible?
salteen is offline
Old 10-15-2007 | 08:05 AM
  #230
OS #8 plugs are best. I've tried OS R5's and A3's also.
I'm going to try O'Donnell 77os plugs soon.
This engine needs a short standard plug. A long plug like the MC's and others will hit the piston.
satoch is offline
Old 10-15-2007 | 08:38 AM
  #231
salteen's Avatar
cool, thanks!
salteen is offline
Old 10-15-2007 | 08:45 AM
  #232
Rocket42's Avatar
The long plugs don't reach in far enough to hit the piston, if you do use those plugs the engine will still run, but it will not run as effieciently because the plug will protrude into the dome shape of the combustion chamber. O.S. #8 is probably the closest to the Go #5.
Jumpjunkie, the engines come at the minimum shimming for 30% nitro so performance should be close at altitude, after break in (1-1.5 gallons) you may want to pull the thin shim out if you feel you need more power.
Rocket42 is offline
Old 10-15-2007 | 01:14 PM
  #233
I have 2 head shims that came with my 5 port. What are the thicknesses?
satoch is offline
Old 10-15-2007 | 01:33 PM
  #234
hi, i run the 7 port and i'm very pleased with it. i'm going to buy another one soon. i have'nt tried or seen the 5 port since i'm the only one in my country with go tech engine and i have some questions:
1. if there is one which is more powerful overall (7 port/5 port)?
2. how much the powerband is different?
3. what is your personal favorite (if you have the two)?
thank you,
dotan.
dotan23 is offline
Old 10-15-2007 | 01:41 PM
  #235
Rocket42's Avatar
Satoch, the engines come with 1) .1mm shim and 1) .2mm shim
Dotan in buggy my personal favorite is the 7port, the engines are very similar since they have the same intake porting. Its hard to say which one is more powerful the 7port spins more rpms while the 5port has more torque. The difference in powerband is very noticable, the 7port is also more sensitive to pipe clutch combo then the 5port. I think it comes down to what you like on the track.
Rocket42 is offline
Old 10-15-2007 | 02:49 PM
  #236
CHogle's Avatar
how would you suggest to break in one of these engines Ive always ran novarossi and ill be switching to the 5 port go , do i break them the same or differantly. I usually let the novarossi's idle for three and then slowly make laps on a dirt oval tuning in the power slowly for four tanks then i let her rip. Do i do this with the go???
CHogle is offline
Old 10-15-2007 | 02:51 PM
  #237
It's best to follow the break in procedure outlined on the Racefactor Industries site for the Go: http://www.racefactorindustries.com/id1.html
satoch is offline
Old 10-15-2007 | 05:39 PM
  #238
Rocket42's Avatar
You can break in the engine with any method yoru comfortable with, there are a lot of different ways to break in engines, if you choose to use the method on the racefactor website I would reccomend an extra tank of idle then whats mentioned.
Rocket42 is offline
Old 10-16-2007 | 02:08 AM
  #239
rossoh10's Avatar
I`m still having serious issies with my 5 port.The first gallon I had no issues at all.I am another half a gallon through it(1.5 gallons in total after break in).The weather got colder here.I live in SOcal so its not to cold about 60 degrees when running.Anyways I started to foul or burn plugs.I was thinking that since the temp dropped that the engine leaned out a little more and was causing my problem.Over this weekend at the North s South race I richened everything 2 hours.For practice and my first heat I had no problems.Then it came time to run my 2nd heat....dead plug again,I popped another plug in and wentto race.I had goood power and great smoke coming from the pipe,still 70 degress outside,at the end of the 5 minute heat I lost all bottom end power.The next lap around I had no power on top and bottom.I was moving like a turtle.Right after I finished the race it died.Forsure another dead plug.I threw in a new plug and it fired up.I called it quits installed a back up engine and finished the day out.I inspected the engine,I have a black piston...probably caused by over heating.The engine still still has plenty of compression and will start.What could be causing this problem.I`m going to go back to factory settings and retune.Is there something I should look for,could there be something wrong with the carb.Any advice would be appreciated.I have tuned and ran lots of engines.Why is this one giving me problems.I also placed in the amain but unfortunatley I wasn`t running the go
rossoh10 is offline
Old 10-16-2007 | 02:34 AM
  #240
lancer mx's Avatar
Smile how to break go engine
Gud afternoon people can you please help me how break in my new .28 redhead go engine from the start what things i must do first and up to the point i start to race it by the way im going to put it on my truggy thanks peeps
lancer mx is offline
