Like Tree21Likes
problem with tuning
Old 11-24-2024 | 01:02 AM
  #31
Ok think i got it... what you all think?
petersen114 and Pharcyed like this.
boomtheroom is offline
Old 11-24-2024 | 11:58 AM
  #32
Panic09's Avatar
https://youtu.be/AZWr7xVB4NA
definitely sounds healthier....what did you adjust?
Panic09 is offline
Old 11-24-2024 | 02:27 PM
  #33
Replaced front bearing, then closed idle and leaned bottom end
Old 11-24-2024 | 02:38 PM
  #34
1995 Monster T's Avatar
looks and sounds good. You could try softer clutch springs to put more load on engine Sonner? whatever you do don't mess with the low needle only the high open it if you have too. never lean it out with low % oil lube fuel. I bet the lean oil % wrecked the front bearing. you would never had to replace it with e more % oil lube. Good smoke trail ! the way to check front bearing for leaks is an oil trail under the flywheel.
1995 Monster T is offline
Old 11-24-2024 | 04:04 PM
  #35
Roelof's Avatar
Funny, I run 9 to10% oil and never had a failing front bearing.
Bud and petersen114 like this.
Roelof is offline
Old 11-24-2024 | 07:07 PM
  #36
Originally Posted by 1995 Monster T
looks and sounds good. [Exactly, Proper fuel and correctly working things are amazing!] You could try softer clutch springs to put more load on engine Sonner? whatever you do don't mess with the low needle only the high open it if you have too. never lean it out with low % oil lube fuel. I bet the lean oil % wrecked the front bearing. you would never had to replace it with e more % oil lube. Good smoke trail ! the way to check front bearing for leaks is an oil trail under the flywheel.
"Good smoke trail" So, You just told us hes using more than enough oil in professional fuel. thanks
" I bet the lean oil % wrecked the front bearing" Wrong. I've had bad bearings from new... did they not use enough oil when machining the cooling head to cause the bad bearing?
petersen114 likes this.
MonsterJuice is offline
Old 11-25-2024 | 04:32 AM
  #37
Roelof's Avatar
Failing front bearing can be anything like a bad quality (as mentioned), dirt (common issue with offroad), unbalance on the clutch or a too tight gear mesh. Also a binding in the whole drivetrain or a too heavy gearing can put huge sideway loads on the front bearing.
Roelof is offline
Old 01-13-2025 | 02:31 AM
  #38
briefer's Avatar
Sounds good but bear in mind that you don't have space in your yard for proper testing. The tuning changes as the engine gets to working temperature (which varies between different engines). The tuning should be reliable to hold for at least 15 min with 1 refueling without dropping performance or having flameouts.
I have seen often cars working great at 5min qualification heats, and then having several flameouts in 30 minutes finals.
briefer is offline
