Team Magic G4
Sp Racer:
yes i totaly agree on what you said!! Its what works on different people, i might not race with world class drivers but i race with my countries best drivers(last weekend came third), and with the correct maintanance, its hard to go wrong
ps anyone know whats going on with the tm wesite. i cant get in, is it just me or...
This may sound like a stupid question to some but if i change my front roll centre by rotating the little triangular piece in the speedshot bracket, do i have to adjust the front toe and camber accordingly or do i just leave it and move the hinge pin around.
yes you will have to readjust especially if you go from outer to inner position, or vice versa.
I've never realised how many parts on the G4 are compatible with parts from the V1RRR. So far i've found the front and rear CVD's work and now the flanged ball in my shock stripped so a titanium ball from 3 racing for the RRR fits nicely. Who would of thought
I thought so i just wanted to make sure, thanks Patto
Front upper arms also direct fit - if you run out of the flying wing ones !
Bearings are the same size -
V one R / RR / S (not RRR) = same size belts ( TM ones are better ) - also the diffs are interchangeable ( but will give you the non-ed trans ratio )
Diff out drives are the same
You can also use the RRR rear sway bar blades, shock pistons & bladders
V one R front bumper fits ( again , the TM one is better ! )
I have an old VoneS that I've given the "TM" treatment - flying wing arms, Kfactory belts & ED transmission fitted, TM shocks etc.....looks so good that it's hard to see the mods, everything just bolts straight on !
Remember, the G4 is "loosely" based on the VoneR
G4S Transmission Parts Up for grabs
Hey Guys,
I'm making the switch to the ED transmission and offloading all of my stock G4S transmission parts on EBay (item number) 220349661828
On another note.. I was watching RCTVLive.com they had a great tip on getting a nice round wheel arch... which works great...
the G4 RTR also gets a review it the episode too..
http://video.google.com/videoplay?do...27206544&hl=en
Regards
Anthony.
Regards
Anthony.
New to the TM world. Just got a g4s and wanted to know what hopup would be more useful first, the speed shot front end or the ed transmission. All of my drive time is in the track!
Thrust Bearing badness...
Bud one of 2 things i can think of.
1. bearing must be lubed with grease at least once on a club day or as well as before the mains.
2. run a smaller clutch gap of .4/.5mm, larger clutch gap is more aggressive.
The .1mm endplay is perfect and isnt teh problem.
Possible that you have clutch engaging a bit high and its stressing the thrust but i doubt it.
i've got grease on it, and slight endplay ....
i do have a largish clutch gap.. .7mm
Here is the question.... whats the difference between running a larger clutch gap and a stiff clutch spring.... ?
At the moment, I've got a soft (red) clutch spring and a large clutch gap...
how would this compare with a smaller clutch gap and a stiff spring... ?
Hope this makes sense... would this explain my thrust bearing badness?
G4 and new G4 Anniversary
Very nice, looks a little like my garage except for one of the motors.
Geez those guys in the picture look impressed with you
G4S
I got the G4S a month ago and its great. I recomend it!
Team Magic G4 II Concept car
