Team Magic G4
Old 07-30-2008, 03:12 PM
  #9571
Bundy_Bear's Avatar
Originally Posted by Pattojnr
well guys here is the latest offerings from K Factory racing products. looks bling as an old friend would say, and looks Expensive. notice new rear lower roll center adjustments in the bulkheads.
http://www.redrc.net/2008/07/k-facto...et/#more-10764
BLING too right!!!!
Patto this isn't the roll centre adustments you were calling for is it? Not sure alloy bulkheads are a wise move, have seen issues with them back in the TT Ts4n days.
BB
Bundy_Bear is offline
Old 07-30-2008, 03:32 PM
  #9572
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Bundy_Bear
BLING too right!!!!
BB
wellmaybe Nick was listening ? or maybe they were already working on it ?
Pattojnr is offline
Old 07-30-2008, 03:36 PM
  #9573
Pattojnr's Avatar
Originally Posted by Sp Racer
nc racer !
p.s. PATTO !
Next time I see you, I will zip tie you to your pit chair and slap the serpent out of you....hehe!
thats some mighty big Zip Ties
Pattojnr is offline
Old 07-31-2008, 09:52 AM
  #9574
NitroWD's Avatar
Default Noisy servo when braking?
hi guys,
is it normal for the T/B servo to be making noise whenever u brake?
it's quiet when throttle but it's noisy when braking. i've check the linkages and they're not binding at all...
btw, i've just changed to the futaba bls451 servo.
NitroWD is offline
Old 07-31-2008, 11:52 AM
  #9575
thanks for the help SP!
nc racer is offline
Old 07-31-2008, 11:58 AM
  #9576
Speyederjedi's Avatar
Originally Posted by nc racer
ok guys i'm back with another stupid question.
I have been mezmerized by the bling of the g4+ and i've decided to buy it.
what i need to know is what will i need to purchase to make it run.
I already have a spektrum radio so, i'm thinking
Engine
header and pipe
2 servos
Will i have to buy spur and pinion gears for it? and if so, do you guys have any recommendations as to what to get brand wise for the above and what teeth pinion and spurs?
I'm looking for speed but, i'm also trying to get a racing club started in my area becuase driving in a straight line is only fun for a little while.
thanks for the help and i look forward to driving a TM car very soon.
NC Racer,
For the price any of the Picco .12 Red dot engines with the Picco pipe you can't go wrong, Best bang for the buck.
KO Propo or Futaba high speed servos and as stated by previous post get the mini receiver.
Spurs and pinions, I'd at least try and get 1 of each and 2 if possible on each of the 16t 1st gear pinion 20t & 21t 2nd gear pinion;51t & 52T 2nd gear spur; 45t,46t and 47t 2nd gear spur.
Hope that helps, Best of Luck.
G4RS
Speyederjedi is offline
Old 07-31-2008, 12:50 PM
  #9577
ok, another stupid question then.
i have the spektrum dx3 radio system.
i can use the new mini recivers with it?
nc racer is offline
Old 07-31-2008, 02:31 PM
  #9578
Trader Rating: 17 (100%+)
Yes...
Solara is offline
Old 07-31-2008, 06:54 PM
  #9579
I am wondering....what caused the TM EUROPE shut down everything about TM over there....
I bet that has many things to do with the TM managment team over @ Taiwan.....horrible
http://www.teammagic-europe.com/
Solara is offline
Old 07-31-2008, 09:59 PM
  #9580
British Menace's Avatar
It's because TM insist on supplying direct to customers around the world, undermining distributors and stores in the region mentioned.
There needs to be a management change over there at TM Taiwan!
Politics!
Anyway. Back to racing.
British Menace
British Menace is offline
Old 08-01-2008, 01:37 AM
  #9581
razzor's Avatar
what can we say ........
TM is shooting themselves in teh foot again, dont they learn !!!
Didnt even know there was a TM Europe.
question :
why wouldnt the Kfactory WC kit for the G4RS not work on a G4S ???
Should be able to transfer over most if not all G4S parts to mke a complete car and that is including ED trans.
razzor is offline
  #9582
aussies1129's Avatar
Trader Rating: 74 (100%+)
Originally Posted by NitroWD
hi guys,
did you adjust your servo travel?
cheers
aussies1129 is offline
Old 08-01-2008, 01:40 AM
  #9583
so with the new wc upgrade kit is the chassis 4mm or 3mm?
can anyone guess the price??
Old 08-01-2008, 02:14 AM
  #9584
NitroWD's Avatar
cheers
yup, adjusted...any less my brakes will not be strong enough already.
about the WC chassis...3mm is fine as long as it's stronger than the current RS 3mm chassis.
price? no idea but hopefully <100?
NitroWD is offline
Old 08-01-2008, 02:16 AM
  #9585
NitroWD's Avatar
i believe the rear parts wouldn't fit on the G4S chassis...
NitroWD is offline
