Team Magic G4
#8311
#8312
QUESTION ABOUT KOYSHO CRF
hi!!
i consider Kyosho New CRF Engine for Korea National Race.
it is harmonize with UFO Clutch system and Mielke Pipe?
#8313
It is the same as Team Orion CRF engine. I have used this engine and it works well. UFO clutch with red clutch parts, 1.9mm Mugen spring works very well. CRF square spring works well too.
I have not used the Mielke pipe but it should work well. Nova 2630 or 2601 works well and the CRF pipes work well too. Many choices for the pipe.
#8314
thanks for your reply..
i know as New Kysho CRF engine solved some problem in CRF initial stage.
maybe.. it was the lack of idling preservation.
Do you know about CRF's weak point?
and some advice pls when using CRF.
thanks..
#8315
diff heat sink
i changed to Kyosho V-one RR Heat Sink Diff Case.
i expect it will help steady diff characteristic in long time run.
#8316
Hi gansei...... long time no see
So what's up ??
So what's up ??
#8317
Hi all....
Getting ready for the nationals and was wondering if there is anyone out there that has run on this track at all with the G4s or the G4+?? Just want to see what they like with there car for that track , since i get there pretty late in the week and practice will be at a premium....
Mike Blackstock
Mike Blackstock
#8318
#8319
#8321
I am having the final nats of the year at the end of the month.
Been busy with renovations at home and getting my new shop sorted out so havent been around much lately.
Still need to put my car together and get alll my gear sorted.
Good luck to the guys , as Dnitro said "may the Gforce be with you"
#8322
Hi all....
Mike Blackstock
Mike Blackstock
See you in Texas. The track is fun.
#8323
thanks D, and Razzor. best of luck to all, seems we are all aving our big races at once all together so good luck to all, and best wishes go out to Gansei, Razzor, and Mike. there will be a few Forum regulars at the AU nationals. Rob (Toy 000, Frankie and myself). will be fun and cant wait. not long to go now, funnily enough i have been very busy. also building a kit at the moment as well, just to pass some time keep the nerves at bay.
#8324
