Team Magic G4
#1516
Originally Posted by rcrevolution
Hi fellow racers, I have a question about the belts on this car, are the Kfactory low friction belts worth the extra cash? are they more durable?
No one has the stock replacement belts, i thought raceday or aces hardware would have them but when I put in the part number they don't show up and I don't feel like ordering all the way from rcmart for a few belts.
so are they way better?
also whats the word on the shock ball cups?
#1517
HELP!!
Can anyone tell me where I can order a G4S from a "reputable" store or hobby shop? I have seen people with it on Ebay, but I had a bad experiance with Ebay and do not want to make any purchases from there. Can anyone please help me out? thank u
#1518
BK,
I bought most of my TM stuff from Raceday Hobbies and they have provided excelent service. Raceday's website is clunky at best but you can reach them @ 480-567-2560.
Mark
Mark
#1520
Originally Posted by mtveten
BK,
Mark
Mark
#1522
Shock Ball Cups
For a temporary fix on the shock ball cups, use the steering link ball cup links. Just cut them down to size and they will work just fine.
#1523
Brian Berry set-up
uniquexme, I have send you a P.M.
regards Mac
regards Mac
#1525
congrats ZOOM, can you give me your clutch setup for the CRF?
#1526
Clutch nut showing 1 thread.
1 weight in the right hand side of each flyweight.
I then started off with .6 gap but I played with the gap to get the right feel. The engine is still no terror off the turns so don't expect too much.
I ran 18/23 and 52/47 gears.
Cheers,
Mike.
#1527
Hi all,
I'm newbie with g4(newbie riding nitro also), i ride the rtr version named Le Mans. I'm really happy with the car.
I got one question. When we talk about the engine having to be at around 220 farhenheit(104 celcius) thats at idle right? Is it normal for the temp to go up to 360Farhenheit(180 celcius)after riding for a while at high trottle?
The engine is the stock sh .15.
Also I will enter my first race with nitro next week. Anyone care to suggest what kind of setting i could use for this track?http://www.rcpikeriver.com./english/Notre%20piste.htm I did download some sample setup sheets from the team magic website as referance but i dont know what the tracks look like so it doesnt really help.
I bought the k factory one piece 32t front solid axle set.Would it be a good idea to install it for this race?
One more thing. I heard the manual for the g4s has a lot of information about setting up the car. The manual that came with the rtr version is completely useless! I emailed team magic about getting the g4s manual but they never replied. If anyone happened to have a pdf version of it ...that would make me a happy men.
Anyway thanks all for your help.
#1528
360 degrees is far too high. When people talk about motor temps of 220 to 250 they are talking about after the motor comes back from a qualifying run or a race. You should be able to see the temps drop a little while idling. Set your high speed needle back to where the manual says and try again to prevent damage to the motor. Maybe talk to your hobby shop where you got the car from and get some basic advice.
As for setup, I'd worry about learning the car as it comes in box stock form before changing the setup too much.
Good luck.
Cheers,
Mike.
Good luck.
Cheers,
Mike.
#1529
Winner of DTM Cup in Indonesia
2005 - Daniz24 (G4 Evo)
2006 - Teddy Syach (G4S)
After finish line, we found out that the there's a leak from the pipe (1 of the small manifold spring is lost or broken) that's why after 2nd refuel the car suddenly lost its power for about 10% and sounds like its overheating
#1530
Ok thanks fo the info. I mail ordered and since i dont speak cantonese...The hobby shop here dont want to help you unless you buy the car with them.The manual has no info about the engine.
I played with the higher needle. I'm just at the treshold of the engine dying by itself. Would the lower needle have any effect? I notice glow plugs have number would getting a lower number glow plug change anything?
I guess i'll postpone the race if i dont wanna blow the engine.
