Serpent 705
#1846
just because when you put ont he clutch nut wont it turn the crank when it gets tight??
#1847
here's what you can do.
first tighten the clutch nut with your hand. now use a plier that can extend out, make sure you have a firm grip and also use towel around the flywheel (we don't want to have a scratch on our new flywheel right?) and use a socket ranch.
if you do this correctly you won't damage your engine.
#1848
but wat happens when the nut gets soo tight the the piston starts to turn over there for turning the cranks which the nuts on??
#1849
as long as you have a firm grip on the flywheel, engine won't turn over.
#1850
I use a flywheel wrench from Ofna to hold my flywheel and lock it with my Hudy wrench (or u can lock it using those 4in1 glow plug wrench). Hold the flywheel wrench and turn the nut wrench in and tighten it. Soo below site of how the flywheel wrench looks like.
http://www.ofna.com/tool-glow.html
The only time i use the piston locker is when i need to take out the clutch bell and change my pinion gears. DO NOT use the piston locker to thighten the 10mm nut onto the flywheel as u put a stress on the conrod.
btw, i always use the collet that comes with the engine, in my opinion, they are a lot better.
#1851
ok.. thnx guys.. i get it now... so what does everyone think... should i use the collet from the engine or kit??? cuz one says engine and one says kit... wat have you guys used??
#1852
#1853
good point... very good... i like that comment... thanks!
#1854
Newer 705 kits now have a grub screw on each 2 speed shoe, is this really a big issue or not that important. This would get the two shoes closer to the housing.
7.0 Gearbox Assembly
Step 7.1
http://www.mytsn.com/publ/publ.asp?sn=7&pid=6966
Realy easy I would guess to modify our current Shoes to also have grub screws I guess if it is an important adjustment to make.
Also would part number 909335 Rear Anti-Rollbar for the 950 work on the 705.
Picture on buttom of this link...
http://www.mytsn.com/products/product.asp?prid=2467
Step 7.1
#1855
are the grub screws included with the kits still though??
#1856
ok... i looked at mine and there is no whole or screws for that... but do i really need to do it??
#1857
Q & A
#1858
sweet... thnx...
#1859
Originally posted by PUNISHER
Thanks InitialD!
I'm still trying to get the whole airbrush stuff down to an ART. There are many good airbrush artist out there that blows me away with thier work!
Thanks InitialD!
#1860
Re: Q & A
I haven’t really had any problems with my 2speed without that grub screw to be closer to the housing. I assuming they updated the 2speed shoe for people that had shifting points problems. Anyway, its less weight on the 2speed gearbox with out those grub screws!!
The adjustable rear anti-rollbar (#909335) blades are to stiff for the 705/Impulse. You will have to change out the male blades for the front (#909216) blades.
Concerning the adjustable rear antirollbar blades, yes the male blades for the front is softer than the ones that come with the 909335. The bad part about these blades is that you need to predetermine the lenght where the grub screw will lock onto it. This is important that you need to determine that both left and right are equal in length and that they put equal pressure on both sides.
Once I get both lengths equal, I use a sharp object to mark on the shaft where the blades will be locked with the grub screws to equal length. The blades that come stock have grooves which you do not need to measure at what lenght you need to lock the blades.
