Serpent 705
#3346
Originally posted by modellor
Yeah Initial D. That is correct.
Airtronics dont make any radio equipment. They contract Futaba to make everything. So basically both are standard Futaba crystals repackaged and rebranded. Even the standard Airtronics servos are just replica S148/S3003s.
I have a few Airtronic standard servos and have mixed the parts with proper Futaba gear to make up a good servo out of 2 after a bad crash with my R/C plane.
#3347
I run different servo setups on my nitro stuff than I do on my electric M8 futaba-futaba reciever-airtronics crystals-JR8417 digital servo(speed and 150 oz of torq) for steering futaba 9302 I think ive got new cases on my futaba servos and I can mix the endplay and trims and subs in my radio so that thiers no digital glitch in the JR servo
#3348
Re: Re: Another-lame-excuse-why-i-haven't-any-pictures!
Originally posted by InitialD
My dear Mark,
Why do you have to put yourself to this kind of torture? Doing some atonement for the things you previously did to your car?
Hey, I think more time spent with the car will do you both good
My dear Mark,
I'm being punished with a heavy cold now I'll have to rebuild my car next week when I've recovered.
This weekend I'll go and watch the final round of the southern German 1/10th and 1/8th championship - should be good; it's at my local track, too!
#3349
Re: Re: Re: Another-lame-excuse-why-i-haven't-any-pictures!
And for goodness sake, get Michael to autograph your car. Perhaps some of his magic will rub on ya
#3350
Re: Re: Re: Re: Another-lame-excuse-why-i-haven't-any-pictures!
You know... the other thing is to keep us guys happy So don't forget to take those D1 pics when you're there enjoying
But I don't think he'll be there - he'll be at the national championship for sure, but then I can't make it.
Don't worry, the D1 will be there at the weekend
#3351
Chaussard with Serpent 705 wins French Championships
Just in
Final Results in the 200mm Pro class
1 Arnaud Chaussard Serpent 705 87 30:09.34
2 Steve Olanier MTX3 86 30:14.44
3 Jacky Mouton Serpent 705 86 30:17.46
4 Sébastien Wartelle Serpent 705 85 30:03.27
5 Vincent Heligoin Shumacher 85 30:05.54
6 Philippe Regolle MTX3 85 30:10.51
7 Marc Dell'Unto Vone 84 30:01.79
8 Vincent Hondekyn Vone/RR 84 30:12.64
9 Nicolas Bougnoteau MTX3 80 30:19.02
10 Jérôme Krowiski MTX3 58 24:12.88
http://www.mytsn.com/news/publ.asp?pid=8856
#3352
D. Its just works better for me, more traction and more steering. Not a very technical explanation i guess With only the rear sway installed the car would oversteer and tend to spinn out
But Im afraid that the car rolls lateral a bit to much in the faster corners so i will trim down a rear swaybar to 1mm.
I have not yet ordered the new fc-blocks yet, thats the next trick i will try. But I, as a newbie, try to change only one parameter at the time...
#3353
#3354
Yep,
We are all guilty of that one. i did it just a few weekends ago and completely ruined my weekends running. Forgot what the original set up was too so I got really frustrated and just gave up.
Making one change at a time is definately a must regardless of whether you are a beginner or seasoned racer. Another good tip for you Johan is to write down everything you do. It will allow you to have different set ups marked out that work or dont work so you can change the car in a hurry if the weather changes dramatically (not uncommon in my part of the world. lol).
#3355
Modellor, Regarding Futaba-Sanwa/Airtronics
What do you mean by "Airtronics dont make any radio equipment. They contract Futaba to make everything "?
Should i take as that the M8 is made by Futaba? Or applies it only to recievers and tx "moduls"?
Just trying to understand the industry
#3356
How much droop are you all running. I have been running 0 in the front and +8 in the rear.
#3358
Re: Shooter 4 mm Chassis - Part 1
Ok, as promised, a pic of the 4 mm chassis I got. Notice the cooling holes in the engine section and the cooling holes in the front, not to mention the front part being more solid. Less chamfering at the sides.
Nice 4mm chassis there!!
Man, that chassis looks like a slade!
Yeah, I havnt weight the car since I put on the Serpent 4mm chassis. I'm guessing it will add 10~12grams.
#3359
So the summary of my setup with the following below should yield a super oversteered car but it was nice to drive in the end.
small front tires
toe out +1
softer front compound than rear
a lot of rear droop +4
Perhaps this was a cumulative "problem" of running the front roll center too high with the smaller front tires and the front upper arm mod.
I must remember to take it one step at a time
#3360
Re: Re: Shooter 4 mm Chassis - Part 1
I don't think it's hit the road soon because at the moment I'm trying out other stuff and see if they work out first.
